Old Jan 31, 2008, 12:37 PM
North Central TN USA
Joined May 2006
Windex
So why is blue Windex with ammonia not recommended for plank bending, only clear? The only clear Windex I find has vinegar, not ammonia.
420TEE is online now Find More Posts by 420TEE
Old Jan 31, 2008, 01:02 PM
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Perhaps it has something to do with the fumes from steamed ammonia?
Ever fry a jalapeno? The fumes are brutal. It's like all the oxygen is sucked out of the kitchen.
woodybob is offline Find More Posts by woodybob
Old Jan 31, 2008, 01:06 PM
master boat slacker
USA, NY, Mastic Beach
Joined Feb 2006
or the blue will stain the planks
bigford is offline Find More Posts by bigford
Old Jan 31, 2008, 01:20 PM
Joined May 2006
Planks will be epoxyed and painted anyway. This sugestion is from the Lyman direction book from M.A.C.K. Products. I've used blue before and never noted any blue color. I don't heat the Windex, just soak the planks.
Old Jan 31, 2008, 01:37 PM
Canada, BC, Victoria
Joined Feb 2006
I just use straight ammonia
smart_racer is offline Find More Posts by smart_racer
Old Jan 31, 2008, 01:55 PM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I just use warm water...
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jan 31, 2008, 03:09 PM
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
When I need to wet a plank for bending, I spray it with some water and heat the plank with a heat gun.
When all else fails, I use an oxy-acetylene torch and a 20 lb sledge hammer.
CG Bob is offline Find More Posts by CG Bob
Old Jan 31, 2008, 03:34 PM
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
vinegar weakens the celluar structure of organic substances, making them 'bendable'. It also weakens them.
I'd just use a small steam box. Steam penetrates the wood, heats it and makes it flexible. When it cools and dries, the hydrogen bonding left behind keeps the wood in the bent shape. A small steam box is super easy to make.
Big ones build big wood boats...
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Jan 31, 2008, 05:07 PM
USA, IN, Carmel
Joined Feb 2006
I'm with CGBob! (The second line!)
Swift16 is offline Find More Posts by Swift16
Old Jan 31, 2008, 05:14 PM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
Thats what i do and its great for removing warps in wings and things, and i finally found a use for that household hand held steam cleaner the wife bought to clean the shower recess with
olmod is offline Find More Posts by olmod
Old Jan 31, 2008, 06:34 PM
Custom Course Wrecker..
Joined Dec 2004
<<So why is blue Windex with ammonia not recommended for plank bending,>>
I used it on the Dauntless build, and had ZERO problems with staining. I'll use it again. I think the staining thing is bunk.
ThrustTugKeith is offline Find More Posts by ThrustTugKeith
Old Jan 31, 2008, 07:07 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Is that a sense of humor I see CG Bob developing?
Kmot is online now Find More Posts by Kmot
Old Jan 31, 2008, 07:19 PM
Joined Dec 2004
420 TEE - The deal with not using blue Windex was strictly so their would be no chance for staining the wood. If you are going to epoxy and paint go to it, the blue Windex works great. The reason I know it will change the color of the wood (bass wood) was because it did so when I built the Midwest Peterborough canoe.
frankg is offline Find More Posts by frankg
Old Jan 31, 2008, 08:46 PM
master boat slacker
Joined Feb 2006
see i said so
Old Jan 31, 2008, 11:32 PM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
No, just 27 years of experience using those items to fix a lot of USCG equipment. A word of caution: Do not use the torch near the CHT or its vents.
