Old Sep 15, 2013, 07:54 AM
tomrandall is offline
Find More Posts by tomrandall
United Kingdom, England, Blackpool
Joined Sep 2013
Help!
A few questions about a DC motor
Hey guys
I'm intending to make a little 30cm boat and was considering this as a motor for it. I just have a few questions about it.
http://www.hobbyking.com/hobbyking/s...erCooled_.html
Would this be a suitable motor for this size boat? Has anyone used one of these before? Would a 30A ESC be suitable for this motor? What sized mount would i need? And what prop size would be appropriate and with how many blades?
Thanks =)
tomrandall is offline Find More Posts by tomrandall
Old Sep 15, 2013, 12:59 PM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
It seems a LOT of motor for a very small boat. With the almost total lack of information in the link, I would be strongly tempted to look elsewhere. Preferably somewhere where they are prepared to give clues over and above size and weight and vague mentions of "standard mounts". BTW, strictly speaking, its not a DC motor, but a 3 phase AC type, the ESC chopping the DC to supply the "phases".
What type of boat? How much performance? Which bit of water do you intend to go on? (Fleetwood, Fairhaven and St Annes lifeboat station are all salt, Stanley Park isn't, but involves a lot of walking).
mfr02 is offline Find More Posts by mfr02
Old Sep 15, 2013, 01:03 PM
Joined Sep 2013
Ah right, I see. Probably a mono hull and it doesn't need massive performance, just a good speed and handling. I'll probably use it on the canal mostly.
Old Sep 16, 2013, 01:32 AM
SoloProFan is offline
Find More Posts by SoloProFan
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
A Speed 280 brushed motor will be power enough, even when run on 4.8 volts.
Here's a vid of my 40 cm boat running on that motor on 6 volts.
Second testrun of my small SAR boat Vegesack (1 min 52 sec)
SoloProFan is offline Find More Posts by SoloProFan
Old Sep 16, 2013, 01:50 AM
Joined Sep 2013
Your boat seems to have a fair speed on it. Would a 3.2kg AS-16 servo be strong enough for that?
Old Sep 16, 2013, 02:52 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Thanks. I'm pretty happy with the performance as well.
3.2 kg is the pull force I assume? Is that a 9 gram servo (servo weight)? If so, it should be ok, in the Vitality FT007 speedboat, where more forces are acting on the rudder, a small, similar size servo does the job just fine.
In my boat there is actually a full size servo, so 40 grams, 5 kg pull force, but that's only because micro servos were not available so easily back in the days when it was built.
Old Sep 16, 2013, 03:58 AM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
12-15mm prop, 2 blade for a 280 on 4.8-6 volts.
If running on a canal, beware the reeds on the opposite bank. Traditionally, always there, also strangely attractive to model boats, especially new ones.
Old Sep 16, 2013, 05:36 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I have a 3-blade 20 mm on, if my memory serves me well.
Old Sep 16, 2013, 11:03 AM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
Near enough, but on a higher voltage a 280 would probably be happier (ie run cooler) with a slightly smaller prop.
Old Sep 16, 2013, 11:55 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Could be. Perhaps on my boat it helps that it's a wave piercing design, so the hull has less drag than for instance a tug boat, as I am running it on 6 volts (5 cell NiMh) and it doesn't even get warm to the touch. The prop used also has a fairly shallow angle on the blades, so it doesn't create a lot of drag when rotating.
Old Sep 17, 2013, 01:54 AM
Joined Sep 2013
Ok. Thanks for all the help guys =)
Old Sep 17, 2013, 06:50 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Looking forward to pics of the final result.
Old Sep 17, 2013, 08:17 AM
Joined Sep 2013
I'll be sure to start a thread up in the following weeks
Old Sep 17, 2013, 02:05 PM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
If you happen to be in the area, a visit to the show at the Norbreck (Oct 19, 20) might give you some useful insights.
Old Sep 18, 2013, 02:55 AM
Joined Sep 2013
I'm not sure if i'll be around that weekend but i'll see if i can make it. Thanks for the info.
Discussion few questions about NAZA v1 and BEC aonavy Multirotor Talk 3 Sep 04, 2013 12:41 PM
Question Few questions about building a Quad. noxs Scratchbuilt Multirotors 2 Mar 23, 2013 06:31 AM
Question A few general questions about Multis... whocares2001 Multirotor Talk 19 Feb 28, 2013 12:42 PM
Discussion Question about the Brushless 2226/2300 KV Easysky motor question (dolphin/cessna) twincobra Micro Ready-to-Fly 0 Feb 11, 2013 12:49 AM
A few questions about what motor/esc for the Corona Prozak Electric Heli Talk 25 Mar 25, 2004 04:07 PM
