Old Mar 22, 2011, 11:04 AM
dimar is offline
Find More Posts by dimar
Joined May 2009
Anybody selling these for 2.4ghz?
dimar is offline Find More Posts by dimar
Old Mar 22, 2011, 11:32 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes:
http://www.readymaderc.com/store/ind...roducts_id=396
I also sell them individually. See my blog for details.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 24, 2011, 08:47 AM
dimar is offline
Joined May 2009
What is the difference between having four wires and three? in gain?
Old Mar 24, 2011, 09:03 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Very little difference in gain. I find the cloverleaf is a better TX antenna. Some here prefer the skew-planar wheel.
-Alex
Old Mar 24, 2011, 11:48 AM
dimar is offline
Joined May 2009
http://www.lindenir.com/2.html
This kind of antenna could also be interesting for the receivers... hemispherical circularly polarized antenna, developed by genetic algorithms, probably patented.
Old Mar 24, 2011, 02:13 PM
Mictronics is offline
Find More Posts by Mictronics
Joined Dec 2009
Mictronics is offline Find More Posts by Mictronics
Last edited by Mictronics; Jul 02, 2012 at 01:33 AM. Reason: Tired of RCG - Quality can be found at FVLAB
Old Mar 24, 2011, 09:42 PM
Old Man Mike is offline
Find More Posts by Old Man Mike
Old Man Mike's Avatar
Joined Sep 2007
Originally Posted by Mictronics View Post
Here is another picture:
Some more informations about the math behind:
http://www.hindawi.com/journals/ijap/2008/197849/
Even with polar coordinates for modeling. Let's warm up 4NEC2 ...]
Been there, done that!
(not easy to build and it did not work well at all)
OMM
Old Man Mike is offline Find More Posts by Old Man Mike
Old Mar 25, 2011, 01:23 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
Originally Posted by IBCrazy View Post
Those look good, Matt. Flux core won't hurt the antenna at all. However I must warn you, once you fly the cloverleaf/SPW combination, that Vee/patch will forever remain in a box
-Alex
hi alex
i am new to FPV and still trying out the range and video quality of my 900mhz 200mW stock whip RX TX from hobbyking
this SP antenna will/should be my next mod to the system
did i understand clearly by the quote above u mean that the range of the SP system will be approximately the same as with a Vee Vtx and patch Vrx but with much better video quality ?
QiW is offline Find More Posts by QiW
Old Mar 25, 2011, 07:46 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by QiW View Post
hi alex
Sort of...
Theoretically range is 40% less, but that is almost NEVER realized. Most will get 2-3X the range out of a CP system as they do a linear system due to multipath problems regarding linear polarization. OMM got 2km on 10 mw on his Quadcopter! So did Marc Antonio on his airplane.
-Alex
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
OMM
Thanks, for that, Mike. I almost tried it
Old Mar 25, 2011, 08:39 AM
dimar is offline
Joined May 2009
Linear polarization is only good for the stationary TX and RX (like wifi) and also used primarily because antennas are cheaper.
Circular is always used for non-stationary TX or RX in the professional applications (like satellite communication).
RC electronics just doesn't seem to use it, probably due to costs and size. I am glad someone is exploring this now. It could also be theoretically possible to have video tx on the 2.4ghz and use 2.4ghz radio (like FASST), both with opposing circular polarizations. Someone should try it.
Old Mar 25, 2011, 10:33 AM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
Sort of...
-Alex
thanks for the reply
i am using futaba fasst for my RC
so in theory a 200mW 900mhz system with SP antennas should be adequate for my standard RC range (i hope) .. i don't intend to go beyond 2km for now
Old Mar 25, 2011, 10:37 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I would suggest a cloverleaf on the TX and a skew-planar wheel on the RX. I have found this to be the best combination. On paper the skew-planar wheel on both ends is better. In practice, I find the cloverleaf to be better on the TX.
-Alex
Old Mar 25, 2011, 06:56 PM
revwarguy is offline
Find More Posts by revwarguy
Joined Nov 2010
I've been looking, but can't seem to find any discussion about the SMB connectors - where to get them, and what to use to crimp coax on one. Does one use the same ones for soldering an antenna directly as well as for crimping coax? I am sure its somewhere - could someone direct me to this info?
revwarguy is offline Find More Posts by revwarguy
Old Mar 25, 2011, 07:28 PM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
-Alex
great .. thanks again
the type/thickness of wire used should not be an issue right ? as long a it holds up against the wind and does not deform so easily
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
