Old Jun 04, 2012, 03:42 PM
DWTRIAC23
United States, MA, North Andover
Joined Feb 2012
Question
Increase radio range ?
Someone told me if you add another battery to your transmitter. Example, changing it from 6 volts to 7.5 volts that it will increase the range of your radio reception. Does anyone know this to be true??
dwtriac23 is offline Find More Posts by dwtriac23
Old Jun 04, 2012, 04:08 PM
Vroooom putta putta putta
SubtleT's Avatar
Joined Feb 2011
What sort of heli are we talking about?
On most of the low end sub-hobby products the Tx either takes 4 nominally 1.5V cells and uses a simple voltage drop to get ~ 5V, or 6 cells and uses a linear regulator to get ~5V.
I'd think bumpng a simple 4-cell Tx to 5 or 6 cells would merely risk frying the components.
Do you really mean "radio?" Most of the 4-cell Txs are IR as far as I can recall, and use IR LEDs as emitters. You might burn these hot for a little while - until either they go or the active eelctronic components go.
Your best bet is probably just to test your batteries every so often and replace the set when any start to fall, since there's some voltage sag. Along these lines use alkalines, since NiCds usually only run around 1.2V/ea.
SubtleT is offline Find More Posts by SubtleT
Old Jun 05, 2012, 05:33 PM
Different fly 4 different guy
gordonzo's Avatar
Canada, BC, Salmon Arm
Joined Jan 2011
I don't think the number of batteries has much to do with range. All of our 'doofy' MJX helis have 4 batteries. The I/R T38 (like s107) has range of about 30' direct sight. The 27Mhz F27 has a range of 30 paces (~90'), and I have flown the 2.4Ghz F45 most of the way down a 460' field. The MJX tx's also warn you when battery is low. I flew an F27 60+ flights on the original AA's and they still showed 5.6V.
My NE J6Pro uses 8 batteries and after 50+ flights with 3 different helis, the battery shows 'full bars'. It's range appears to be about the same as the doofy tx that came with my MJX F45.
regards . . . g
gordonzo is offline Find More Posts by gordonzo
Old Jun 05, 2012, 05:58 PM
DWTRIAC23
Joined Feb 2012
it is a Syma S033G and the transmitter is 27 Mhz
Old Jun 05, 2012, 06:00 PM
SubtleT's Avatar
Joined Feb 2011
Hah!
I remember that now. I suspect I'd confused a mention of an MJX heli with a JXD (Doof King). Apologies, I goofed, and I won't pretend to know anything about MJX helis.
I'll go correct that now.
Old Jun 05, 2012, 06:24 PM
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
I don't know about your radio for sure, but my guess is "no".
Each radio and it's circuit board is designed to work at a certain voltage. Because of that, a typical board has a voltage regulator at the point of entry for the power source. For instance, a radio might use 8AA batteries (12v) as a power source. But internally, the PCB only operates at 5v. So at the point of entry, it is regulates to just 5v. (My radio is that way, so now, I'm only using a 2S cell, about 8v to drive it.) So even if you bumped up your power source from 6 to 7.5, the PCB will see what it allows through. Therefore, you're not going to boost the signal that way.
Heli Pad is online now Find More Posts by Heli Pad
Old Jun 05, 2012, 06:50 PM
gordonzo's Avatar
Joined Jan 2011
Hah!
Doof King - Now that is funny! And so true!
T - you should try the MJX F45. It's a really nice step into fixed pitch and your back yard looks like it would be a perfect place to practice. You can even put it into mode 4 if you prefer that. It can handle a decent breeze, too, so it increases your flying days.
regards . . . g
Old Jun 05, 2012, 07:31 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Signal strength is determined by the transmitter and is regulated by FCC license. 27 mhz is intentionally low power output because it runs on the "citizen band" and is highly susceptible to interference and causing interference. Changing batteries will not increase power output.
Balr14 is online now Find More Posts by Balr14
Old Jun 06, 2012, 08:57 AM
SubtleT's Avatar
Joined Feb 2011
It's a good thought, and I appreciate the recommendation. Might even happen once I unload a few more small coax helis now that school is getting out.
Lots of mine get resold far below cost to kids in the neighborhood to play with inside on rainy days. I've bought some weird stuff and some of it isn't fun for long so there is no point in it sitting here taking up space. I let a lot of 3CH helis go for about $8, making sure they know they're getting a used bird. I won't sell to kids under 13 w/o a signed note from parents. I use a sort of form letter thing I made about battery hazards and potential injury from operating rotors they have to get signed. I've resold a few 4CH new at cost as well, sometimes having bought 2 or 3 to make sure I get a "good" sample - I've been amazed at the variation in some models from unit to unit.
Old Jun 06, 2012, 05:16 PM
DWTRIAC23
Joined Feb 2012
Yes that makes sense from what little i did learn in electronics class in school. Thanks for the info
Old Jun 06, 2012, 05:17 PM
DWTRIAC23
Joined Feb 2012
That makes sense...Thanks
Old Jun 06, 2012, 05:18 PM
DWTRIAC23
Joined Feb 2012
Sold DX7 7 Channel 20 Model Memory Full Range DSM RC Radio retiredjb Aircraft - General - Radio Equipment (FS/W) 1 May 14, 2012 04:56 PM
Discussion Range of my Radio M4d_D FPV Talk 0 May 07, 2012 09:15 AM
Discussion Walkera Radio Range Issues Only 60FT max. N8LBV Radios 9 Apr 04, 2012 10:07 AM
Discussion 12ch Radio relay for wireless long range UHF ground station i3dm FPV Talk 0 Mar 22, 2012 03:20 AM
Logo 10 - How to increas flight time? test3 Electric Heli Talk 5 Jul 11, 2003 01:28 AM
