Old Jun 16, 2012, 12:07 PM
imacswd's Avatar
Newark, Ca
Joined Jun 2005
Help!
J/r 9303
I have a 2.4 J/R 9303 which has been working perfectly with my Heli's. I'm changing to 2.4 in my Sailplanes and have run into a problem with the Collective/Flap gimbal. As I pull the flaps down at the lowest position the flaps go to neutral on there own.
Note; I have tried to adjust the travel to correct and it did not have any effect.
My question is there a way to electronically adjust the calibrations? I think it will only take a click up on the calibration to correct.
imacswd is offline Find More Posts by imacswd
Old Jun 18, 2012, 08:20 PM
United States, CA, North Highlands
Joined Aug 2004
Have you checked to make sure you do not have some mixing programed in that is causing the issue?
Broncomech is offline Find More Posts by Broncomech
Old Jun 18, 2012, 08:57 PM
59 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
With any kind of issue like this, the first step is always to leave the receiver turned off and look at what is happening in the transmitter by viewing the monitor screen. The second is to make sure you do a data reset on the model memory to eliminate any mixes or other settings.
If you then see a glitch, it probably means a bad pot that will need to be replaced. That means a trip to the service center.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jun 19, 2012, 12:05 AM
that's gonna hurt...
USA, CA, San Jose
Joined May 2005
Should be a simple fix. Go to the Butterfly menu - on the bottom left - towards the middle is a menu item - SPOI STK - change the setting from 0 to INH. This shold fix your problem.
Bruce
blewis01 is offline Find More Posts by blewis01
Old Jun 26, 2012, 07:31 PM
imacswd's Avatar
Newark, Ca
Joined Jun 2005
Thanks for the info, I'll give it whirl.
Old Jul 03, 2012, 06:17 PM
imacswd's Avatar
Newark, Ca
Joined Jun 2005
OK, You are the Gooroo of the 9303. That did it. Thank you blewis01 for getting me on the right track.
Have a great Holiday, looking forward to doing some gliding this week. )
Discussion J r service jerryshape Sailplane Talk 5 May 10, 2012 05:28 PM
Sold JR 9303 with R 700s plus dugless Aircraft - General - Radio Equipment (FS/W) 3 Apr 28, 2012 03:55 AM
Sold ** look** 9303 2.4 j.r. Radio. matthew james Aircraft - General - Radio Equipment (FS/W) 5 Sep 22, 2011 10:12 PM
Found j.r. fm 6102 radio or something thats 6 ch j.r. radio matthew james Aircraft - General - Radio Equipment (FS/W) 6 Sep 11, 2010 01:52 PM
Wanted JR 9303 TX & R 770 REC gmony Aircraft - General - Radio Equipment (FS/W) 3 May 15, 2006 09:34 PM
