Old Jul 21, 2014, 12:16 AM
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
Originally Posted by Vantasstic View Post
..plus a spare. Try as I might I've failed to kill the first...I wonder what the life span is of elapor type foam???
I can shorten it for you !
GLADUS63 is offline Find More Posts by GLADUS63
Old Jul 21, 2014, 04:46 AM
Just clumsy. Oh, forgetful too
MikeTheCrash's Avatar
undefined
Joined Jun 2008
Originally Posted by Cyprusflyer View Post
A lot of bench testing going on with the Arduino Txlator, for some strange reason I had to put the baud rate back to 38400, crazy but it was outputting nonsense on the serial monitor port, that fixed it.
Now I found that the DOSD was not picking up the IMU consistently, it only does that on booting up, as the serial data was good every time, I thought that maybe the timing of the I2C join request was a bit critical so introduced a 2 second delay there that has made it a lot more consistent:
void setup()
Serial.begin(38400);
pinMode(2, OUTPUT); //Serial Mux
digitalWrite(2, HIGH); //Serial Mux
pinMode(LED_RED, OUTPUT); // Red LED
pinMode(LED_BLUE, OUTPUT); // Blue LED
pinMode(LED_YELLOW, OUTPUT); // Yellow LED
slave_setup();
Serial.println("FY-30A AHI for DOSD V2+ by 'gytiswb' (www.rcdreams.lt) v1.0\r\n");
delay(2000);
Wire.begin();
this doesn't work for me, I just get a static horizon. Reverting to previous FW until I find my error!
MikeTheCrash is online now Find More Posts by MikeTheCrash
Old Jul 21, 2014, 02:55 PM
Joined Feb 2013
Mike, thats odd, static horizon means that roll and pitch is not being sent across but DOSD is picking up the I2C address for the IMU. Something really strange happened to me in that I changed the speed to the AP30 to 19200, worked fine, then a few days later I had to change it to 38400 as Virgis had it. The clue was monitoring the serial output from the Arduino. I do not have an explanation for this but my last effort uploaded and has not failed at all now, loads of bench testing and fresh boot ups done, I would say its 100% for me.
BTW monitored an AP31 for interest, on the way to reverse engineer, the format, its not as simple as there are 4 sentences in byte format that are sent out, I have found the header, sentence length byte and end of sentence marker. Just need to find out what each byte does, may reverse the problem and make a program to vary each byte and send to the Hornet OSD and watch what happens. Cant think of any RS232 analyser that can do this.
Post edit: found the speed glitch problem, I first used my desktop to program the device and selected the correct board in the Arduino environment. Then working in my shed, I switched to my Laptop and forgot to select the correct Aduino mini board, I had Duemilanove w/Atmega328P selected. Aha, so the Arduino clock divide registers will be different when compiled, this gave me the clue: http://forum.arduino.cc/index.php/topic,46458.0.html
So select the correct Arduino in the environment and the Baud rate should be 19200, thank god I wasnt going crackers then!
Cyprusflyer is offline Find More Posts by Cyprusflyer
Old Jul 23, 2014, 01:51 PM
Joined Feb 2013
And cracked the AP31 output format, probably easy enough to make a translator for it but probably not cost effective as the AP31 does a lot more than the AP30. May post the format if there is any interest, it is a lot more complex than the AP30 ASCII output!
Old Jul 26, 2014, 09:57 PM
Rookie Pilot
eBoon's Avatar
United States, IA
Joined Aug 2013
Do I have to use the current sensor if I just want to monitor battery voltage. Can I just hook up straight voltage from my battery to the current sensor pins and get voltage?
Thanks!
eBoon is online now Find More Posts by eBoon
Old Jul 26, 2014, 10:07 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Thanks!
Good question. I've never tried it. If you're using a 3S pack you can connect a battery lead to the DOSD power pins (wih jumper removed) and enable the External Voltage (I believe) reading. I wouldn't recommend using a 4S as the 5v regulator on the DOSD will get pretty hot. Anything larger will fry the regulator...no matter which pins you connect the battery to. You can, of course, use a larger batter, but need to remove the jumper and power the DOSD with a 2S or 3S battery.
Vantasstic is online now Find More Posts by Vantasstic
Old Jul 26, 2014, 10:13 PM
Rookie Pilot
eBoon's Avatar
United States, IA
Joined Aug 2013
Thanks Van - using a 3S battery to run everything on the quad. Had been powering the board from the voltage sensor - but think by removing the jumper and powering directly from the battery I'll get voltage.
Old Jul 26, 2014, 10:15 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Yep, that'll work fine. No need to use the sensor pins...just connecting you batter to the power pins with jumper removed will power the DOSD and display the voltage.
Old Jul 26, 2014, 10:25 PM
Rookie Pilot
eBoon's Avatar
United States, IA
Joined Aug 2013
Perfect! Thank you.
Old Jul 27, 2014, 04:14 AM
undefined
Joined Jun 2008
Thanks!
I actually did this on a little 2s plane setup I had. I had a 3.3V video circuit so it wouldn't run the DOSD normally. I put the 2s motor power into main power-in pin V1 and used the video voltage on V2 without a current sensor.
Having a voltage on V2 switches on the current display even if there is no current sensing voltage connected to DOSD.
Discussion Dragon OSD Level Flight FPV Talk 22 Dec 31, 2013 08:08 PM
For Sale New Intelligent Flight Dragon OSD bfischer Aircraft - General - Miscellaneous (FS/W) 7 Jul 19, 2010 11:56 AM
Discussion FS Ready to fly Intelligent Flight Dragon OSD bfischer FPV Talk 0 Mar 03, 2010 05:57 AM
Discussion RV OSD or Dragon OSD djdaveq FPV Talk 1 Feb 06, 2009 12:18 AM
Discussion RV OSD and Dragon OSD - so near to being Really good! magnetman FPV Talk 8 Nov 11, 2008 05:13 AM
