Old Dec 16, 2012, 07:36 PM
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Joined Mar 2005
Ringmaster Jr Questions ???
I picked up a nice Ringmaster Jr. from Ebay.
It looks to be unflown (I think the person that built it, could not have flown it, as it appears they forgot to install the leadouts-so I will have to perform surgery).
The engine is an O.S. 20 FP R/C. I have a muffler on order, and will be attempting to order a venturi for it.
I have several questions:
How long should the lines be?
What gauge should the lines be?
What is a good propeller size?
Is there anything about this particular model that should be done, prior to flying it (i.e. areas that need re-inforcement, etc.).
Thank you all in advance.
Ah Clem is offline Find More Posts by Ah Clem
Old Dec 16, 2012, 07:54 PM
LA Ming's Avatar
Poteau, OK
Joined Nov 2008
1. Typically, the line length for the smaller displacement engines (.15's .19's/etc.) Is 52 1/2'.
2. .015".
3. Pass: I don't know a thing about OS .20's.
4. Pass: Not intimately familiar with the airplane in question.
Oh well... that's only 2 out of 4... but it's a start!
LA Ming is online now Find More Posts by LA Ming
Old Dec 16, 2012, 08:07 PM
Ah Clem's Avatar
Joined Mar 2005
Thank you very, very much for the info!
It is greatly appreciated!
Old Dec 16, 2012, 08:17 PM
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
That's twice as much engine as the tiny little thing will fly properly with. It should have a modren 0.10, or a classic era iron engine, other than a TeeDee, in an 0.15 size.
If flown on that engine, it will want to fly at about 90 mph, so if that's good with you, use .015 by 60' steel.
I think it will slow down enough, if you use an 11/4.
I have to imagine the nose is far too weak after the surgery to open up the mounts that large. Make sure no specxtators are within a couple of hundred feet.
Kiwi
The Kiwi is online now Find More Posts by The Kiwi
Old Dec 16, 2012, 09:48 PM
gcb
Joined Sep 2008
Don't blame the builder for the engine size, the plans show a Fox .25 schnuerle in it...I have NO idea why.
I have an Enya .09 in mine.
George
gcb is offline Find More Posts by gcb
Old Dec 17, 2012, 10:52 AM
Old Timer
The Kiwi's Avatar
Joined Jun 2010
I had a K&B 19 GH back in 1957 that I didn't have any current model plane to attach it to. I did "know better", and did shorten the nose, beef up the motor mounts, etc, but it was still nose heavy, and very fast. On its first flight, that Ring Jr ended its brief life with a classic figure 9.
Covered in silk that stayed more or less intact, I don't think a single wing rib survived, but the end was also classic, a "bag of splinters" was all I really had left.
Kiwi
Old Dec 17, 2012, 11:02 AM
Ah Clem's Avatar
Joined Mar 2005
Well,
Perhaps I will leave the R/C carb on it, and throttle it back. I certainly don't want an overly fast or unsafe airplane.
Also, somewhere I have a Gilbert Thunderhead .11 (which I don't think I ever ran), so that is an alternative.
Thank you all for your comments. Your assistance is greatly apprecieated.
Old Dec 20, 2012, 11:15 AM
northernlightsfl's Avatar
Tok Alaska
Joined Aug 2005
Ringmaster JR
Back in the 60s I had one that I flew with a McCoy 35 on it flew on 60 foot lines .018.
Was at the time my favorite combat airplane.
FAST was not the word but FUN sure was.
This carried on with several after the first way into the 90s then I got too old to keep up with the speed
northernlightsfl is online now Find More Posts by northernlightsfl
Old Jan 03, 2013, 05:59 PM
United States, TX, Spring
Joined Jul 2010
Here's a little control line humor (not my Ebay item, btw):
http://www.ebay.com/itm/Sterling-Jr-...item2a27c8885f
Get it?
Gnu4FF is offline Find More Posts by Gnu4FF
Old Jan 03, 2013, 06:34 PM
Ah Clem's Avatar
Joined Mar 2005
Top Flite performance?
Old Jan 06, 2013, 05:38 PM
Jim Kraft's Avatar
The middle of Kansas
Joined Jan 2005
I learned to fly inverted and do lazy 8's with a Jr. Ringmaster back in the 60's with a Fox 15 slant plug. I still have the engine, and it still runs great. My Jr. was a little on the heavy side, but it didn't fly to bad. I flew the same engine on a Shark 15.
Jim Kraft is offline Find More Posts by Jim Kraft
Discussion Ringmaster Jr and Baby Plans Pinecone Control Line 49 May 03, 2012 07:33 PM
For Sale VINTAGE STERLING RINGMASTER UC Kit rickj12 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 29, 2012 08:54 AM
Yippee! My Jr. Ringmaster..... Laramie Control Line 20 Jul 05, 2010 04:42 PM
Help! Ringmaster JR by Sterling ronrange Control Line 4 Dec 06, 2009 11:16 PM
Sold Vintage Sterling Models Ringmaster Jr. mechengineer03 Aircraft - Fuel - Airplanes (FS/W) 4 Jul 12, 2008 03:03 PM
