Old Apr 22, 2001, 11:48 PM
funflyer is offline
Find More Posts by funflyer
Fun Flyin
Escondido, CA, USA
Joined Mar 2001
ZAGI batteries. I want to make my own, Does anybody know how?
I was wondering if i bought 9 sub c 2700 nimh batteries if i could make my own pack. I dont know what the volts are but i think they are aound 1.5 volt per battery. So if i had 9 of them it be around 9.6 volts for the speed 400 motor. If i soder them side by side i might be able to build a really AWESOME battery. This would be a 2700 NIMH battery, Thats 1000 MaH longer then the Big 8 cell battery that zagi cells. So does any body know if i could make my own battery using nine sub c 2700 nimh cells? Also does anybody know the height and weight of these size cells. I thought these were about the same size of the zagi sanyo cells.
funflyer is offline Find More Posts by funflyer
Old Apr 22, 2001, 11:57 PM
elad10 is offline
Find More Posts by elad10
Port Orchard WA USA
Joined Mar 2001
you will need to soder the batterys togeather. Pos to neg. I'd use eight, for a total of 9.6 volts, as the batterys are rated for 1.2 volts each. check on the overal weight though. Good luck.
elad10 is offline Find More Posts by elad10
Old Apr 23, 2001, 01:22 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Originally posted by funflyer: I was wondering if i bought 9 sub c 2700 nimh batteries if i could make my own pack.
Yes, but it would be too heavy for your Zagi and make it fly like a brick.
Small storage cells are 1.2 volts each. 9x1.2=10.8 volts.
TRy it and see how it works.
Probably if you know your way around a 40 watt soldering iron. See the FAQ for information on building packs such as you describe.
Sub-Cs are 1.690 in height and .910 in diameter. They weigh 2.2oz for NiMh and 2.09oz for many Nicads. Batteries that are normally used in Zagis are "A" and "AA"-sized.
Mark Wood is online now Find More Posts by Mark Wood
Old Apr 23, 2001, 09:20 AM
funflyer is offline
Fun Flyin
Escondido, CA, USA
Joined Mar 2001
What if i only use 8 of these cells, Would it still be too heavy
Old Apr 23, 2001, 09:24 AM
Andy W is offline
Find More Posts by Andy W
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Yes, much.
..a
Old Apr 23, 2001, 09:34 AM
funflyer is offline
Fun Flyin
Escondido, CA, USA
Joined Mar 2001
Are nicads less heavy compared to nihm batteries? What do you think about 8 1800 nicad sub c cells? Would they work better?
Old Apr 23, 2001, 11:34 AM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Funflyer:
Forget the Sub-Cs for a Zagi. 8x"A"-sized packs at the most. K?
mw
Old Apr 23, 2001, 04:49 PM
thin wing is offline
Find More Posts by thin wing
ireland
Joined Apr 2001
try 1400 ae nicad 32 grams each same as 800 ar 9 should work equal to 8 * 800 ars for voltage recharge 2c
also 1700 au use 10 to keep amps below 5 amps or use short bursts of power internal resistance relitivly high max amps recommended 10 amps weight 35 grams
have used these types suycessfully on s400 for long flights recharge below 2c
theses battery add very litle weight to increase flying time power density in excess of 40 to 1
sub c power density 30 to 35 to 1 generally regire two s400 engines to lift up and larger wing surface such as graupners new twin jet foamy would work well on 8 or 10 sub c nicads and pobably ok on 10 nimh
large battery packs also start to remove bounce factor in foamies and repair time and cost starts to kick in
s400 have fun world wide
hope this helps
thin wing is offline Find More Posts by thin wing
Does anybody know how to kill hornets? Old Man Life, The Universe, and Politics 43 Aug 02, 2009 12:54 PM
does anybody know how to remove topflite econocote from foam flyer10 Beginner Training Area (Aircraft-Electric) 2 Feb 12, 2007 01:24 PM
want to make my own USB cable nakman8 Simulators 8 Nov 01, 2005 11:50 AM
i want to make my own cable lttakas Simulators 7 Jun 09, 2004 11:39 AM
ZAGI batteries, I want to make my own. Does anybody know how? funflyer Foamies (Kits) 2 Apr 23, 2001 09:18 AM
