Old Jun 19, 2010, 05:13 AM
Chris_S is offline
Find More Posts by Chris_S
Joined Jun 2010
Glow engine quits inexplicably
I have this ancient MRC Trainer Hawk (Foam plane w/ glow engine) and the engine starts right up and throttles up properly for the first few minutes or so. After a couple of minutes, however, the engine seems to lose power and doesnt throttle up properly anymore. Then, when I try to idle the engine, it dies. Also, when the plane is tilted, the engine seems to lose more power. What gives? Is the needle not set properly or is it the gas tank or what?
Chris_S is offline Find More Posts by Chris_S
Old Jun 19, 2010, 10:20 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Sounds rich on the LSN, what engine is it specifically?
1320fastback is offline Find More Posts by 1320fastback
Old Jun 19, 2010, 11:09 AM
downunder is online now
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
It sounds too lean to me, especially losing power when the nose is tilted up. Losing power after running for a while is a sign of over heating from being lean also.
downunder is online now Find More Posts by downunder
Old Jun 19, 2010, 11:26 AM
USA, CA, Oceanside
Joined Jul 2008
Yea now that I re-read it I am confused
Here, try this for help http://www.hooked-on-rc-airplanes.co...ning-tips.html
Old Jun 19, 2010, 04:09 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Recheck all your plumbing, especially that inside the tank. Make sure clunk is free and no holes or disconnected lines inside the tank.
Rodney is offline Find More Posts by Rodney
Old Jun 19, 2010, 07:29 PM
Chris_S is offline
Joined Jun 2010
Its an Enya brand, like .15 or so. Not a big engine.
Old Jun 19, 2010, 08:00 PM
Wayne V is offline
Find More Posts by Wayne V
Wayne V's Avatar
London, Ontario, Canada
Joined Jan 2006
What prop are you running ?, too big of a prop can also load the motor too much and make it overheat which will cause a loss of power.
Wayne V is offline Find More Posts by Wayne V
Old Jun 19, 2010, 09:56 PM
Chris_S is offline
Joined Jun 2010
The original prop, which was wood, broke so I got some new synthetic ones that were the same size. I used to have the "scimitar"-shaped props which seemed to greatly aid in climbing power, but theyve since broke and i havent got new ones. Now I just have the normal shaped ones.
Old Jun 20, 2010, 02:30 AM
downunder's Avatar
Joined Sep 2003
Uh oh...that might be your problem. If it's an SS15 then they're ABC but if it's a 15-V or earlier then they use an iron piston which needs a fuel with at least 20% all castor, normal RC fuels will make them overheat/wear out from lack of suitable amounts of decent oil.
Old Jun 20, 2010, 03:49 AM
Chris_S is offline
Joined Jun 2010
A friend of my dad's who flies RC or something suggested a while ago that overheating could be a problem. So is that 20% castor fuel still available? And btw, the link was very helpful... Never knew that part about never letting it run lean.
Old Jun 20, 2010, 09:56 AM
downunder's Avatar
Joined Sep 2003
There are a number of companies in America that make a suitable fuel for the Enya so your best bet is to go to different company's web sites and check out their blends. Don't bother going to Morgan though, I know for a fact they don't have one. Try Sig, Fox or similar. Those Enyas are very good engines and if you treat them right they'll last practically a lifetime .
Old Jun 21, 2010, 05:20 AM
Chris_S is offline
Joined Jun 2010
If its lasted this far, with the amount of abuse it has been put thru, I think it'll be fine. At least I hope so, anyway. It used to be my dad's and he tinkered around with it awhile when he was a kid, but he never got around to flying it.
Old Jun 27, 2010, 03:21 PM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Its not the fuel it's the mixture of fuel and air...sounds too lean to me too much air.....ask a more seasoned flyer to help you tune your engine
jetmech05 is offline Find More Posts by jetmech05
Old Jul 25, 2010, 04:55 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
btw tune the engine (needle setting) so that when you hold the plane with the nose at about 45 deg the engine runs fine; this is ussaly a few steps rich (open) then full power when the plane is horizontal.
btw is your prop a 8*4 size?
cmulder is offline Find More Posts by cmulder
Question twin wing one engine quits before the other..why? grfcon Electric Plane Talk 4 Jan 02, 2010 11:53 PM
Help! Hangar 9 P51 PTS Evolution Engine quits above half throttle! iflyer Fuel Plane Talk 7 Nov 27, 2009 03:12 PM
For Sale MDS .40 glow engine and OS .40FP glow engine hoofhearted Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 29, 2007 02:29 PM
Aerobird engine quits Brian O. Beginner Training Area (Aircraft-Electric) 25 Oct 22, 2005 10:17 PM
Engine quits in the air... miamiquasar Engines 6 Sep 06, 2003 06:06 PM
