Old Jun 17, 2006, 03:14 PM
Joined May 2006
Help!
GWS Moth 31.5 inch span.
I have just finished converting my rudder and elevator tiger moth to coupled ailerons by using 6mm depron for the wings but have left the tail end as is. I have also changed the motor to an EPS 350 C gearbox one as per the so called 3D model. I will be using 11.1v lithium polymers but am not sure which would be a good prop size to match. Also does anyone know
where the C of G should be? The model now weighs just under 14 ounces. Any advice appreciated. Thanks.
Tony77 is offline Find More Posts by Tony77
Old Jun 17, 2006, 06:18 PM
kensp's Avatar
Darwin Australia
Joined May 2002
Originally Posted by Tony77
Also does anyone know where the C of G should be?
If your wings have exactly the same area, sweepback and span as well as being mounted in the same place as the original wings then the CG will not change.
Ken
kensp is offline Find More Posts by kensp
Old Jun 17, 2006, 07:58 PM
Joined May 2006
Thanks Ken. Yes the wings are the same except that they now do not have any dihedral at all or any camber. Any ideas as to the prop size? Regards. Tony.
Old Jun 17, 2006, 08:16 PM
Joined Oct 2005
350c-c
I have also changed the motor to an EPS 350 C gearbox one as per the so called 3D model. I will be using 11.1v lithium polymers but am not sure which would be a good prop size to match. Thanks.
Tony 77;
From the GWS 350C-c chart they do not recommend more than 9.6Volts and less than 10 amps on the 350 motor so an 11.1 lipo is not good.
http://www.gwsus.com/english/product...em/eps350c.htm
Bob
bob2005 is offline Find More Posts by bob2005
Old Jun 17, 2006, 08:42 PM
Joined May 2006
Thanks Bob. Have taken on board what you say and might now re-think the situation. I'm still trying to get a line as to prop size though. Any views on this? Tony.
Old Jun 17, 2006, 08:49 PM
kensp's Avatar
Darwin Australia
Joined May 2002
The GWS web site for the 3D Tiger Moth lists an EPS-350D 6.6:1 geabox and a GWS EP1147 Propeller using 8 cells NiMh.
So for a 5.33:1 gearbox one would have to first try a GWS EP1047 and 2 cells LiPoly. MotoCalc predicts that this would be the best GWS propeller. For 3 cells I would go for the APC 9 x 3.8 Slowfly to drop thr currnt draw and pitch speed.
I think that with 3 cells that the thrust will be so greatly in excess of weight that it will be very sensetive to throttle when hovering.
Ken
Old Jun 17, 2006, 09:20 PM
Joined May 2006
Thank you once again Ken for your interest. I shall try the EP1047 and the 9 x 3.8 with two and three cells. As I don't have either of these props in my miserable collection, I shall have to wait until I visit my model shop after the week end. Tony.
Old Jun 19, 2006, 01:41 AM
Taipei, Taiwan
Joined Oct 2005
Hi Tony,
It'd be much better to use 9.6V NiMh pack or 2S LiPo pack with EPS350.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jun 19, 2006, 08:41 AM
Joined May 2006
Hi Chen,
Thank you for your message. I have several 2S LiPo packs but no NiMh so I will be trying the LiPos as soon as the weather permits. Thanks again. Tony.
Build Log The "Big P-40 Build" 70.5 Inch Wing Span JAM Foamies (Scratchbuilt) 1223 Jul 22, 2013 12:16 PM
Sold For Sale - Gee Bee R2 - Hobby Hangar/Adrian Page - 41.5 inch span TRP Aircraft - Electric - Airplanes (FS/W) 3 Dec 30, 2006 02:00 PM
Sold Gee Bee R2 - Hobby Hangar/Adrian Page - 41.5 inch span TRP Aircraft - Fuel - Airplanes (FS/W) 3 Dec 30, 2006 01:57 PM
5.5 inch span biplane room flyer billystiltner Scratchbuilt Indoor and Micro Models 59 Aug 21, 2006 02:59 PM
Discussion 2.5 inch span Ultra Micro Butterfly Joe Malinchak Scratchbuilt Indoor and Micro Models 22 Feb 05, 2006 03:39 PM
