Old Jul 25, 2013, 07:17 AM
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
APM on a Plane: UAV/FPV
Since quite a few of us Bixler(1/2) owners are using APM boards (Ardupilot Mega, Arduflyer, ReadyToFlyer etc), and the APM thread is mainly aimed at multirotors, I thought a Bixler-APM thread was in order. Many others in the Bixler 2 thread thought it was a good idea, too, so we made this Fixed Wing APM thread!
Basic info about setting up APM and peripherals can be found here (the infamous APM thread). The first few posts contain answers to most questions, so please, please, please read/skim that before asking here!
Especially for initial setup, you absolutely have to read about the basic topics explained in that thread. Otherwise you're gonna pay for it in money, waiting time, building time, frustration and of course crashes.
Build logs and pics are welcome
cmavr8 is offline Find More Posts by cmavr8
Last edited by cmavr8; Mar 23, 2014 at 04:08 AM. Reason: Changed links to APM thread
Old Jul 25, 2013, 07:18 AM
Chris
Joined Sep 2010
So here's my own build:
(external links to a wiki)
Overview
Electronics layout pics
More info about connecting OSD, GPS, making shielded wires etc
I am not copying the info from the wiki here, cause it's not static. I'm going to update the wiki with other people's info/pictures, so that everything is concentrated there.
Old Jul 25, 2013, 09:42 AM
United States, CA, San Diego
Joined Jul 2013
Thanks!
Thanks for creating this thread, and for adding the links to your configuration!
I found it interesting how you set up the internal wiring. Since I am in my initial build of my Bixler2, I was debating where to place everything. I didn't want to place things where I wouldn't be able to access them once the two halves were mated together, but maybe you aren't permanently joined.
I had debated placing my GPS at the outer part of one wing, but the new APM2.6's GPS has two wire sets (9 wires total). I would need to rig up my own wire harness and string it out to the far side. I do like the idea of shielding the wires - I was debating that or just using twisted pairs.
What was your reason for using the two BECs? Sounds like no one is trusting the ESCs any more.
Thanks again.
PhotoBoyJack is offline Find More Posts by PhotoBoyJack
Old Jul 25, 2013, 10:15 AM
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
You could add easystar to the list
irun4fundotca is online now Find More Posts by irun4fundotca
Old Jul 25, 2013, 02:48 PM
Burt KF7ULM
United States, AZ, Phoenix
Joined May 2007
Are you hand launching?
If so do you know your final weight?
Reason for the questions, I tried to setup my Bixler2 very close to yours, and COULDN'T hand launch it. I did finally get it in the air by setting it on my rc car.
It did fly great. Had to find the level point and set the APM up to that. The first few flights was nose high when switched to Stab.
Have stripped it of all electrons right now, but plan on rebuilding it soon for the flying season here in AZ, Only this time with landing gear.
Burt
Overview
burtgree is offline Find More Posts by burtgree
Old Jul 25, 2013, 03:03 PM
Chris
Joined Sep 2010
Yes, I decided to place the electronics so that interference is minimized. For example, high current wires (especially battery->ESC->motor) must not be close to the APM (magnetic interference).
I have my halves taped together, so I can separate them...
This is where I got the idea of using shielded cat5/6
Thanks again.
Yeah, two BECs for sure. One of them is too small for the servos, too. I should have used a 7.5A one. The other one is for the electronics. ESC's becs are linear. They create heat and tend to not be able to deliver their max amperage. A small UBEC's weight is nothing for this plane Better safe than sorry.
I'm really happy that you found the info useful
Old Jul 25, 2013, 03:06 PM
Chris
Joined Sep 2010
Burt
Yes, hand launching. Left hand, too (I'm right handed, and not very muscle-y). It needs a hard toss and almost full throttle. AUW is 1.2kg. Oh and 50% flaps down!
When all these were done, I had no problems. If I fail to do one of the three, it "lands" immediately.
Old Jul 25, 2013, 03:37 PM
Done Posting, Gone Flying
JNJO's Avatar
Sweden, Uppsala County, Balsta
Joined Jun 2012
Can I come too?
I made the first flight with ArduPlane on my FunCub today.
Not a Bixler, but I did chase a Bixler-like plane, does that count?
FC FPV (0 min 18 sec)
Worked right out of the box, but some fine-tuning is still needed.
Also, the MinimOSD firmware I'm using (MinimOSD Extra Copter) doesn't display the correct flight modes, and altitude is off by +16 Meters compared to Mission Planner.
I guess I'm seeing GPS-altitude.
What MinimOSD firmware are you guys using?
I can adapt the one I have, but getting a working version seems easier.
NVM, just uploaded Extra_PreRelease_Beta 2.4_Plane_r663 which sorted the flightmodes, and it turns out that altitude in OSD is MSL.
Not really useful that.
Has anybody managed to get it to display AGL? Not true AGL of course, but it would be nice to see altitude over home, like in Mission Planner.
Altitude is sorted now. It's called "Home Altitude" in the Config_OSD tool.
Fly safe,
/J
JNJO is offline Find More Posts by JNJO
Old Jul 25, 2013, 04:22 PM
GraKez's Avatar
Australia, QLD, Brisbane
Joined Apr 2013
Yay!
Great beginning to the this thread Chris, thanks for putting in the start-up work.
I have laid back at night going over & over wiring configs in my head, & seeing your photos really help!
One question is what range are you getting on your FrSky setup? I have FrSky too. I thought about putting my FrSky antenna there, but someone said that reception may drop off when you point your Bixler back to home (RX is behind FPV transmitter) I would be keen to hear about your range etc.
One comment: My version of FrSky receiver is also a transmitter for RSSI and so I wont be game to put mine that close to the GPS receiver. I was thinking of mounting my 8 ch receiver out on one wing.
Graham
GraKez is offline Find More Posts by GraKez
Old Jul 25, 2013, 07:31 PM
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
Originally Posted by JNJO View Post
Can I come too?
http://youtu.be/s4gGVIoQvwQ
Fly safe,
/J
Well, isn't the "Home Altitude" panel item what you're looking for?
From the wiki:
Home Altitude
This panel indicates your height above your home position in meters if you set metric system for units of measurement, and feet if imperial.
It works this way:
When APM boots and gets GPS lock, it checks your height above sea level than calibrates you barometric pressure sensor. After this it is using barometric height by default. From this moment, MinimOSD-Extra stores this height, than subtracts it from your actual true height. So you see the home altitude.
(You can change it in APM parameters to use only GPS to measure height, or only barometric height (this is default) or a mix of both.)
Cheers,
Geoff
gbmarsh is online now Find More Posts by gbmarsh
Old Jul 25, 2013, 08:05 PM
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
I am going to fly an FPV Raptor from Lanyu Hobby with the APM. Maybe a good idea to rename this forum to "Fixed Wing with APM"
JNJO, how to load new firmware to the MinimOSD? Use the mission planner?
Pattaya01 is offline Find More Posts by Pattaya01
Old Jul 25, 2013, 08:42 PM
Wait...what?
gbmarsh's Avatar
Joined Sep 2010
For loading firmware and character sets you will need an FTDI cable or breakout board and the minimosd extra config tool found here:http://code.google.com/p/minimosd-extra/
Also read the wiki for how to set it up here:http://code.google.com/p/minimosd-extra/wiki/index?tm=6
Hope this helps
Cheers,
Geoff
Old Jul 25, 2013, 09:39 PM
Joined Sep 2012
OK, thanks for the fast reply. So nothing I can do without some extra hardware.....
Old Jul 25, 2013, 09:53 PM
Wait...what?
gbmarsh's Avatar
Joined Sep 2010
Just one of these, cheap and easy to use
http://www.rctimer.com/product_684.html
Old Jul 25, 2013, 11:56 PM
Joined Sep 2012
It will be on my next order, thanks. Anthony.
Discussion Swapping electronics to HK Bixler or Bixler 2 High_Octane Beginner Training Area (Aircraft-Electric) 2 Apr 07, 2013 05:22 PM
Help! Need help with my FPV uav project. Soren64able Engines 9 Feb 02, 2013 04:00 PM
Sold HK Bixler with Retractable FPV Camera Mount....will trade crd FPV Equipment (FS/W) 4 Sep 24, 2012 07:39 PM
Sold FPV HK Bixler $35 Orcoz Aircraft - Electric - Airplanes (FS/W) 10 Aug 07, 2012 02:25 PM
For Sale Ardupilot Mega APM V1/900 MHz Xbee/Bixler Chassis - $300 shipped justjason Aircraft - Electric - Multirotor (FS/W) 2 Jul 13, 2012 01:22 PM
