Old Mar 12, 2002, 08:44 AM
Pennsylvania
Joined Dec 2001
Will 2mm coroplast work for elevons?
Yesterday I ordered some clear 2 mm coroplast. Will this be thick enough for elevons? If not can I double it up? I also ordered some 5.9 x 5.9 graupner cam race props, a new prop adaptor, and 12 500ar cells. I can't wait to test it out. I am going to make everything out of the clear coroplast. Last Friday I recieved my Kontronic drive 150. I should be drawing over 20 amps with this setup. I think this should give me the power I am looking for, but hopefully the weight of the extra 4 cells won't weigh it down too much for slow flight.
Hildy
HILDY is offline Find More Posts by HILDY
Old Mar 12, 2002, 08:50 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
What are you building, Hildy? A Zagi or other wing perhaps?
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Mar 12, 2002, 08:58 AM
Pennsylvania
Joined Dec 2001
Opps, forgot to mention that. I am rebuilding my Zagi Razor. I am not retaping it, just upgrading the power system, and making coroplast elevons, tray, canopy, and winglets.
Hildy
Old Mar 12, 2002, 09:01 AM
Pennsylvania
Joined Dec 2001
I am also thinking about reinforcing it with a carbon fiber rod. Where can I buy one?
Hildy
Old Mar 12, 2002, 09:04 AM
Owner of the real Petey
ghoward79's Avatar
Vista, CA USA
Joined Feb 2001
2mm will work fine for wing tips and in fact that size if preferred over 4mm for wing tips. 2mm will not work good for elevons because it will flex too much.
ghoward79 is offline Find More Posts by ghoward79
Old Mar 12, 2002, 10:21 AM
Lifes 2 short, go sloping
colorado @ 5500feet
Joined Sep 2001
I tried 4mm cloraplast for my elevons, they flexed way too much so I'd say 2mm won't work. Go with balsa if you put zagi tape over them they will be plenty strong, and use the 2mm for the winglets and make the flumes (channels) run vertical on them.
Vinnya42 is offline Find More Posts by Vinnya42
Old Mar 12, 2002, 10:47 AM
Pennsylvania
Joined Dec 2001
Thanks, I origonaly thought it would be better to run the channels in the winglets horizontal. I am just going to get some balsa from the lhs and cover them with tape.
Hildy
Old Mar 12, 2002, 11:40 AM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Why not channel the flumes horizontally? It allows air to pass through the winglet almost acting as an airfoil in itself. Vertically I would think would present more drag.
Just wondering.
mw
Old Mar 12, 2002, 12:15 PM
Idaho
Joined Oct 2001
I have used 2mil for elevons on a Mugi. Worked fine as a slope soarer. I dunno about using it for power flight though. On my IC .47 size planes I use 4mil as control surfaces. It works just fine. You can also layer two peices of the 2mil for elevons. Make one layer with the flutes running spanwise then put another layer on with the flutes running perpendicular. You can also stiffen up the coroplast by running bamboo skewers down the flutes. Or dowels that would fit.
Just FYI.
Josh
JayParke is offline Find More Posts by JayParke
Old Mar 12, 2002, 12:48 PM
SAM Elec GrdChmp04,07,10,12,14
Jay Burkart's Avatar
Smithfield, Ky.
Joined Sep 2001
Carbon fibre everything
Here's a good place to get all your carbon fibre
goodies.
Arero Space composites.
http://www.deltronix.com/public/acp/ACP-CAT.HTM
George is great to deal with.
I've bought a lot from them over the years.
Jay Burkart is offline Find More Posts by Jay Burkart
Old Mar 12, 2002, 01:09 PM
MX
Embedded Systems Engineer
MX's Avatar
Grass Valley, CA
Joined Sep 2001
I replaced the balsa elevons on my FMA Razor 400 with 2 layers
of the 2mm black coroflute. One layer is hinged and glued to the
TE of the wing, the second layer is narrower and glued to the
first to stiffen the elevons. It looks like they should work alright,
but they made the wing tail heavy. I still have to get it
balanced out before flying.
Click for larger image
MX
MX is offline Find More Posts by MX
Old Mar 12, 2002, 02:38 PM
Terry Dunn
mopar_man's Avatar
United States, TX, Lubbock
Joined Jan 2001
I think the 2mm doesnt have the torsional strength necessary for elevons. Stacking 2 pieces of 2mm would make the weight penalty of using coroplast significant. It would weigh much more than a similarly sized piece of 4mm coroplast (double the number of inner walls, plus any adhesive used ). 4mm is the way to go (flutes running span-wise). The taped balsa will work too.
MX, try a set of 4mm elevons and see if that fixes your CG problem.
mopar_man is offline Find More Posts by mopar_man
Discussion Will Cox RTF Warbird transmitter with mixing work for elevons? tooconceited Parkflyers 7 May 15, 2007 10:09 PM
will this charger work for a 7.2v 270mAh battery? littleflyer Batteries and Chargers 0 Nov 08, 2002 05:11 PM
Will the Atomic Force work for converting to the Corona? Frankenator Electric Heli Talk 4 Jan 24, 2002 09:33 AM
Will these components work for Corona LMH hnearnest Electric Heli Talk 1 Dec 02, 2001 12:12 PM
Will this setup work for TJ Jeremy_D Foamies (Kits) 2 Sep 17, 2001 09:34 PM
