Old May 08, 2009, 01:03 AM
FairlyFaded is offline
Find More Posts by FairlyFaded
Registered Snoozer
FairlyFaded's Avatar
Palo alto CA
New Product
Testing the waters: Large, cheap packs?
Hello. I have recently acquired a large quantity of Sony 26650VT cells which I plan on using for an EV project.
In short, I am wondering if you folks would be interested in me putting together some large packs.
Here is the story of these cells:
The cells are from a certain power tool company that had a defective battery pack design. The BMS board broke after the first charge on many of the packs. If this did not cause a failure, then the poorly welded battery straps connecting the cells were next in line. The battery packs were re designed (old designer was fired?) with 5 spot welds and a new BMS board. These cells are warranty returns. The bulk of them received no more than a few charge cycles.
Now on to the specs:
Rated Capacity - 2500mah
Tested Capacity ~2200mah
Voltage - 4.1v - 2.5v
Energy Density - 250wh/L
Max. Output - 50 amps
Weight - 90g
Size - 26mm x 65mm
Here is a forum posting about them:
http://www.rc-monster.com/forum/showthread.php?t=10178
They are similar to A123 in ways (long life, safe). They are heavier however, and are happy with 10c continuous and 20c burst, unlike the A123's 30/60c.
I would be willing to put together packs for ~ 4$ per cell.
An example pack:
10S3P: 41v, 6450mah, 2735grams. Good for 65 amps cont. 120 amps burst.
$120 USD.
This battery would work very well for any sort of large sport flier, probably not so well for a 3D.
Tell me if you have any questions/are interested.
Michael
FairlyFaded is offline Find More Posts by FairlyFaded
Old May 08, 2009, 10:07 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
I'd suggest connecting with everydayflyer (Charles) over in the battery forum.
jrb is offline Find More Posts by jrb
Sold Large Lipo packs cheap Steve H. Aircraft - Electric - Batteries & Chargers (FS/W) 9 Apr 18, 2008 08:58 PM
FS: Large Lipo packs NEW Jet Dreams Aircraft - Electric - Airplanes (FS/W) 13 Aug 07, 2004 07:03 AM
Large, Cheap, Surplus Coreless Motors? Dave Hederich Scratchbuilt Indoor and Micro Models 5 Nov 07, 2003 06:51 PM
Testing the waters for selling my Venus Heli Slime Aircraft - Electric - Airplanes (FS/W) 4 Apr 01, 2003 10:50 PM
Best Charger for small. medium, large capacity packs microflyer77 Batteries and Chargers 1 Dec 19, 2002 10:08 PM
