Old Jul 25, 2014, 06:22 PM
United States, CA, Lake Forest
Joined Jul 2014
battery charger for Hubsan x4 3.80 mah
Can the Traxxas EZ Peak charger be used to charge the 3.80 mah battery from the Hubsan x4?
dadaphil is offline Find More Posts by dadaphil
Old Jul 25, 2014, 09:54 PM
Canada, ON, Mississauga
Joined Oct 2011
The datasheet for the Hubsan x4 says that its battery capacity is 240mAh.
Since you did not post links to the Hubsan nor to the charger then I did not lookup the charger.
I do not know what connectors they have.
Audioguru is offline Find More Posts by Audioguru
Old Jul 27, 2014, 07:24 PM
Joined Jul 2014
The link for the charger: http://traxxas.com/products/parts/ch...hargerplus6amp
The link for the Hubsan x4 h107d: http://hubsan.com/products/FPV/H107D.htm
The battery has a micro Losi connector.
The battery is 380mah.
Old Jul 27, 2014, 10:42 PM
Joined Oct 2011
Your spec's for the helicopter show a higher capacity battery than the spec's I saw.
The helicopter battery is charged by the charging circuit inside the helicopter or inside its USB charging cable. It uses a 5VDC power supply from a computer (USB) or from a wall-wart adapter.
Why use the extremely expensive Traxxas charger that is designed to charge nearly anything?
The charger does not have a micro Losi connector.
Old Jul 28, 2014, 12:25 AM
Joined Jul 2014
Help! Hubsan x4 charger putting 4.67v? Battery blew up! ErnestRD Batteries and Chargers 20 Sep 11, 2014 01:06 PM
Sold 5 X 380 mah lipo for Hubsan X4 H107D (New) Pilot in MO Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jul 26, 2014 04:50 PM
Question Hubsan X4 - Best Multi Battery Charger? Sepster Multirotor Power Systems 8 Jul 24, 2014 01:41 PM
Discussion hubsan x4 only works with dead battery? HELP Pkitup Mini Multirotors 7 Apr 16, 2014 04:00 AM
Question Parallel cable for mini battery charger U816 U816A Hubsan X4 eaman Multirotor Power Systems 0 Dec 03, 2013 04:25 PM
