Old Jun 14, 2009, 10:12 PM
starzak is offline
Find More Posts by starzak
Tye
Chacotoma, NM
Joined Jan 2004
Leon Shulman's Zomby
In the June issue of Model Aviation, page 58, Mr. Shulman offer's his plan for a blue foam Zomby. He uses an AXi 2208-34 motor together with a Jeti 8 amp ESC. The next larger Jeti is a 12 amp unit, without that much price difference. Being an electric "newbie", would it be to my advantage to select the larger 12 A. ESC ? Or .... Would the 8 A. ESC be perfectly adequate. He uses a 2 cell lipo. Is anyone else out there using a similar set-up, and any additional information for improving the system in this plane would be greatly appreciated.
Thanks for your help.
zak
starzak is offline Find More Posts by starzak
Old Jun 14, 2009, 10:28 PM
Xpress.. is offline
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
No harm in going up to the 12amp other than increasing weight from the larger ESC.
Xpress.. is offline Find More Posts by Xpress..
Old Jun 15, 2009, 12:55 PM
starzak is offline
Tye
Chacotoma, NM
Joined Jan 2004
Xpress, excellent point my friend !
Would you or any one else here, happen to know the weight differnce between the 8 amp, and the 12 amp JETI brushless ESC ? ? ?
Thanks again for your help.
> zak
Old Jun 15, 2009, 01:09 PM
SuttonSV is offline
Find More Posts by SuttonSV
SuttonSV's Avatar
New York
Joined Aug 2008
8 amp is 7 grams:
http://www.hobby-lobby.com/advance_p..._2967_prd1.htm
12 amp is 10 grams:
http://www.hobby-lobby.com/advance_p..._2968_prd1.htm
SuttonSV is offline Find More Posts by SuttonSV
Old Jun 15, 2009, 04:05 PM
Xpress.. is offline
Hitec RCD CSR
Xpress..'s Avatar
Joined Oct 2007
3 gram difference, not a whole lot for the zomby
Old Jun 15, 2009, 09:14 PM
starzak is offline
Tye
Chacotoma, NM
Joined Jan 2004
Thanks for your input guys.
My primary concern is knowing if the JETI 8 amp ESC is robust enough, to deal with the power surges between the AXi 2208-34 brushless motor, and a 2 cell Li-Poly battery. What do you think ?
Thanks again.
zak
Old Jun 15, 2009, 10:17 PM
lmopar69 is offline
Find More Posts by lmopar69
Team Cobra!!! Ssssssss!
lmopar69's Avatar
United States, NE, Doniphan
Joined Feb 2005
I run a few AXI 2208/34 motors on 3S with 10x4.7 props. I have an 18 amp ESC on them. Guess I'd rather be safe than sorry. Personally, I would go with the larger one in case you ever want to step it up to a 3S lipo.
Laine.
lmopar69 is offline Find More Posts by lmopar69
Old Jun 16, 2009, 03:23 PM
starzak is offline
Tye
Chacotoma, NM
Joined Jan 2004
Laine.
Thanks Laine. I think that I am going with your good advice, and buy the 18 amp unit. Would you happen to know how much heavier the 18 is over the 10 amp unit, which weighs 10 grams ? ? ?
Thanks again.
Ed
Old Jun 16, 2009, 11:38 PM
lmopar69 is offline
lmopar69's Avatar
Joined Feb 2005
I dont know, but I wouldnt worry about it. If a couple grams makes any difference that you can notice, I'll be VERY surprised. Ounces, I MIGHT worry about... grams, I wouldnt pay any attention to.
Laine.
Old Jun 17, 2009, 11:42 AM
Lost_Dawg is offline
Find More Posts by Lost_Dawg
S.E. Michigan
Joined Feb 2006
Go for the larger capacity ESC. It will give you more versatility for use in other/next planes. 3 grams just isn't going to matter unless you are a serious perfomance geek or a competitor.
Lost_Dawg is offline Find More Posts by Lost_Dawg
Old Jun 17, 2009, 02:48 PM
starzak is offline
Tye
Chacotoma, NM
Joined Jan 2004
Well the Jeti 12 amp = 10 grams, and the 18 Amp = 21 grams, per the Hobby Lobby catalog, so that's an 11 gram difference ! .
So I'll need to consider that. The plane I'm considering is on page 58 of the June issue of Model Aviation. It's Leon Shumans Zomby. Please take a look at it, and tell me if it has enough wing area to handle the 18 amp Jeti ?
Thank you for your inputs.
Ed, electric newbie
Old Jun 17, 2009, 04:57 PM
lmopar69 is offline
lmopar69's Avatar
Joined Feb 2005
I have looked at the Zombie in the magazine, it wont notice 11 grams. Go for the 18 man. However, I would go with a Castle Creations Thunderbird 18. I have used many of them and they work great. might be lighter too.
Laine.
Old Jun 17, 2009, 05:09 PM
starzak is offline
Tye
Chacotoma, NM
Joined Jan 2004
" I would go with a Castle Creations Thunderbird 18. "
Thanks Laine. And the AXi 2208-34 motor would work OK with the Castle Creations 18 ? ? ? Remamber, I'm a raw newbie here Sorry ! Is this a good motor ?
And what mail order company handles Castle Creations ?
zak
Old Jun 17, 2009, 05:12 PM
lmopar69 is offline
lmopar69's Avatar
Joined Feb 2005
Hobby-Lobby carries them, so does Tower Hobbies, you can order direct from Castle Creations and there are many other places that have them too.
AXI's are excellent motors. I have 10 or more of them. They cost a bit more than some of the "economy" type chinese motors, but in this hobby, you pretty much get what you pay for. If something is REALLY cheap, its probably for a reason.
Pretty much any brushless ESC will work with any motor. The only real concern is voltage and amp draw.
Laine.
Old Jun 17, 2009, 06:09 PM
lmopar69 is offline
lmopar69's Avatar
Joined Feb 2005
Oh, and the CC Tbird 18 is 17 grams, so its right there in the middle.
Laine.
Discussion Leon Shulman's Zombie starzak Vintage & Old-Timer Designs 15 Nov 25, 2009 01:17 PM
Discussion Shulman's ZOMBY Mcgivern Vintage & Old-Timer Designs 7 Apr 26, 2009 04:13 AM
For Sale Jason Shulman's Toc Fiberclassics Extra 330XL 3 METER awschucks Aircraft - Fuel - Airplanes (FS/W) 0 Jul 07, 2006 05:05 PM
Jason Shulman’s ¼ scale Extra 260 video fbw4 Sport Planes 7 Mar 28, 2004 09:31 PM
Jason Shulman's Exhila ARF Aviv Giladi Sport Planes 15 Jul 16, 2003 06:33 AM
