Old Feb 22, 2013, 05:42 PM
Entropy76 is offline
Find More Posts by Entropy76
The Last Question
Entropy76's Avatar
United States, UT, West Valley City
Joined Oct 2006
Did I screw up?
I made a little jet. It weighs 61g and maintains 65g of thrust. Anyway I was doing test glides onto the bed and power off glides were ok...not the best but power on glides at half throttle shows a bad nose down situation. I didn't really think about the fan being above the wing until now. So what should I do? Any fixes you can think of? I don't want to start over.
Entropy76 is offline Find More Posts by Entropy76
Old Feb 22, 2013, 07:26 PM
DoubleOne is offline
Find More Posts by DoubleOne
DoubleOne's Avatar
United States, MD, Annapolis
Joined Jul 2012
I'm not too sure...but you may want to check your CG. It could be a little nose heavy, or the moment from the thrust above the centerline could be causing a nose down (negative) moment. You can counter it with a positive moment from shifting the CG aft.
You could give the exhaust duct some kind of down angle...so the front of the duct points down and the exhaust is pointing up a little bit.
I drew a diagram to show basic moments from different CG locations...and what it looks like when you point the exhaust in that upward direction. **Please note, the diagram is VERY basic. There are a lot of other factors that come into play in regards to the moments, but I would start by moving the CG slowly aft**
The neutral point is the aerodynamic center of the entire airplane.
If someone thinks that I am way off, let me know.
DoubleOne is offline Find More Posts by DoubleOne
Old Feb 22, 2013, 07:36 PM
The Last Question
Entropy76's Avatar
Joined Oct 2006
Wow, thats an awesome diagram! Thank you. So either move CG back making it tail heavy or adjust the thrust line giving it a positive moment when throttle is applied.
So am I wrong in thinking the best solution would be the change in thrust line?
Old Feb 22, 2013, 09:17 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Hi Entropy,
It looks like you have the start of a nice little micro EDF there.
Definitely make sure the thrust line is correct because even a little misalignment can make a big difference. My rule of thumb for new designs is to make sure the thrust line passes thought the middle of the battery since that will be your heaviest single component.
Additional thoughts:
1 - Where is your CG now? My hunch is that it's too far forward with the long nose, battery, RX, etc. out in front of the wing and not much behind.
2 - You vertical stabilizer looks too small and/or too far forward. Side area of the forward fuselage is larger than the vertical stabilizer which will make it very unstable in yaw.
3 - No horizontal stabilizer? Any reflex in your elevons?
Good luck!
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Feb 22, 2013, 09:19 PM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
I would move the thrust angle, just a touch higher at the tail end of the outlet cone, the thrust is most likely pushing the nose down.
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Feb 22, 2013, 09:35 PM
The Last Question
Entropy76's Avatar
Joined Oct 2006
Originally Posted by Esprit440 View Post
Hi Entropy,
Good luck!
-Matt
Thank you, CG is at the recommended point based on an online calculator for delta wings.
(The nose is hollow)
So about the rudder, you're saying it is too far forward and not big enough. When I adjust thrust angle I'll try and improve that. Yeah, no horizonsntal stab, it's a delta.
No reflex in elevons. I'll give it a mm or two.
Thanks.
Old Feb 22, 2013, 09:43 PM
The Last Question
Entropy76's Avatar
Joined Oct 2006
Joe
Thanks, will do. And I'll try making the vert stab bigger/further back. It did wag a little even throwing it on the bed.
Old Feb 22, 2013, 09:44 PM
The Last Question
Entropy76's Avatar
Joined Oct 2006
CG is about 1 mm forward of the servos BTW.
Thrust line is through the middle of the battery also...
Old Mar 03, 2013, 02:25 AM
The Last Question
Entropy76's Avatar
Joined Oct 2006
Well that didn't end well. First and last flight was a few days ago. I put landing gear on it. I got it up to speed and took off. The tail was wagging up and down pretty bad. I banked it left to turn and it rolled upside down and nose dived into the ground.
So next one will have a bigger wing, bigger rudder and I think most importantly edf and wing will be mid-body.
Old Mar 04, 2013, 11:52 PM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Hey, that's the way it is with these things! Most of my planes don't fly, or are uncontrollable or nose dive, or crash to pieces, or loop and hit me in the back of the head and break in two, or, or, or!
Just think about it....most of us are not aeronautical engineers (except Jetsett44 he works for Boeing so he does not count! )And we're building one off custom airframes and boy aren't we all glad there are not pilots lives at stake. Keep at it and you'll have a winner you can be proud of.
MUTCAKE is offline Find More Posts by MUTCAKE
Old Mar 05, 2013, 05:21 AM
The Last Question
Entropy76's Avatar
Joined Oct 2006
Thanks for the support! Yeah, I love building so it was fun anyway. The whole time building it I was wondering if it would actually fly. I couldn't just let it sit there and not know. Anyway the motor/fan combo is what I really wanted to test and it definitely had good speed on takeoff. Hey, it was only foam, right?
Old Mar 05, 2013, 10:38 AM
MUTCAKE is offline
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
I used to start a lot of builds and never finish them, saying to myself "aw that will never fly". Now I just chuck everything I got into the air. I don't care! Yeah its only foam and I have yet to break any gear. Well at least not at this weight.
16/15/3 on 4S in a t-rex..? did i screw up? birdie_in_texas Mini Helis 15 Jul 02, 2005 02:26 AM
Corona Pre-Flight Check (or, what did I screw up?) Harv Electric Heli Talk 26 Jun 02, 2005 10:19 AM
Megatech Skyliner....How bad did I screw up??? Jagzilla Electric Plane Talk 3 Sep 18, 2004 01:50 PM
Question Did I Screw Up My New E-Tec LiPo Pack? Yakrobat Batteries and Chargers 2 May 07, 2003 04:02 PM
Did I screw up the aerodynamics of my Zagi? emaij Power Systems 3 May 04, 2001 09:32 AM
