Old Apr 15, 2015, 06:24 PM
Fredriksson is offline
Find More Posts by Fredriksson
Just having fun
Fredriksson's Avatar
United States, KY, Hopkinsville
Joined Feb 2008
Question
Spektrum with Eneloops charging question - keep stock charger plugged in?
I have a Spektrum DX7 (not the DX7 S) that I purchased used about 2 years ago. The battery is the stock 9.7 volt 1500mAh NiMH battery. I keep the battery charged with the stock Spektrum110mA charger. The battery has gone bad and will not hold a charge very long. It ran out of power on me this past weekend after about 5 hours having it on only during flights which totaled around 2 - 1/2 hours of actual flight time.
I have ordered 8 Sanyo Eneloop NiMH AA 2000mAh batteries to replace the stock battery and a Radio Shack style battery holder. I will use the connector from the stock battery to plug this new battery set into my DX7 transmitter.
My question is how I keep the batteries charged. I have been keeping the transmitter charger plugged in all of the time. I unplug it to go flying and then plug it back in when I get back home. I fly each week or every other week. The unit is plugged in 24 hours a day between flying sessions. Is this what caused the stock battery to go bad? Will it be OK if I do this with the Eneloops? If this is not OK, what is the best practice to use for occasional flying that ensures that the TX batteries are ready to go with a full charge when I go flying?
Thanks.
Freddy
Fredriksson is offline Find More Posts by Fredriksson
Old Apr 15, 2015, 06:32 PM
Ira NZ is online now
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Yeah, should be fine to leave it plugged in. You're going to be charging the new ones at an even slower rate than the stock batteries. It's not the ideal solution, which would probably be to plug it in for a day or two after flying and then unplug it. But you're talking still a lifespan of likely years not ruining them in months.
Ira NZ is online now Find More Posts by Ira NZ
Old Apr 15, 2015, 06:58 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
IMO, I'd go with the "plug it in for a day or two after flying and then unplug it."
Since the eneloops have an extremely low self discharge rate, the potential for excess current is high and that excess energy has to be dissipated as heat. How much will that degrade the pack...got me. Some recommend a C/40 trickle rate.
hoppy is offline Find More Posts by hoppy
Old Apr 15, 2015, 07:09 PM
AA5BY is offline
Find More Posts by AA5BY
AA5BY's Avatar
East Texas
Joined Aug 2007
To leave on a charger, it should have been one that charges and then shifts to trickle charge.
With the eneloops, charge and then remove from the charger as they will remain charged between flying sessions.
AA5BY is offline Find More Posts by AA5BY
Old Apr 15, 2015, 07:19 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
+1
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Apr 15, 2015, 07:23 PM
Just having fun
Joined Feb 2008
Thanks for the advice. It is appreciated.
I forget that the eneloop's hold a charge for a long, long time. The old battery lost charge in around three weeks of being unplugged.
Since these eneloops will hold a charge, I will opt for the "plug it in for a day or two after flying and then unplug it." I am sure my run time on the TX will be much improved. And the unplugging part will not be a problem.
Freddy
Old Apr 15, 2015, 08:08 PM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
For starters the endloops are 2300 mah opposed to the 1500mah loose the charge Spektrum batteries,so all being equal you start with 25% more capacity.
The Tug is offline Find More Posts by The Tug
Old Apr 15, 2015, 11:47 PM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
The Eneloops you want to use in a TX are rated at 1900mAh "minimum", 2000mAh typical. There are Eneloop Pro XX cells with 2300-2500mAh capacity, but they have a higher self-discharge rate and they're only good for about 500 charge-discharge cycles vs. 1500+ cycles for the standard Eneloops.
Pete
PGR is online now Find More Posts by PGR
Old Yesterday, 01:43 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Most reputable brand NiMh are now low self discharge, Enerloop lost hold of that marketing bit a long time ago.
I use Grundig NiMh of 2300mAh and have old Futaba M chargers of 50mA rate. They stay plugged in continuous to my Tx's. My Grundigs are well into 3rd year and get hard use as well. My Tx is left on once or twice a year to discharge to its Low voltage alarm and still now - I get over 9hrs before it sounds. My alarm is set with still good margin left.
For when I need quick charge - I have a Prolux Smart Nixx charger that whacks out near 1A - not recc'd to leave connected past its auto point as most Tx sockets are not designed for such loads.
1500 cells on a 110mA charger ? I'm not surprised if you left plugged in continuous that your pack is now damaged. At 1/10th rate you are advised not more than 14 - 15 hrs. Your charger although less than 1/10th is still in the range that you should not leave continuous.
My way to calculate is : battery capacity / charger rate gives perfect charge time, which is impossible. Therefore add ~30% to the time ... up to 40% depending on charger etc,
The only continuous rate I would be happy with on your new batts of 2000 mAh would be similar to my 50mA chargers. If 100mA - then I would calculate the charge time needed or best is invest in a NiMH delta peak auto charger such as the Prolux.
Nigel
solentlife is offline Find More Posts by solentlife
Old Yesterday, 10:28 AM
James_S is offline
Find More Posts by James_S
United States, WA, Woodinville
Joined May 2014
Most say they are, some are quite good, many are crap. Eneloop are the only ones I've seen that are made in Japan, the rest are China. Given the cost difference is less than 20% in most cases I use Eneloop almost exclusively. I've been burned too many times trying to save a bit of money buying something cheaper only to have to go back and buy the better one anyway. I can go buy a pack of Eneloop AA's and KNOW they will perform as specified, why chance it?
James_S is offline Find More Posts by James_S
Old Yesterday, 10:32 PM
PGR is online now
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
Originally Posted by James_S View Post
Eneloop are the only ones I've seen that are made in Japan, ...
Beware: Some generation-4 Eneloops are made in China now and they're not as good as the Japanese ones. But please note that some generation-4 Eneloops are still made in Japan and they're better than ever, so don't believe the rumor that all gen-4 Eneloops are junk. Unfortunately it's impossible to tell the Japanese Eneloops from the Chinese version without reading the small print on the cells, but the Japanese cells do say Made in Japan on them and the Chinese cells do say Made In China.
Probably the most comprehensive discussion on the topic can be found HERE IN THE CANDLEPOWER FORUM. There are even photos of the Japanese and Chinese cells in posts # 158 & 160.
Pete
Sold T Plug Parallel Charging Board for B6 type chargers and others twco Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 29, 2014 06:17 PM
Discussion Parallel Charging Facts - Part 2, Charge Applied, then Batts Plugged In FredYates Batteries and Chargers 18 Sep 17, 2014 11:05 AM
Discussion Charging batteries with stock Syma charger E_T Batteries and Chargers 0 Aug 29, 2014 08:22 AM
Discussion Basic question regarding plugging in battery to charger venton Batteries and Chargers 3 Jan 30, 2014 06:03 PM
Discussion Charging Eneloops with Dewalt charger DRC-Wartex Batteries and Chargers 1 Jan 05, 2009 10:35 PM
