Old Jul 17, 2010, 09:24 PM
Joined Oct 2009
Just finishing up the Eflite F-86..
And have a question.. should I cut the airflow hole in the bottom for the ESC? I do live in Dallas and temps are over a hundred degrees outside.. however I have never had an over heating problem with the Habu I yanked it out of.. I don't fly full throttle all the time either.. Any last minute suggestions before I maiden it tomorrow? I did put a towhook in it with no problem.. right at 2/3rd from the nose to the CG.. Thanks in advance..
deanguy is offline Find More Posts by deanguy
Old Jul 17, 2010, 09:29 PM
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Cut the hole, not worth the risk. 100+F is hot.
If it bugs you that much cut a smaller hole then the instructions recommend.
bmiller is offline Find More Posts by bmiller
Old Jul 17, 2010, 09:35 PM
Joined Oct 2009
Thanks man ... That's what I figured... It's good to have help at the last minute when you are undecided on something.. that's why I love this forum!
Old Jul 17, 2010, 10:12 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yes better to have some cooling ...i have even put holes in my intakes ,i glue some screen over it to prevent FOD, then i put the esc right where the hole is . the intake will suck some air over it .of course you needa a hole or opening in front so it can bring some air in too .gear door or a naca shaped scoop.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jul 18, 2010, 12:35 PM
Joined Oct 2009
Anybody have to add weight and move the battery as far froward as possible to get he CG right? Im might have over done the glassing of the towhook.. just to make sure it wouldn't come loose.. Im about 5.5 inches from the leading edge of the wing..
Old Jul 18, 2010, 05:20 PM
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
I added 1/2 oz up front along the inake tube against the fuse, it helped alot.
ATIS is offline Find More Posts by ATIS
Latest blog entry: maxford Nieuport 1/5th Scale
Discussion Skymaster F-86 1/6.5 scale set up Chris Nicastro Electric Ducted Fan Jet Talk 93 Sep 06, 2013 01:22 AM
For Sale Eflite F-86 Sabre SMITHB Aircraft - Electric - Jets (FS/W) 4 Jun 09, 2010 11:25 PM
New Product Just saw this F-86 Skyblazers EDF kuczy Foamy EDFs 0 Dec 08, 2009 10:08 PM
Rave Just another big F-86 Horst Kuehn Electric Ducted Fan Jet Talk 47 Sep 15, 2005 05:12 AM
Help! Just finishing up Corona build farscape105 Electric Heli Talk 9 Jul 14, 2005 10:40 AM
