Old Feb 26, 2015, 03:16 PM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Originally Posted by xlcrlee View Post
Also the motor will be hotter and the fast-moving linkages tighter. This is quite common: even my tiny nano-quads show the same > not only does the LIPO voltage go down a bit, but more significantly, the crude motor bushings get tighter because of friction-heat, and require more power.
Gotta "feed the beast!" ..... his name is Entropy
Thanks for the explanation and for the quick Thermodynamic lesson
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Mar 03, 2015, 01:59 PM
Joined Nov 2006
Thank you Lee
Hi Lee
I've tried the weightless balancing method of the wings you mentioned ... and I have to say that the avitron now flies much more stable and predictable ... it is indeed a better way to balance the wings .. thanks a lot for sharing this
I really needed it ... it gives a straight flight both in flapping and gliding mode
and also ... at all tail angles ... and at all throttle settings , this is amazing
Khaled
Old Mar 03, 2015, 03:50 PM
Joined Nov 2006
Avitron V2 .. hands free flight :)))) (1 min 32 sec)
Old Mar 04, 2015, 10:37 AM
xlcrlee is offline
Find More Posts by xlcrlee
Zurich
Joined Apr 2006
Originally Posted by khaled_abobakr View Post
Hi Lee
Khaled
Thank you, Khaled, for reminding me: with the oncoming full moon Kiki is totally "wired" and insisted on flying around the room with an Avitron [he said, "Want 'Go, Go' with the Big Boy!" and made the Avitron motor/gear-flapping sound]. So I took out my oldest V1.0 and soon discovered it was turning too much to the left and not enough to the right. I also saw that the left wing membrane had come loose at the spar root and that there was a cut-down section of an alu weight strip on the right wing. So I removed that weight and put on a super-thin coat of UHU Por and re-attached the membrane at the root, pulling it a bit tighter. The UHU Por is wonderful insofar as I could pull it off again during a few test tries to get the membrane tightness exactly right to balance the flight. Then every flight, in both circling directions, easily plopped onto my hand.
Kiki was very happy [me too]
Lee
xlcrlee is offline Find More Posts by xlcrlee
Old Mar 04, 2015, 10:55 AM
Joined Nov 2006
Lee
That makes me happy too ... It is a wonderful little bird .. and of course Kiki too
Khaled
Discussion avitron v1 vs avitron v2 what are the differences? Legendary_Agent Ornithopters 7 Jun 05, 2012 05:37 AM
Discussion avitron v1 vs avitron v2 what are the differences? Legendary_Agent Ornithopters 0 Jun 01, 2012 02:38 AM
For Sale Paris control board v2.0 and v3.0 Talajouy Aircraft - Electric - Multirotor (FS/W) 3 Feb 28, 2012 01:52 PM
Discussion F3JScore v2.0.0.17, help... garfield.v Sailplane Talk 2 May 17, 2010 02:45 PM
Discussion New Avitron with 0.6g 2.4ghz RX Veteran Scratchbuilt Indoor and Micro Models 6 Feb 12, 2010 10:09 PM
