Old Oct 05, 2010, 03:21 PM
markeydoo is offline
Find More Posts by markeydoo
Joined May 2008
Is there a tracking device that will work with any system??
Is there one?
Mark
markeydoo is offline Find More Posts by markeydoo
Old Oct 05, 2010, 05:10 PM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
If you are referring to an antennatracker then yes, the ImmersionRC TinyTelemetry will work with any OSD, just means adding a small module to your plane which will transfer telemetry over the audio channel and use the ImmersionRC EzAntennaTracker on the ground for tracking.
If you mean a universal system that works with everything, there's no such thing at this moment. The various (2) antenna tracking solutions commercially available are not compatible.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Oct 05, 2010, 09:29 PM
Joined May 2008
Thanks Sander
Tiny Telemetry is what I need.
So what is the interface to the servos to track the plane? Also since the OSD I have uses a gps ant. would I be able to share the TT GPS ant?
Are there any pictures of a complete working system?
Mark
Old Oct 05, 2010, 10:12 PM
workshop is online now
Find More Posts by workshop
Tesla's Workshop
workshop's Avatar
USA, CA, Torrance
Joined Nov 2004
Mark...
I use ImmersionRC gear with my rig. I'd be glad to walk you through the install and use...
workshop is online now Find More Posts by workshop
Old Oct 06, 2010, 12:18 AM
garris2 is offline
Find More Posts by garris2
Melbourne, Australia
There's also the Dakar/Lynx (Lince) system that will work with anything.
You can turn off the Dakar OSD text and just use the tracking function.
But you have to build it yourself.
Dakar; Airbourne component.
http://www.aeromodelismovirtual.com/...ead.php?t=1137
Lynx (Lince); Ground station component
http://www.aeromodelismovirtual.com/...ead.php?t=1849
garris2 is offline Find More Posts by garris2
Old Oct 06, 2010, 01:39 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
MyFlydream also is universal.
http://myflydream.com/Home/MFDStore/...1/Default.aspx
It taps on any existing OSD GPS, and deliver NMEA stream over audio at the ground, with optional antenna tracker.
renatoa is online now Find More Posts by renatoa
Old Oct 06, 2010, 08:44 PM
Joined May 2008
Thanks Everyone
Has anyone tried MyFlyDream tracker?
Old Oct 07, 2010, 01:06 AM
glassfox is offline
Find More Posts by glassfox
glassfox's Avatar
Tianjin, China
hi, i am actually testing which is believed to be the newest version MFD tracker, it works with my 10hz gps, i am impressed by the heavy duty pan/tilt, it's well made and do not need any assembling, it saves time and increase safety
FOXTECH,
Fu
glassfox is offline Find More Posts by glassfox
Site Sponsor
Old Oct 07, 2010, 06:02 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I am working on a DIY antenna tracker project where no GPS is needed. I haven't had the time to finish development yet as I am in the middle of moving to a new house. When I do finally get it done ant tested, there will be a how to on building it.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Wanted fpv system that will work with my 2.4 ghz plane bradsears Aircraft - General - Radio Equipment (FS/W) 2 Aug 24, 2010 11:53 AM
Discussion Are there any chargers that will or can be modified easily to be a CC power supply? Gigaah Batteries and Chargers 4 May 01, 2010 04:48 AM
Help! Is there a tx that will work with this? all4smallrc Scratchbuilt Indoor and Micro Models 2 Nov 21, 2009 10:12 PM
Discussion Is there a Motor battery Esc combo that will work on just about every plane? lacofdfireman Foamies (Scratchbuilt) 11 Nov 16, 2009 10:43 AM
Is there a P-47 (ARF or Kit) that will work with wetmore16 Fuel Warbirds 3 Jun 27, 2005 12:43 PM
