Old Mar 01, 2013, 07:12 PM
jeff262 is offline
Find More Posts by jeff262
farmington, mn
Joined Sep 2003
7 minutes to short to fly with?
I am converting my Pby from electric to gas 4 strokes. All I can manage to get in the wing are two 3.5 ounce tanks. Doing a bench test all I can get is almost 8 minutes at 80% throttle before its bone dry. Should I look at trying to fit some 1 oz header tanks in the wing for is 7 minutes enough to really fly with its a pby so I don't plan on going anything to exciting. Also I am using the standard tank type with the round rubber stopper and the three brass tubes with a clunk. All I can fill it up is 80% before it comes out the exhaust is this normal or should I be able to fill it all the way up, as you can tell I normall don't fly gas
Thanks jeff
jeff262 is offline Find More Posts by jeff262
Old Mar 01, 2013, 07:40 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
3.5oz tanks are kinda small. Are we talkin gas or nitro?
Kyler1 is offline Find More Posts by Kyler1
Old Mar 01, 2013, 08:00 PM
jeff262 is offline
farmington, mn
Joined Sep 2003
Nitro is running a .26 4 stroke
Old Mar 01, 2013, 08:54 PM
miltac is offline
Find More Posts by miltac
miltac's Avatar
United States, NC, New Bern
Joined Dec 2011
you should be able to fill the tank till its completly full. The line going to your muffler should be bent up inside the tank until its about just shy of touching the tank.
miltac is offline Find More Posts by miltac
Old Mar 02, 2013, 09:19 AM
kenh3497 is offline
Find More Posts by kenh3497
Live long and fly high
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
IMO 7 minutes is not a "short" amount of time. A PBY is not an aerobatic plane. I take it you will mostly just be tooling around the sky. You might find 7 minutes is a long time to just fly in circles. Go for the 3 1/2 oz tanks. You can always add the header tanks if you feel the need.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Mar 02, 2013, 09:39 AM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
When I got a minute flight with a rubber powered plane I could hardly believe it. It seemed like it would never come down. It's all in the frame of mind. I wouldn't complicate it.
Are you really going to fly a PBY around at 80% throttle? Seems like for a scale type you'd be throttled back more, and I would expect to get much better than 7 minutes from 3 1/2 oz on a 26 4 stroke. Probably you'll want to do touch and goes. But even for take-offs models almost always take off way too fast for realism, so even there you might not use full power. And as soon as you're up you throttle back, right? Scale models usually look terrible at anything close to full power, unless it's a WWII fighter type.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Old Mar 02, 2013, 10:49 AM
jeff262 is offline
farmington, mn
Joined Sep 2003
Thanks for the input I'm normally flying electric so I'm still not sure how much fuel gets used in starting and taxi. But I should be able to get more run time if I get the exhaust tube bent correctly to fill the tank all the way up, another question is with this small of a tank should I use a clunk since it really doesn't have much movment with that short of a tube and just use the brass tube and bend it down towards the rear of the tank? Next question is in small tanks do I want to use a ball type fuel filler or a hand crank filler
Old Mar 02, 2013, 07:55 PM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
You will want to use a clunk. Find some small fuel line though. It will be more flexible. In fact you should use small line all the way to the carb. It will help with fuel draw a bit. The engine will lift a small column of fuel better than a large column.
Sounds like a neat project. Post some photos of your progress.
Ken
Old Mar 02, 2013, 08:52 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Once you get airborne, you can very likely throttle back to 1/2 to 3/4 throttle and fly the plane. So at reduced throttle you should be able to make it go 10 minutes or longer even.
earlwb is offline Find More Posts by earlwb
Old Mar 03, 2013, 10:29 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
For sure. And by the way 10 minutes is longer than Many electrics fly. It is a nice comfortable flight time.
Fokker DII is offline Find More Posts by Fokker DII
Discussion Black Hornet military drone. Only 12 grams and can fly for 30 minutes jasper7821 FPV Talk 36 Mar 02, 2013 07:15 AM
Sold $80 shipped! -- 2.4G Fly-Sky CT6B 6-Ch. Tx with (7) seven 6-Channel Rx's Cobra68 Aircraft - General - Radio Equipment (FS/W) 0 Jan 13, 2013 09:52 PM
Discussion HENG KUN HK298 Twin Screw Transport Helicoptor (now with 7 minute flight video!) Rodeown Coaxial Helicopters 29 Mar 16, 2011 04:57 PM
Discussion Finished camera holder, but will she fly with the camera attached? Added short video turnbui Aerial Photography 19 Sep 24, 2008 04:56 AM
