Old Sep 21, 2014, 02:09 PM
Israel, Jerusalem
Joined May 2007
Saito 325 radial conversion to gas?
I want to convert my Saito 325 5 cylinders radial to gas. Mostly for reliability of running, and of course cost.
Does anybody know if there is a commercial kit for such a conversion?
S_YORAM1@BEZEQIN is offline Find More Posts by S_YORAM1@BEZEQIN
Old Sep 21, 2014, 03:10 PM
Complete RC Idiot Savant
The Netherlands
Joined Nov 2009
Not to start any methanol/gas or glow/spark war:
I think if reliability is the main goal, you're better off with Sparks, but stick to methanol.
Gas introduces a whole lot of other issues like mixture control (Glow carbs are not designed to provide the accurate metering of fuel needed for gas), additional heat, lubrication, power loss, etc etc.
CDI alone will reduce your fuel bill by roughly 20~25%, and in case you are running Nitro, you can leave that out and save even more, moneywise, from cheaper fuel, but volumetric the consumption will go down as well, by about the same percentage as the nitro omitted....
It will also gain you a little bit power....
But gas is an option, for sure, and if economy is the main goal above everything else, then that is the way to go....
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Sep 21, 2014, 03:14 PM
Israel, Jerusalem
Joined May 2007
The main concern is reliability. Radials on glow plugs tend to loose soemtimes the bottom 2 cylinders due to fuel accumulating there and cooling the glow plugs. My solution was to move to spark ignition, I don't mind so much the cost of the methanol, as much as i am concerned at the loss of power coming from loosing the 2 bottom cylinders.
I thought of a glow ignition system as a solution, but that is adding a big and heavy battery, to correct a reliability issue. Two wrongs don't make a right :-)
So i am looking for a 5 cylinders spark ignition system.
Old Sep 21, 2014, 03:30 PM
The Netherlands
Joined Nov 2009
I think there is not much weight difference between a 5 cylinder ignition system, and a Twin onboard glow.
If that (loosing the two bottom units) is your main concern and nothing else, on board glow is the thing for you, most likely you will like it even better than ignition.
Personally I would definitely go for the Sparks, but that is because I am a fan of CDI....
Brgds, Bert
Old Sep 21, 2014, 11:00 PM
Reginald's Avatar
Belgium
Joined Aug 2004
There are several manufacturers of onboard glow systems. Sullivan for example.
Reginald is online now Find More Posts by Reginald
Old Sep 22, 2014, 08:06 PM
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
Try and contact these guys. They have systems that are not listed on the site. I've seen a video of a guy running his 7 cylinder Evo engine with CDI.
http://www.ch-ignitions.com/
V2rider is offline Find More Posts by V2rider
Old Sep 22, 2014, 09:22 PM
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
CH-Ignitions has 5-cylinder CDI sytems that use a single hall sensor pick-up point & a unitized module.
As stated above, e-mail Adrian as the site doesn't even come close to listing all that is available.
Onboard glow for an engine that large is a waste of money. CDI will soon pay for he small added expense in fuel savings even when glow fuel is retained.
CDI methanol will give you all of the user friendliness of gas W/O the power loss associated when converting from glow ignition to a full gas conversion. It will also be more reliable.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Sep 22, 2014, 10:21 PM
Israel, Jerusalem
Joined May 2007
Thanks to all. I am in touch with Adrian, and I think I have a solution.
Wanted Saito radial - 325 collector ring swop grantypoo Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 28, 2014 03:42 AM
For Sale Saito R33R3 4-Stroke Gas Radial Slider403 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 23, 2014 12:46 AM
Wanted Saito radial - 450 or 325 grantypoo Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 08, 2014 08:21 PM
Sold Saito 325 radial davezagwyn Aircraft - Fuel - Engines and Accessories (FS/W) 6 Feb 25, 2014 06:40 AM
