Old May 31, 2011, 01:29 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
Thanks Markus..
I took another look at my 3 (clover) antenna..
they where not at 45deg.. like in this video..
Cloverleaf antenna for FPV by IBCrazy (1 min 5 sec)
I bent them closer to 45.. and it's improved about 10 times.. now when I move it around.. it does not cut out as much ..
1failure to the 10 before..
cant wait to get this in the air.... will start the build tonight with some modification on that cub..
Anyone have a video link ..like the one above for the 4 (skew planer) ?
that made it so simple to understand the angles ..
Thanks.. again ..
flyhigh300 is offline Find More Posts by flyhigh300
Old May 31, 2011, 02:37 PM
bamabaxter is offline
Find More Posts by bamabaxter
bamabaxter's Avatar
United States, MS, Clinton
Joined Apr 2010
I think it is the same, just has four instead of three.....90 degrees apart vs. 120 if I understand correctly....
bamabaxter is offline Find More Posts by bamabaxter
Old May 31, 2011, 03:50 PM
terry74 is offline
Find More Posts by terry74
la fabrique circulaire
terry74's Avatar
geneva
are you talking about this fresh one?
The Skew-Planar Wheel (SPW) circular polarized omni antenna by IBCrazy (1 min 11 sec)
A+
JAy
terry74 is offline Find More Posts by terry74
Old May 31, 2011, 07:31 PM
Jaybee is offline
Find More Posts by Jaybee
SLO Flyer
Jaybee's Avatar
San Luis Obispo, CA
Joined Dec 2003
Pair of completed skew planar antennas:
Right hand polarization. Side-fed with a short length of cable, for wing mounting.
Heavier gauge wire, for the receiver antenna.
Thanks for the awesome guide, Alex!
Jaybee!
Jaybee is offline Find More Posts by Jaybee
Old May 31, 2011, 09:34 PM
Joined Nov 2010
Thanks..
That makes it easy to understand.. !
I did my first set.. really quick.. HUGE improvement..
will draw up some templates to get the angles as close to perfect..
http://www.youtube.com/watch?v=P-3hwU5ejbE
A+
JAy
Old Jun 04, 2011, 03:25 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Does anyone have a picture of their SPW jig? I am looking at making a few for my planes and I would love to see how people put their jigs together to speed up the process. I just finish making a cloverleaf jig that works nicely but I haven't thought up one for the spw.
whakahere is offline Find More Posts by whakahere
Old Jun 04, 2011, 03:43 PM
vipix is offline
Find More Posts by vipix
FPV from Lithuania
vipix's Avatar
Lithuania
Joined Mar 2007
It is same as CL, but 45 degree triangles at 90 crossover...
vipix is offline Find More Posts by vipix
Old Jun 04, 2011, 03:47 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
yea I am guessing as much but I am building 5.8ghz and 2.4ghz antennas. So I have to keep that cross over point very small.
Old Jun 06, 2011, 07:25 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Side feed or base feed? For side feed, I use magnets on a small metal plate. Drop the wires on them and it holds geometry.
For base-fed I use a split bullet inside a cylinder. I will post pictures if I can remember where I put my camera... Basically I have a cylinder with 4 magnets on the edge. The bullet has a small loe in the middle and is split in two. The cable comes through the center of the bullet, the cylinder hold the halves together. Dorp the lobes in and the magnets hold them in place for soldering. Add heat and solder and it does it perfectly every time. When soldered, push the bullet from the cylinder and it splits open to unlock the antenna.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 06, 2011, 10:12 AM
terry74 is offline
terry74's Avatar
geneva
5.8g spw
0.5mm piano cord made
Old Jun 06, 2011, 01:52 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
-Alex
that sounds like a great plan. Love to see a picture still as I am more visual that ... reading learner
but magnets sound like a great idea!!
Old Jun 06, 2011, 01:53 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
My hat off to you. they look bloody good!
Old Jun 06, 2011, 11:53 PM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
this post was originally about my bent-then-straightened blu-beam cpw antenna, moved over to VAS customer support thread..
Glenstr is offline Find More Posts by Glenstr
Last edited by Glenstr; Jun 07, 2011 at 12:38 AM. Reason: moved post to different thread
Old Jun 21, 2011, 03:20 AM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
Many thanks
Can't wait to try out my SP and CL combination
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Old Jun 22, 2011, 09:40 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Taking a break
Many of you have noticed I haven't been around as much. It's because I have been burned here on RCG. I will continue to be active on FPVLAB where it appears there is a much more mature crowd.
You can find me and post questions here as I monitor this regularly: http://fpvlab.com/forums/forumdispla...Aerial-Systems
That is also where I plan to launch my new antenna designs.
Take care all of you,
-Alex
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
