Old Feb 02, 2015, 06:56 AM
joao.macarrony is offline
Find More Posts by joao.macarrony
Joined Feb 2015
Question
How to charge multiple batteries?
Hi! My name is Joćo and I'm from Portugal. This is my first thread in this forum, and since I'm a beginner, will ask you a quastion.
So I bought my first quadcopter online in Banggoods "WLtoys Skylark V636 RC", and I bought 2 extra batteries as well. My doubt is how can I charge 3 batteries at the same time with the same charger? Is it possible? This is the battery: http://www.banggood.com/WLtoys-Skyla...-p-949193.html
In the attached files there is a system where we can charge them at the same time. How can I find the cable do attach the 3 batteries at the same charger? Is the connector of the battery (the little plastic thing at the end of the cable) universal?
If you could answer my noob questions I will be grateful!
Best Regards!
joao.macarrony is offline Find More Posts by joao.macarrony
Old Feb 02, 2015, 08:13 AM
Joined Feb 2015
Does anyone knows how to move this thread for the right place? I posted it in the wrong place...
Old Feb 02, 2015, 08:42 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
your in the right place, but more info is needed.
A link to your copter and charger would help.
tacx is offline Find More Posts by tacx
Old Feb 02, 2015, 09:28 AM
Joined Feb 2015
The model was removed from the online shop. But this link is a good review of the model made by an user from this forum. http://www.rcgroups.com/forums/showthread.php?t=2232133
I don't have any information about the charger, I'll try to find it somewhere in the internet. Thank you
Old Feb 02, 2015, 09:45 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Here you go: http://www.amazon.com/Charging-Cable...charging+cable
Free shipping too.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Feb 02, 2015, 01:33 PM
Race Miata is online now
Find More Posts by Race Miata
Race Miata's Avatar
Vancouver, Canada
Joined Nov 2004
If you use stock charger to parallel charge 3 packs together, charge time will be roughly tripled so you don't really save any time.
Race Miata is online now Find More Posts by Race Miata
Old Feb 02, 2015, 02:49 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Best Regards!
May I suggest you read this: http://www.tjinguytech.com/charging-how-tos
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Feb 02, 2015, 07:21 PM
Joined Feb 2015
Thank you all for your help, I saw that cable on Banggood but wasn't sure if the batteries could attach on that.
Thank you for the support, regards!
Old Feb 02, 2015, 08:03 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
I didn't see one on Banggood with the JST plugs you need. The one I linked to above is the one you want.
mw
Old Feb 08, 2015, 07:34 AM
Joined Feb 2015
charger for parallel charging
Just one more doubt guys. For charging in parallel 3 batteries of lithium with 3.7 volts and 730 mAh, using a jst plug cable wich charger do I have to buy? Will I need a charger whose output should be 11.1 volts (3.7*3) right? So I have to buy one of these http://www.banggood.com/Wholesale-IM...r-p-46220.html ? Can I select the output voltage to 11.1? And this usb charger? Does this has energy enough to charge 3 batteries? http://www.banggood.com/3_7V-Lipo-Ba...-p-917170.html
I hope you could help me guys, sorry for bothering. Regards
Old Feb 08, 2015, 08:59 AM
USA, GA, Marietta
Joined Aug 2005
When charging in parallel you do not add the voltage, it remains the same.
You do add the current. Therefore when charging three 1S 730mAh batteries in parallel the charger is set to 3.7V (1S) and 2.19A.
Please read the article I referenced in post #7.
Yes the IMAX-B6 is an adequate charger for this requirement.
No I do not think the USB charging cable you referenced will charge three 1S 730mAh batteries. At least I would not recommend it if for no other reason that you cannot tell what it is doing. The IMAX-B6 will tell you the battery voltage, the charging current and the ma returned to the pack during the charge.
Glen
Old Feb 08, 2015, 09:02 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
No, no ! The batteries are connected in PARALLEL. That means you still charge them as a bigger 1S 3.7V battery. So you want a charger that will charge at 3.7V but at a higher current, 3 x 730mA or more, i.e. around 2.2A.
The B6 should do it o.k. But the USB thing only charges at 0.5A so it would take about 4 to 5 hours to charge 3 batteries....if you don't mind waiting that long I guess it would work.
Steve
- typing too slow again .
slipstick is offline Find More Posts by slipstick
Old Feb 08, 2015, 09:40 AM
RyanZ is offline
Find More Posts by RyanZ
Joined Nov 2011
Not trying to hijack the thread, but I'm attempting to do something very similar. I bought multiple batteries for my LaTrax Alias (1s 650mah lipos with a jst connector) and would like to charge them all at once with my Onyx 235 charger.
I'm not sure exactly what I need, but I do know the Onyx 235 has no jst...only a balancing port for the board that came with it and banana clips.
RyanZ is offline Find More Posts by RyanZ
Old Feb 08, 2015, 09:48 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
I'm not sure exactly what I need...
You need one of these parallel charge harnesses: http://www.progressiverc.com/paralle...rge-cable.html
Simply connect to the main 4mm output of your charger, connect all of your cells, set charger to 1S lipoly, set charge current, and start charging.
Note that when connecting multiple cells in parallel, you're effectively creating a larger capacity cell. e.g. - If you connect six of your 650mAh cells in parallel, you now have a 3900mAh, single cell battery. 1C charge would thus be 1S, 3.9A.
Read here if you'd like to learn more: http://www.rcgroups.com/forums/showthread.php?t=932319
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 08, 2015, 11:10 AM
RyanZ is offline
Joined Nov 2011
Thanks a ton for the help. I'll add a wrinkle to the equation...don't think there's any way to fix this, though.
I got a deal when I bought my quad and it came with two generic 700mah batteries. I assume I can't plug in my 650mah and 700mah batteries at the same time and get a full charge on everything, right? Thanks again for the help!
Help! Charging JJRC H8C multiple batteries fredPT Multirotor Power Systems 3 Nov 11, 2014 03:57 PM
Help! Charging Multiple 1S Batteries Sir Raleigh Batteries and Chargers 2 Sep 24, 2014 02:12 PM
Question I have no idea how to charge multiple batteries. billy0569 Batteries and Chargers 11 May 26, 2012 09:30 PM
Discussion How do you charge multiple lipo batteries fonz316 Batteries and Chargers 7 Nov 20, 2008 09:42 PM
How do I charge multiple batteries? RobinBennett Beginner Training Area (Aircraft-Electric) 26 Jun 14, 2004 02:04 PM
