Old May 05, 2014, 02:36 PM
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
Just got this pretty little quad any suggestions?
kelloggair is offline Find More Posts by kelloggair
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Just fly it.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old May 05, 2014, 02:43 PM
kelloggair's Avatar
Joined Mar 2008
Battery is charging as I post
Old May 05, 2014, 06:40 PM
kelloggair's Avatar
Joined Mar 2008
what an awesome little flyer, now to get used to flying with a screen
Old May 05, 2014, 06:51 PM
Slowly but Shirley
segroegt's Avatar
Canada, QC, Montreal
Joined Jan 2009
Congrats. maybe do the Jelly lens mode for a wider view. Good luck and Best Regards.
segroegt is offline Find More Posts by segroegt
Old May 06, 2014, 04:39 AM
United Kingdom, England, Nottingham
Joined May 2014
Interlaced footage?
New HC107C (SD) user here, and I've gone through the 107C and almost all of this thread already (about two dozen pages to go and many of the 101 posts.
One thing I've not seen mentioned or discussed anywhere, so I just have to chime in: I believe the H107D TX records interlaced footage. 720x240 isn't PAL or NTSC size, but from what I can gather searching (I can't find any original files to download) it does record in 50 or 60 fps. It's also an analog video signal. So, rather than upscaling, I believe the 720x240 recordings should be interlaced at half the framerate to get the native resolution. Question then still remains whether it is odd or even frames first (and whether that is reliable at all).
Shiari is offline Find More Posts by Shiari
Old May 06, 2014, 04:48 AM
Nevped67's Avatar
Australia Qld
Joined Jun 2010
Got mine today flys true ! Very happy now waiting for that batt pack of 5 lol !
got that stick on lens not bad at all
Nevped67 is offline Find More Posts by Nevped67
Old May 07, 2014, 02:44 AM
Australia, NSW, Allambie Heights
Joined Mar 2012
I just got mine and with the 500mah battery I'm getting 5mins 40seconds flight, isn't that a little to low, considering the ad says "about 7 mins" and thats with the provided 380mah lipo?
Bruno028 is offline Find More Posts by Bruno028
Old May 07, 2014, 03:46 AM
Joined Feb 2014
What does “a 7 min Flight Time” mean to you? If it means that the H107D is in the air (not sitting on the ground) for 7 minutes then there statement is correct.
The H107D can hover 5 to 10 cm of the ground for about 7 min. I refer to it as hovercraft mode, flying just above a surface. By doing that it will generate more lift at a low power consuming level.
When you fly around more then that, then its about 5 minutes.
Sjors Boomschors is offline Find More Posts by Sjors Boomschors
Old May 07, 2014, 03:59 AM
Joined Mar 2012
Ohk, thank for clarifying. I did 5 mins 40 sec of hover, not zipping around. ill try again and see what i get on the 380mah provided
Old May 07, 2014, 04:00 AM
I Void Warranties
goebish's Avatar
France, Aquitaine, Bordeaux
Joined Feb 2010
I got 4mn30 (flying, not only hovering) until the LEDs start flashing with the 380mAh, not much more with a 500mAh because of the additional weight, I could fly a little more but I prefer preserving the batteries. This is with props guard and lightened jelly lens.
goebish is offline Find More Posts by goebish
Old May 07, 2014, 04:20 AM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Brand new LiPos get a little better after a few charges.
dbacon is offline Find More Posts by dbacon
Old May 07, 2014, 06:12 AM
Joined Mar 2012
Confirm,
500mah - 5mins 36 seconds of hovering and slow flying around my room until first low battery led flash
380mah - 4mins 51seconds of hovering and slow flying around my room until first low battery led flash
Time to charge 380mah lipo = 51 mins
Old May 07, 2014, 02:13 PM
WonderDude's Avatar
Joined Apr 2014
Can't wait for mine to show up. I ordered it from Banggood on the 21st of April. Was hoping it would show up this week. But I'm betting I'll be waiting a little bit longer.
WonderDude is offline Find More Posts by WonderDude
Old May 07, 2014, 04:24 PM
Joined May 2014
I have a hubsan 107d but i loss the video signal in the transmitter, i change the battery but nothing happens.
Anyones Know how i can fix this problem?
donadir9 is offline Find More Posts by donadir9
Discussion hubsan X4 canopy repair viper1402 Mini Multirotors 5 Mar 24, 2013 11:40 PM
Discussion Hubsan X4 battery connector hazardpro Mini Multirotors 2 Jan 07, 2013 06:53 PM
Discussion Hubsan x4 Problems jm1289 Mini Multirotors 2 Jan 05, 2013 07:25 AM
Discussion The Hubsan FPV X4 -(No.H107D) - What Happened?! JHawk19 Mini Multirotors 4 Dec 31, 2012 11:49 AM
Discussion The Hubsan FPV X4 -(No.H107D) hubsan Mini Multirotors 35 Dec 27, 2012 09:34 PM
