Old Aug 24, 2014, 12:26 AM
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Wow..she looks awesome wingman!!! Gona be a blast to fly,
falcon5 is offline Find More Posts by falcon5
Old Aug 24, 2014, 01:48 AM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
thanks guys!
got the stabs done. i wasnt able to get enough anhedral..but i got some...thats better than flatm i wanted to keep the stab setup simple and light. i used a piece of a old glass pushrod i had as the tube. both stabs and the tube weigh .9 oz. they are made from 2 layers of 6mm bonded together then shaped. making the vertical the same way
corsair nut is online now Find More Posts by corsair nut
Old Aug 24, 2014, 02:41 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
built the vertical..same manner as stabs...2 layers of 6mm depron laminated and carved. weighs 1.1oz with embedded carbon spar. i think that brings me up to about 16.5oz. theres still a number of small items to add plus wbpu and paint...i full expect 26 to 28oz by the time its all said and done.
Old Aug 24, 2014, 04:13 AM
justj's Avatar
United States, AZ, Chino Valley
Joined Feb 2012
Class
Where do I sign up for the class that teaches forming the body of that gorgeous beast?
J
justj is online now Find More Posts by justj
Old Aug 24, 2014, 09:18 AM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
classes start sept 1.....but tuition is pretty steep
Old Aug 24, 2014, 10:41 AM
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Man that looks gorgeous !
Awesome work.
meerkat13 is offline Find More Posts by meerkat13
Old Aug 24, 2014, 12:30 PM
justj's Avatar
Joined Feb 2012
Tuition
2 six-packs, a lipo and a case of depron?
It isn't the tuition, it's the commute [625 miles or so]!
From the looks of your progress you will have it flying for AITH?
Looking forward to seeing everyone there!
J
Old Aug 24, 2014, 01:24 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Brent-
Being so talented in so many areas, must be tough on you!
You mentioned earlier, that twin 60's might be your choice,, have you decided on what fans your going to run??
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 24, 2014, 01:59 PM
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Looking good Brent!
I haven't touched mine since last week... was in Vegas
AceMigKiller is offline Find More Posts by AceMigKiller
Old Aug 24, 2014, 02:18 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
the plan is to have it finished for aith....but im only going tues to thurs because of my sons birthday on friday.
cooler...while i think it was accually area ruled....h3 may have been thinking of jessica from roger rabbit
i dont drink beer but cherry coke on the rocks will do
Old Aug 24, 2014, 02:20 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
honestly im having 2nd thoughts about the 50mm fans i got...i ordered some 64mm fans to try and may end up going cn special and cutting them down to 60mm depending on amp draw ect. the thrust numbers arnt as good as i had hoped for the 50mm setups
Old Aug 24, 2014, 02:37 PM
Joined Jul 2004
When is AITH?
Old Aug 24, 2014, 02:41 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
oct 10th 11th
Old Aug 24, 2014, 05:41 PM
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
Originally Posted by CoolerByTheLake View Post
Brent-
They claim the curves were for improved airflow but I think your right about the female influence.
Tom
carr52 is offline Find More Posts by carr52
Old Aug 24, 2014, 07:53 PM
DELTAS RULE
tehachapi, CA
Joined Jan 2006
yeah its called area rulling...really helps at transonic speeds. one of the reason it was so fast on so little power
Build Log Shumate T-38 Talon 225% dhelms9138 Scratchbuilt EDFs 61 Aug 08, 2014 11:08 AM
Build Log T-38 Talon build thread Jeff Charlot Pusher Prop Jet Models 51 Sep 21, 2006 12:54 PM
Wanted: T-38 Talon or S3-A viking ttnissan Aircraft - Electric - Airplanes (FS/W) 0 Dec 25, 2001 02:10 PM
T-38 Talon or S3-A Viking ttnissan Foamies (Kits) 0 Dec 25, 2001 02:08 PM
