Old Apr 06, 2005, 08:09 AM
canuckrcer is offline
Find More Posts by canuckrcer
Joined Mar 2005
2100 charge rate
Hi, I just purchased the Dynamite Vision Peak Ultra and a Thunder Power 2100mah pack with these specs:
2100 mAh, 2 cells (7.4V)
Rating: 10-12C (21-25A) continuous, 16C (33A) burst
Output: 7.4V Nominal, 2100mAh
Dimension: 34mm x 98mm x 13mm (98gr)
The Vision charger has adjustable charge rates for lipo from .1a to 2.5a.
My question is this- 1c charge rate for this pack would be 2.1a but I have heard its best to charge at a lower rate the first few charges. So would say 1.5a be an acceptable rate for say the first 6 charges. Then I could move to 2.0a for regular charges. Oh and at 1.5a I would expect it to take 100 minutes to charge?
Steve
canuckrcer is offline Find More Posts by canuckrcer
Old Apr 06, 2005, 08:36 AM
willhicks is offline
Find More Posts by willhicks
Dealer
Hendersonville, NC
Joined May 2004
I'd use 1C. Limit your first flights to short 10 minute flights. The batteries will get better.
Will
willshobbies
willhicks is offline Find More Posts by willhicks
Old Apr 06, 2005, 09:03 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Steve
1C is the maximum standard however many do believe that less such as 0.7C is easier on the batteries. I use 0.7C most of the time. Addational length of time required is not proportional to the reduced rate as all Li Poly chargers reduce the rate long befor charg e is completed anyway.
As per the TP Safety Sheet take it a little easy for the first several flights.Make sure LVC is set to 3 volts per cell and try to land befor LVC for the first several flight especially. Let battery rest(cool) to ambient temperature befor re charging.
Charles
Lipoly question - TP 2100 Charge Rate ChuckD Power Systems 3 Nov 26, 2004 03:04 AM
Max charge rate for AR's? Kosh Electric Plane Talk 8 Oct 13, 2001 01:49 PM
What is safe charge rate for 2000 Nimh Panasonics ? Al P Electric Plane Talk 5 Jul 18, 2001 12:22 AM
'Green' 500 ARs - maximum charge rate? Bill Glover Electric Plane Talk 6 May 23, 2001 12:30 AM
For 9.6V 1600ma NIMH battary what is the charge rate and charge time? clchen Electric Plane Talk 7 May 06, 2001 09:06 PM
