Old Apr 20, 2013, 06:55 PM
Life begins at 40
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
Build Log
Guillows Typhoon conversion
This is going to be my second rubber conversion. I will be using the SPMAR6400, 2x 1.5g servos and the motor, gearbox and prop from a UM P-51.
Enjoy
Nathan
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Apr 22, 2013, 05:40 AM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Looks good so far!
The 900 series kits make great conversions using the equipment you have selected.
I did the Trojan and Skyraider and have the Tiffie kit waiting.
Do check the wing incidence on the plan side view. I raised the trailing edge about 1/8" on my conversions to cut down on excessive climb under power.
I also made a spar joiner box that extends through the fuselage. The 1/16 x 1/8 spars were left long and they meet inside the box.
Glenn
glewis is offline Find More Posts by glewis
Old Apr 22, 2013, 08:10 AM
Life begins at 40
Canada, ON, Guelph
Joined Jun 2012
Thanks for the tips. I hope it won't be too heavy. I'm hoping for a weight of 40-45g.
Old Apr 22, 2013, 10:29 AM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
It will fly great at that weight. You will have more power than you need and I think it will cruise at about half throttle. Both my 900 conversions do and they are about that weight.
Old Apr 22, 2013, 02:45 PM
Life begins at 40
Canada, ON, Guelph
Joined Jun 2012
I hope so. Just finished covering the tail feathers. Will try to post pics soon.
Old Apr 22, 2013, 04:11 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
great to see this build.i have this kit waiting / spare for my other builds. are you going to have ailerons?
meltor is offline Find More Posts by meltor
Old Apr 22, 2013, 09:58 PM
Joined Apr 2013
i am currently converting a guillows 404 zero kit. i never did this before. i went with rudder and elevator. no aeilerons. i added extra dihedral to help stay level.i appreciate any advice. i was into rc planes 30 yrs. ago. alot has changed as far as size and weight of batteries.i had alot of experience with glo engines, but it seems electric is my new choice.
haniloginasim is offline Find More Posts by haniloginasim
Old Apr 22, 2013, 10:06 PM
Joined Apr 2013
guillows rc conversion
[any advice. please
Old Apr 22, 2013, 11:54 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
here you go .look in beavers conversion threads.http://www.rcgroups.com/forums/showthread.php?t=827861
Old Apr 23, 2013, 05:48 AM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Originally Posted by haniloginasim View Post
[any advice. please
Yes, I would skip the rudder and add ailerons.
Once the model drops a wing tip, the rudder will probably not bring it back= spin, crash.
Dihedral will help, but this is a fighter, might as well build it as one.
You can keep the rudder, but I would strongly suggest ailerons on that model.
Don't forget to mount everything as far forward as possible to get the proper cg.
Remove as much material as possible aft of the trailing edge. Hog out the middle of the formers with a sanding drum.
I cut new formers out of 1/32 sheet and laminate the tail surface outlines.
Glenn
Old Apr 23, 2013, 07:53 AM
Life begins at 40
Canada, ON, Guelph
Joined Jun 2012
Yes I will have ailerons. The servo leads are too short so I had to rig up a bellcrank system. I coverd the fusalage last night, and the total weight is 32 grams with battery. I am going to have a hidden pushrod system for the ailerons. I will post more pics tonight.
Old Apr 23, 2013, 05:39 PM
cpaine's Avatar
Canada, ON, Paris
Joined Mar 2007
me too! i was going to use the micro tiger motor... or champ guts
cpaine is offline Find More Posts by cpaine
Old Apr 23, 2013, 06:46 PM
Life begins at 40
Canada, ON, Guelph
Joined Jun 2012
Even more pics. I am having lots of trouble setting up the aileron bellcrank to the ailerons.
Old Apr 23, 2013, 07:43 PM
cpaine's Avatar
Canada, ON, Paris
Joined Mar 2007
It looks like you took some of the dihedral out?... I looked at the plans the other night and they were pretty cranked up for rubber power... I was going to do about half
Discussion UPDATED - Guillows Hawker Typhoon- Conversion (PZ gear) (Videos added) samson55 Scratchbuilt Indoor and Micro Models 32 Jan 10, 2011 01:51 PM
Discussion Guillows Typhoon 18'' conversion MadProf Electric Warbirds 29 Jul 17, 2010 03:54 PM
Build Log Guillows Typhoon Kit 906 Slow_Buzz Scale Kit/Scratch Built 34 Jun 21, 2010 12:42 PM
Build Log Guillows MK IB Typhoon build shin Scratchbuilt Indoor and Micro Models 3 Nov 14, 2009 05:27 PM
Sold Guillows BF109 and Typhoon kits, new never started planebldr Aircraft - General - Miscellaneous (FS/W) 3 Aug 13, 2009 12:18 AM
