Old Apr 08, 2014, 12:55 PM
Bigmic's Avatar
Norway, Sogn og Fjordane, Askvoll
Joined Aug 2012
Hmmm, but the led is flushing anyway...
Bigmic is offline Find More Posts by Bigmic
Old Apr 09, 2014, 09:17 AM
Bigmic's Avatar
Joined Aug 2012
Ok, after I put back to v049_r161 - it works fine!
Old Apr 09, 2014, 09:56 AM
Seattle, WA - USA
mark_q's Avatar
Joined Sep 2003
Excellent!
FYI - There is really no difference in stability between 161 and 207. 207 does have more features but 161 seems to be easier to tune.
Have fun!
Mark
mark_q is online now Find More Posts by mark_q
Latest blog entry: TBS Disco Gimbal Update
Old Apr 10, 2014, 12:51 PM
Blu-Core is my friend
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
I got the "RCTIMER 2-Axis Brushless Gimbal Controller v1.0" from UAV Objects.
worked great out of the box.... on the bench.
Not so good in the air. way to much vibration. I am going to change all the damper balls.
But, the question I have is about the GUI... I can get it to "connect" with green on the screen and it says connected. But there is no info coming in from the board.
I did notice i get a motion error. Do I need to disconnect the motors before using the GUI?
or is this a driver issue? I did the whole uninstall and delete drivers wo/ internet...
Later,
Gundy
Gundy is offline Find More Posts by Gundy
Old Apr 10, 2014, 02:10 PM
Seattle, WA - USA
mark_q's Avatar
Joined Sep 2003
Later,
Gundy
Generally, if there is no info update from the board, you are not fully connected. It is usually a driver issue.
Here is some info to help with the drivers (scroll down to "step 2")
http://www.itsqv.com/QVW/index.php?t...troller_Set-Up
As far as disconnecting the motors, this isn't necessary. There is a power up sequence you should use:
Starting without battery or USB plugged in AND the GUI software not open-
1. Plug in the battery and let the gimbal initialize
2. Plug in the USB cable
3. Start the GUI and click connect
Also, make sure the IMU connections are correct and solid.
Cheers,
Mark
Old Apr 11, 2014, 03:32 PM
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
Thank you!!
this is my weekend project.
Later,
Gundy
Old Apr 11, 2014, 04:13 PM
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
Here is the Bad video for the first test flight
bad (2 min 24 sec)
Here is the video from the mobius cam
No Vibration
mobi (2 min 2 sec)
Old Apr 14, 2014, 05:09 PM
Joined Dec 2013
Some critique please,
@mark i consider you a gimbal expert can you please tell me what is wrong with my gimbal??
Trucks (0 min 42 sec)
bbarb is offline Find More Posts by bbarb
Old Apr 14, 2014, 06:12 PM
Seattle, WA - USA
mark_q's Avatar
Joined Sep 2003
http://youtu.be/p61yS-Ebdzc
Looks good, I don't really see anything wrong? There is no Jello which is excellent The little jerkiness in the yaw rotation is not the gimbal but rather the camera or edit settings. I get this same jerkiness on my GoPro2 if I shoot at 30fps or less or if I use a crappy class 6 SD Card. It can also happen if you render in a format that YouTube doesn't like.
Did I miss something?
Mark
Old Apr 15, 2014, 01:58 AM
Joined Dec 2013
Mark
As expected, you didnt miss anything....
But this yaw issue is what i cant deal with and some vibrations i still have as well.
I shoot with a lumix lx7 at full hd at 60fps.
I shoot shutter priority at 1/60 auto iso to eliminate rolling shutter.
i have applied some unsharp mask in premier to deal with tiny vibrations i still get. I rendered the footage with premier at youtube full hd but i maintained the 60 fps. So premier shifted the footage to 720p. I used max render quality.
What am i doing wrong?
I also shoot whith image stabilazitaon activated on camera.
What am i doing wrong???
how stupid am i!! i am posting at a wrong thread..........i just spot it....sorry evryone.
Mark and any other please lets continue here:
http://www.rcgroups.com/forums/showthread.php?t=2147036
thanks and sorry
Old Apr 21, 2014, 09:31 AM
lakis21's Avatar
Greece, Makedonia Thraki, Nikiti
Joined Dec 2006
Hi all I just upgrade this gimbal to 3 axis with a gimbal yaw motor with slipring!!!!
Works really great!
The motor is the following:
GBM5208-SR(12N14P) DSLR Gimbal Motor With Slip Ring
http://www.rctimer.com/index.php?gOo...=13&image.y=17
After almost 10 months this gimbal still works great!
RC Timer Brushless Gimbal for GoPro, updated to 3 axis with GBM5208 SR12N14P With Slip Ring , AlexMo (3 min 13 sec)
lakis21 is offline Find More Posts by lakis21
Old May 14, 2014, 03:20 PM
United States, LA, Shreveport
Joined Jul 2013
RCTIMER 2-Axis Brushless Gimbal For GoPro / CCHD
10volts default settings on brugi 049 r77 soooo many flights with this gimbal.
Hexacopter nice day to fly. (4 min 51 sec)
AIRFED is online now Find More Posts by AIRFED
For Sale GoPro 2-axis gimbal for DJI Phantom frame Cuba59 Aircraft - Electric - Multirotor (FS/W) 6 Jul 08, 2013 06:23 PM
For Sale 2-axis gimbal for gopro ecokopter.pl Aircraft - Electric - Multirotor (FS/W) 0 Mar 21, 2013 06:01 PM
Sold Xaircraft 2 axis carbon gimbal - Perfect for GoPro 3 or 2 or 1! Sleepyc Aircraft - Electric - Multirotor (FS/W) 4 Jan 23, 2013 08:30 AM
Discussion Best 2 axis Gimbal for DJI 450/GoPro? FixedWing172 Aerial Photography 3 Jan 11, 2013 04:39 PM
New Product CLD 2/3-Axis FPV Gimbal for mini cameras and GoPro crd FPV Talk 9 Jul 13, 2012 10:42 PM
