Old Oct 13, 2012, 10:09 AM
Kenbogunz is online now
Find More Posts by Kenbogunz
Joined Sep 2008
HobbyKing ESC best bang for the buck
In the 40amp and up rating what is the best ESC for the money from HK or HPartz?...would also be curious as to what is teir best ESC with a switching bec?
Kenbogunz is online now Find More Posts by Kenbogunz
Old Oct 13, 2012, 11:25 AM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
The Hobby King Plush series has always worked great for me, never had a failure. The best part is being able to use the programming card to set up the esc. I've had at least 12 to date. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Oct 13, 2012, 03:16 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
Plush. Plush all the way. Programming card, amazing preformance, smooth throttle response... That's all I use on everything but motor/esc combo packs.
acetech09 is offline Find More Posts by acetech09
Old Oct 13, 2012, 04:58 PM
ColinNZ is offline
Find More Posts by ColinNZ
ColinNZ's Avatar
Auckland New Zealand
Joined Aug 2004
" Hobby King Plush series
ColinNZ is offline Find More Posts by ColinNZ
Old Oct 16, 2012, 10:16 AM
Joined Sep 2008
thanks fellas...got my vote
Old Oct 16, 2012, 11:21 PM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Dynam Dentum
http://www.hobbypartz.com/60p-dye-1004-40a-esc.html
It is identical to the Turnigy Plush, (uses the same program card of course), is in stock in California and costs quite a bit less. I have been using them in 40, 60 and 80 size. They are solid. Look at the 70 amp size for the complete application chart.
Rich in ILM is offline Find More Posts by Rich in ILM
Old Oct 17, 2012, 12:15 PM
acetech09's Avatar
Joined Apr 2012
I have both an 18A detrum and an 18A plush. I think they do run the same firmware (hence same programming), but under the shrink the 18A plush is MUCH different than the 18A detrum. The soft start is much more linear on the Plush, as well as a more snappy brake.
That said, maybe there's more equivalency at the larger sizes.
Old Oct 18, 2012, 02:35 AM
RedLine19k is offline
Find More Posts by RedLine19k
United States, OH, Youngstown
Joined Nov 2004
the 40 plush is listed as 3A linear.. not sure i;d trust that on 6s. the 40A detrum says switching BEC so.. not the same or bad description?
also, i vote for detrum, cheaper, closer and same performance. haven't noticed any less power or smoothness than 25A plush
RedLine19k is offline Find More Posts by RedLine19k
Old Oct 18, 2012, 03:29 AM
B12 is offline
B12
Find More Posts by B12
B12
Finland
Joined Sep 2010
There are some esc's running Hobbywing firmwares and can be programmed with Hobbywing card. Purple Towerpro 40A (without shrink tube) is one. I bought a Hobbywing Pentium 80A from ebay. Turned out to be counterfeit. I reported ebay and got refund by the seller. The esc works like a charm anyway counterfeit or not.
B12 is offline Find More Posts by B12
Old Oct 18, 2012, 05:59 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Originally Posted by RedLine19k View Post
the 40 plush is listed as 3A linear.. not sure i;d trust that on 6s. the 40A detrum says switching BEC so.. not the same or bad description? also, i vote for detrum, cheaper, closer and same performance. haven't noticed any less power or smoothness than 25A plush
The Plush is mislabeled. The P40 is switchmode BEC and is identical to "Detrum" and "Hobbywing Pentium". So choose brand for price. +1 for these ESCs - they are bulletproof and underrated. I have many of them and use them in my 64MM EDF hot setups (750W) and these planes fly at 45-48A sustained. Never a problem. Of course, I make sure they are well ventilated.
The 60A and 80A Plush / Detrum / Pentium are also very good.
TTRotary is offline Find More Posts by TTRotary
Old Oct 18, 2012, 06:18 PM
acetech09's Avatar
Joined Apr 2012
Ehh... I still believe that the 18A Plush and Detrum are different units, at least in hardware. They have different board layouts and what looks like different FETs under the shrink.
Old Oct 18, 2012, 06:45 PM
TTRotary is offline
Joined Mar 2010
Yes, those are different, and so are the 25s. But the 40s are identical.
Old Oct 18, 2012, 06:47 PM
acetech09's Avatar
Joined Apr 2012
Ah. Makes sense. If I ever get something over 40A, I'll go with the Detrums then.
Old Oct 19, 2012, 07:23 AM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
All of the Dynam are switch mode (2 or 3 amp) from 12 amp to 80. The 3 amp BEC starts with 40 amp model. I know the 40 and 60 are identical as I have both of those sizes. I would guess the 50, 70 and 80 are also. Maybe all are identical that have switching bec's? I can tell you the Detrums have been very very good, I run a couple of the 40's at well over the 40 amps on burst and have never had a problem.I have 60's in my 6s planes.
Discussion LiPo's what's the current best bang for the buck? tommyt Batteries and Chargers 66 Sep 01, 2012 06:24 PM
Discussion Best Bang for the Buck in Full House Thermal Sailplane? dwmumford Thermal 13 Jul 21, 2012 10:32 AM
Discussion Best bang for the buck? Idoitall Night Flying 10 Jul 01, 2012 02:53 PM
Discussion What goggles/sunglasses are the best bang for the buck? Twyl Slope 39 Apr 01, 2012 04:28 PM
Help! Recommend me the Best Bang for my Buck rcbif Radios 6 Mar 28, 2012 08:46 AM
