Old Feb 06, 2015, 10:47 AM
glider304guider is offline
Find More Posts by glider304guider
glider304guider's Avatar
Joined Nov 2003
Source for solid 15mm carbon rods?
Anybody know where I might find solid carbon rods with od of 15mm. I'm wanting to replace a solid steel wing rod with something lighter. I've found hollow ones online but can seem to find solid ones.
Thanks for any help.
glider304guider is offline Find More Posts by glider304guider
Old Feb 06, 2015, 01:46 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Google - 15mm solid carbon rods
Looks like some use that diameter for camera rails, and other things.
eflightray is offline Find More Posts by eflightray
Old Feb 06, 2015, 03:19 PM
Joined Nov 2003
Yea, the camera stuff is 15mm o.d. But the stuff I saw is
hollow carbon tubes. I'm looking for solid rods.
Thanks for responding
Old Feb 06, 2015, 07:24 PM
kenh3497 is offline
Find More Posts by kenh3497
Live long and fly high
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
If you can find another tube that will slide in the 15mm tube and glue the two together I would think the strength would be much more the the solid steel rod. BUT, I have no hard numbers to prove this theory of mine.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Feb 07, 2015, 02:46 AM
saramos is offline
Find More Posts by saramos
Joined Feb 2007
Here's a link to some 10mm and 12.7mm carbon rods. These are pultruded carbon rods.
http://www.cstsales.com/carbon_rods-ss4.html
Scott
saramos is offline Find More Posts by saramos
Old Feb 07, 2015, 06:20 AM
Joined Nov 2003
Thanks Scott,
I did see their web site. They just don't carry the 15mm that I'm looking for.
Old Feb 07, 2015, 07:30 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Have you considered a hardwood dowel, (beech or something similar).
I used 12mm beech dowels on my old 132" span Hump glider as joiners for the three piece wing, they were only 7" long as the ribs and wing spar did all the work.
I also used beech dowels on my 93" B-25, (9mm), and a 100" B-17, (12mm).
A piece of 12mm, (1/2") diameter dowel is near impossible to break by hand, even a 3ft length.
Old Feb 07, 2015, 08:47 PM
Joined Nov 2003
I think I'll go with Ken's idea and glue a solid carbon fiber rod inside a hollow one. Should be pretty strong.
Old Feb 08, 2015, 09:43 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
I have GOT TO ask. Why solid for wing rods. ALL the physics say that the "core" of a solid rod is just along for the ride; add weight without benefit, and indeed, promotes bending more easily.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Feb 08, 2015, 02:53 PM
Joined Nov 2003
Even with a solid carbon rod I'll be saving a lot of weight. My steel rod weighs in at 1.5lbs. A solid carbon fiber rod should be in the neighborhood of 0.5lbs. I did find a source thanks to another member on RCGROUPS. Here is a link in case anyone else is looking for similar stuff.
http://www.rcfoam.com/carbon-fiber-s...rod-p-758.html
Also I actual measured the rod with some calipers and found out I need a 14mm rod. Moral of the story, don't believe everything you read on the internet.
Duane
Discussion Good source for carbon fiber & fiberglass rod/tube ChrisRD Scratchbuilt Multirotors 0 Jul 25, 2014 12:37 PM
Wanted 8mmx 8" solid carbon rod raceredg Aircraft - Sailplanes (FS/W) 7 Dec 27, 2013 07:44 PM
Discussion best us source for carbon rod and strips? mattnat Indoor Pattern/F3P 4 Dec 03, 2013 06:43 AM
Discussion Anyone replace the carbon rods in their Cularis wing with solid carbon fiber? tekrunner Foamies (Kits) 9 Jul 03, 2009 11:15 PM
Looking for Source for Metric Carbon rod/tube suppliers AeroSports Micro Helis 8 Jan 07, 2003 11:19 PM
