Old Feb 08, 2012, 03:40 PM
Merk is offline
Find More Posts by Merk
Merk's Avatar
United States, SC, Clover
Joined Sep 2004
Yes, I am ready to get this thing moving.
It has been sitting in the garage way to long.
Need to make some noise.
Merk is offline Find More Posts by Merk
Old Feb 08, 2012, 03:42 PM
Merk is offline
Merk's Avatar
Joined Sep 2004
Tom, Just bring the part with you to FL.
It is only a week away.
You can bring any other parts that you might not want also..LOL
Russ
Old Feb 08, 2012, 04:04 PM
G_T is online now
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
If I ever get my machine running... I have the Hitachi as well. It is pretty smooth and quiet as routers go.
Gerald
G_T is online now Find More Posts by G_T
Old Feb 10, 2012, 09:01 PM
woode is offline
Find More Posts by woode
woode's Avatar
Joined Mar 2011
Just curious as to what the repeatable accuracy is for your machines? Can you get inside 0.002"?
woode is offline Find More Posts by woode
Old Feb 11, 2012, 09:41 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
IF I adjust my machine just before the cut I can get within .002"
Nothing I cut needs to be that accurate, so I don't always readjust my machine prior to cutting. I can go for months at a time without adjustment and cut within .005"
What are you wanting to cut that requires such precision? A decent machine with .005 tolerance can be built for about $2k. You can plan on 3-5x the cost for a machine that consistently does .002" and plan on 10-30x the cost for a machine that consistently does better. Chasing unnecessary precision can be a very expensive game.
My machine is typically used by cabinetmakers and sign shops. I sacrificed a bit of speed in my rapids to get a tighter resolution, knowing that my router would lack the power for high speed cutting anyhow. Speed is an even more expensive game than precision.
Hobby machines are exactly that, even though it's easy to want to build it better, stiffer, tighter, faster, more precise etc...
tom43004 is offline Find More Posts by tom43004
Old Feb 11, 2012, 11:20 AM
Goinav8n is offline
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
I have the Energy Chain and the router enroute to us. Should be here this week
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Old Feb 11, 2012, 12:25 PM
szastoupil is offline
Find More Posts by szastoupil
Scott Zastoupil
szastoupil's Avatar
USA, WI, Waupaca
Joined Aug 2002
Jeff
Where did you end up buying the energy chain? I need to buy another chunk and deciding to go with the same generic stuff or purchase a true Igus brand chain. I asked around recently and found out my work and other local organize just threw out garbage cans of Igus chain.....frustrating.
szastoupil is offline Find More Posts by szastoupil
Old Feb 11, 2012, 06:57 PM
Goinav8n is offline
Jeff Carr
Joined Mar 2001
Hi Scott
Here is where I got ours
http://www.ebay.com/itm/250974148151...84.m1439.l2649
Free shipping made it a better deal.
Russ had me come over today and do some soldering. I got the wires soldered to the DB9 connector. Now we just need the correct computer cable and see if it will run.
Were not far from getting this thing going. Russ has done a great job. I have some pics but will try to get them up later
Jeff
Old Feb 13, 2012, 01:53 PM
Goinav8n is offline
Jeff Carr
Joined Mar 2001
Here are a few more pics of the build. I went over and did some soldering for the new Gecko board and then helped Russ do the final touch ups on the Unistrut.
We did not have the correct computer cable for the board so had to order one. We powered it up and it hums. Thats a good sign
Jeff
Old Feb 13, 2012, 09:57 PM
I_Can't_Fly is offline
Find More Posts by I_Can't_Fly
But I am learning
I_Can't_Fly's Avatar
USA, MD, Cumberland
Joined Apr 2008
Wow that's looking really good Russ. I have "cutting area" envy. I had to go and order parts to extend my x-axis out to 33" cutting area before my first part was really cut. I should be able to cut DLG wings in one go now. However it looks like you will be able to cut 10 at a time lol.
I have all my build progress in my Blog for anyone that is interested.
Brian P.
I_Can't_Fly is offline Find More Posts by I_Can't_Fly
Old Feb 14, 2012, 10:36 AM
Merk is offline
Merk's Avatar
Joined Sep 2004
Brian P.
Thanks the table is 72x60 but the useable part is only 48x48. (Or there about)
The gantry can't go all the way over to the sides or front and back.
I have a cable for the G540 coming and I hope to get it moving soon.
This is just killing me that I have all of this and I can’t get it moving because I am waiting on a $6.00 cable.
Tom is bring me the parts for the “X” access so after the DLG contest this weekend in FL. I should have that built by next week.
Brian what are you using to surface the spoiler board?
Russ
Old Feb 14, 2012, 11:13 AM
Scott Zastoupil
szastoupil's Avatar
USA, WI, Waupaca
Joined Aug 2002
I hope your new cable resolves your issues. I saw your or Jeff comment on the cable and it saved me quite a bit of time when I encountered issues last night of the PC not recognizing the Estop logic from the controller board. I was using the controller and cable for foamcutting, but that setup used different pins. Luckily I had a different cable...swapped it out, and viola with a working system. I probably wouldn't have thought of it as quickly if I didn't see your problem here...so thanks. The XML file from Gecko's site worked with minimal changes. I disabled the 4th axis for my machine and also increased in the pulse width to 2us in the Motor Tuning menu. I just happened to read that recommendation in the Gecko manual (2us pulse width or greater for step and direction), and the XML file had a default of 1us. I'm guessing you already slaved your two gantry axis. Good luck!
Old Feb 14, 2012, 12:01 PM
But I am learning
USA, MD, Cumberland
Joined Apr 2008
I have not surfaced it yet. I will probably buy a 1/2" shank surfacing bit unless someone has one they could lend. I have parts on order to make my machine longer, and don't want to worry about surfacing until I get the final set up installed.
Brian P.
Old Feb 19, 2012, 09:12 PM
But I am learning
USA, MD, Cumberland
Joined Apr 2008
I found this, and the price looks right. I may order one, and share it with you guys if you would like.
Surfacing Bit
Brian P.
Old Mar 06, 2012, 07:28 PM
Merk is offline
Merk's Avatar
Joined Sep 2004
OK,
I have some more done on the table
I have the table bolted down and the spoiler board marked for tracks.
I got my G540 back from the repair shop. (Blow a fuse in it-Bad)
I have it all hooked back up.
Got some of the Z axis built. waiting on some more parts.
I have the Router. have to buy the mount for it yet.
I think I can get it moving now.
Help! cnc router table ian murdock CAD/CAM 14 Jul 06, 2011 05:10 PM
Build Log CNC router table build hawaiianspork226 CAD/CAM 94 Jun 01, 2010 11:49 AM
For Sale CNC 3 axis router table topforce Non R/C Items (FS/W) 0 Jul 02, 2006 01:34 PM
Looking for CNC router table FHHOBBIES The Builders Workshop 13 Jul 19, 2005 08:39 AM
WTB CNC Router table corey Aircraft - Electric - Airplanes (FS/W) 2 Dec 10, 2003 08:16 PM
