Old Nov 29, 2005, 01:01 PM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Ultracote strength - single sheet or pieces OK?
I'm about to start covering a M60. I'd like to put fore-aft stripes on the bottom for orientation. This is my first real experience with using Ultracote. Do I have to use one continous spanwise sheet and then apply strips of contrasting color over that? Or can I stitch dicrete pieces together with some overlap? Does it matter in terms of strength? TIA
- Felix
GoFaster is offline Find More Posts by GoFaster
Old Nov 29, 2005, 01:11 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
You can use seperate pieces; just overlap them about 1/4".
Pete
SchiessCo is offline Find More Posts by SchiessCo
Old Nov 29, 2005, 01:46 PM
lockheed martin is offline
Find More Posts by lockheed martin
Hello Moto
lockheed martin's Avatar
Auckland, New Zealand
Joined Mar 2005
What are you useing for the fuse? Im planning on useing Solartex for my M60 as it compund curves well. But I also found out that Ultra does aswell. Good pick on the Ultra, its the toughest one out there!
Nick
lockheed martin is offline Find More Posts by lockheed martin
Old Nov 29, 2005, 01:58 PM
I'm Rick James is offline
Find More Posts by I'm Rick James
Nucking Futs
I'm Rick James's Avatar
Southern Killafornia
Joined Jan 2005
It'll probably be easier to just lay a whole sheet at once and then trim stripe as necessary. That's the way I usually do it if I have the materiel. If I'm trying to make it stretch then I would do bits at a time.
Just my .02
IRJ
I'm Rick James is offline Find More Posts by I'm Rick James
Old Nov 29, 2005, 02:10 PM
Louied is offline
Find More Posts by Louied
ALL IN !
Louied's Avatar
Carlsbad, California, United States
Joined Feb 2004
Use separate pieces like stated in Pete's answer. I find that you get a cleaner look. If you lay a 2nd piece over another it tends to get bubbles in it when you apply the iron or heat gun.
Louie
Louied is offline Find More Posts by Louied
Old Nov 29, 2005, 02:14 PM
malachite is offline
Find More Posts by malachite
just add beer......
malachite's Avatar
Lakewood, CA
Joined Oct 2005
When you guys are talkin' "Ultracote" are you referring to Top Flite Ultracote (aka Heavy Duty Monocote) or Hanger 9 'Ultracote'??
Who's supplying the Hanger 9 Ultracote online? I've found a few places but their stock seems spotty.
malachite is offline Find More Posts by malachite
Old Nov 29, 2005, 02:19 PM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
Hanger 9 Ultracote. Monokote is a high temp covering...great for open structures but may melt foam when you apply.
As far as strength, I would think that one piece is stronger...how much so and wheter or not it will make a noticeable difference is debatable. I prefer the "Schiess" method . Saves on material and you don't need to worry as much about keeping your covering in a dark over light colors order.
InTheLift is offline Find More Posts by InTheLift
Old Nov 29, 2005, 02:29 PM
screamin' eagle is online now
Find More Posts by screamin' eagle
Confirmed Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
NICE Weasel!
I don't have any personal opinions about the strength issue, but I distinctly recall that my M60 instructions said to use one piece of Ultracote for the wings (i.e., don't cut the covering off the part of the wing that goes into the fuse) in order to retain the strength of the covering. The instructions said that the wings get additional strength from the covering.
I laid down my yellow top and bottom and then added the purple stripes. Beware that if you do this in reverse order, the darker color ultracote will show through the lighter part (i.e., you will see the purple through the yellow).
screamin' eagle is online now Find More Posts by screamin' eagle
Old Nov 29, 2005, 02:36 PM
lrsudog is offline
Find More Posts by lrsudog
Go get them Meg!
lrsudog's Avatar
Cabin 21...
Joined Jan 2001
The overlap is pretty strong if at least 1/4" like Pete said. I also try to wipe down where I'm going to make a seam with alcohol to get off all my finger & hand print mung before ironing the overlap.
lrsudog is offline Find More Posts by lrsudog
Old Nov 29, 2005, 02:49 PM
It could happen...
InTheLift's Avatar
Joined Jan 2004
Thanks Dom!
I'd say that if the instructions call for a solid piece, you'd be wise to consider the solid piece.
Old Nov 29, 2005, 02:55 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
ITL - how heavy did the weasel come out w/ ultracote?
ajroahkni is offline Find More Posts by ajroahkni
Old Nov 29, 2005, 03:13 PM
It could happen...
InTheLift's Avatar
Joined Jan 2004
Under 11.5 ounces...it was about 11 and change right before final balance and took less than 1/4 ounce to get it dialed. I haven't weighed it since it was cg'ed. Has a balsa tail, but it's not exactly a light tail! LOL!
Old Nov 29, 2005, 05:48 PM
AntonL is offline
Find More Posts by AntonL
antipodean recalcitrant
AntonL's Avatar
Melbourne, Victoria, Australia
Joined Feb 2004
Another option is to use a single piece of iron-on and then apply trim using sign-writing vinyl or the like.
Anton
AntonL is offline Find More Posts by AntonL
Old Nov 29, 2005, 06:23 PM
-DoubleV- is offline
Find More Posts by -DoubleV-
-DoubleV-'s Avatar
Joined Mar 2005
either way will work really. just stick to the basic rule of thumb, light colors ALWAYS first.
V V
-DoubleV- is offline Find More Posts by -DoubleV-
Old Nov 29, 2005, 09:27 PM
Pegasus is offline
Find More Posts by Pegasus
Pegasus's Avatar
Austin, Tx
Joined Nov 2003
The ideal methodology is to use one piece of Ultracote on the top of the wing and one on the bottom of the wing. This will give you the optimum torsional rigidity over EPP for the wing.
The other reason for using one piece is that when using the proper Ultracoat shrinking technique you will allow yourself the ability to modify the shape of the wing with more consistency. i.e. should you want to increase or decrease the dihedral of the wing.
Steven
Pegasus is offline Find More Posts by Pegasus
zagi ultracote cover? full lenght or peices? engr Foamies (Kits) 3 Mar 05, 2002 01:40 PM
