Old Mar 28, 2015, 05:40 PM
tdilwo is online now
Find More Posts by tdilwo
Joined Oct 2014
Leaving a lipo charged
Hi all,
I have some lipos that I have had sitting around for a while fully charged. I realize that this is a big nono but I dont really have a choice because my charger does not have the ability to take the batteries down to storage voltage. My question is how much much of a change in performance will this make? I will be pretty mad if I wrecked $120 worth of batteries.
tdilwo is online now Find More Posts by tdilwo
Old Mar 28, 2015, 05:44 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Depends on the specific battery and storage temperature. Some survive such abuse, some don't. If you have the means to test internal resistance, you can tell straightaway whether you've damaged your packs.
"I dont really have a choice because my charger does not have the ability to take the batteries down to storage voltage."
You do have a choice. http://www.myrcmart.com/rcx-3in1-bat...ng-p-4767.html
mrforsyth is online now Find More Posts by mrforsyth
Old Mar 28, 2015, 05:54 PM
Joined Oct 2014
Thank you. They are the Turnigy A-Spec 4s batteries with the very high c rating. I odnt know if you know anything about them in particular. What I meant by i dont't have a choice is that it hadn't really occurred to me until today and my current setup doesn't allow me to discharge them.
Old Mar 28, 2015, 06:54 PM
bob93447 is offline
Find More Posts by bob93447
Joined Sep 2006
Can you run them on the bench? A few minutes run time can bring them into storage voltage. But take the time to hook up a voltmeter so you don't discharge them below about 3.8v/cell.
bob93447 is offline Find More Posts by bob93447
Old Mar 29, 2015, 03:13 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Unfortunately very high C ratings are usually WORSE for degradation. And it obviously depends and how long "a while" is. Couple of days, not much problem, couple of months, very likely a problem.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 29, 2015, 07:42 AM
Joined Oct 2014
Steve
Yeah unfortunately it has been closer to a couple of months. What kind of ill effects can I expect?
Old Mar 29, 2015, 08:58 AM
So. Cal.
Increased internal resistance and reduced capacity. This will result in less available power and shorter flight times.
Old Mar 29, 2015, 12:39 PM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
I have to argue that it's a matter of reduced usable capacity at the current loads we demand to spin props and rotors. And for the sake of this argument, I have to define capacity as the ability of a pack to provide adequate voltage at those high current loads.
BUT:
It's been my experience that the pack capacity at reduced loads remains largely unaffected. I say this because I have a long history of re-purposing my LiPo packs once the voltage drop at a required load becomes excessive which, btw, is the #1 symptom of high IR. My most common use for old packs is external power for camera strobes, LED video lighting, and camcorders. Packs that are no longer up to the task of spinning props will usually serve well in that new role; often for several more years.
And charge/discharge test cycles at the reduced current they now need to supply indicates that they haven't lost the ability to store energy. They've simply lost the ability to release the energy at high rates.
Pete
PGR is online now Find More Posts by PGR
Old Mar 31, 2015, 08:09 AM
Joined Oct 2014
Thanks all for your replies,
Am I in any danger if I use them? Ie any danger of a lipo fire
Old Mar 31, 2015, 08:32 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You can't say there is "no danger" of a lipo fire as that's always on the table, but the chances are very low. Store and charge in a firesafe place and enjoy.
hoppy is offline Find More Posts by hoppy
Old Mar 31, 2015, 11:07 AM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
I rarely use the storage feature of my charger. My flight time is such that the batteries end very close to the storage voltage then I just put them away until next use.
600Bob is offline Find More Posts by 600Bob
Discussion Why NOT leave LiPo's charged? daved20319 Multirotor Talk 7 May 25, 2014 10:16 AM
Discussion Can I charge lipo's at 1/10C and leave it on marcwv Batteries and Chargers 9 Apr 06, 2007 04:22 PM
Discussion does leaving a Lipo on charger drain the charge ?? X3n0 Batteries and Chargers 22 Aug 23, 2006 01:47 PM
how long can you leave a charge in a lipo ? mhale71 Batteries and Chargers 11 Mar 02, 2005 01:36 PM
Charging lipo's from li-ions / leaving the hood down! DeaninMilwaukee Batteries and Chargers 13 May 16, 2004 10:00 AM
