Old May 12, 2011, 02:08 PM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
New Product
Winners Model's 49.5-in EPP YAK55M
Here comes another good choice for flying with a 3-cell 2200 mAh pack!
Specs:
- Wing Span 1256 mm (49.5 inch)
- Length 1248 mm (49.1 inch)
- Wing Area 37.2 sqdm (576.6 sqin)
- Flying Weight 920 g (32.5 oz) with no battery
- 130-160 gram KV900 Brushless Motor
- 40A Brushless ESC
- Propeller APC 13x6.5E
The plane is available here.
feda
feda is offline Find More Posts by feda
Old May 12, 2011, 02:27 PM
Renton, Wa.
Joined Feb 2006
There was a video or two of this somewhere. Seems to fly real nice. Real floaty too for that size.
stevelmaa is online now Find More Posts by stevelmaa
Old May 12, 2011, 02:29 PM
Renton, Wa.
Joined Feb 2006
Heres a link to the video
Winners Model EPP Yak55m Prototype No. 2 Test Flight (5 min 23 sec)
Old May 12, 2011, 04:24 PM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Thanks, Steve, for posting the video.
Here is another showing how to attach the wing:
Winners Model EPP Yak55m -- Wing Attachment (2 min 13 sec)
Old May 12, 2011, 04:27 PM
nac
nac's Avatar
Melbourne, Australia
Hey Feda,
With regards to "130-160 gram KV900 Brushless Motor" which is also what is needed for the MXS.
Are you able to suggest a few options?
nac is offline Find More Posts by nac
Old May 12, 2011, 04:39 PM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Originally Posted by nac View Post
Hey Feda,
Hi nac,
The one I am using is probably close to what you are using, i.e., usable but not as powerful as you would like. The one I am using won't get hot at all in flight, therefore I guess I can push this motor a little more. I have ordered a higher KV (1000) version for testing to see if it can yield more power. I'll try to do some search and get back to you.
feda
Old May 12, 2011, 05:11 PM
nac
nac's Avatar
Thanks.
Mine is not getting hot at all, but I can't seem to get more performance out of it even when propping up.
Old May 15, 2011, 11:50 AM
I like EPP
matk's Avatar
Victoria BC Canada
Joined Sep 2005
Mine Favorated model.Finally....
I was just thinking what SkyWing will come up next, then happend to see this at the site,but man this have to wait till I got the MXS flying.
Good job SkyWing.
Matk
matk is offline Find More Posts by matk
Old May 15, 2011, 04:45 PM
corsair214's Avatar
United States, IN, Danville
Joined Mar 2007
winners and skywing
Hi planes look awesome ... wish someone would carry them in the US so i could expand the fleet.. the shipping cost is the stopper for me
corsair214 is offline Find More Posts by corsair214
Old May 16, 2011, 01:14 AM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Hi corsair214,
I'll be receiving some in Canada at the end of May. Would you be interested?
feda
Old May 16, 2011, 12:05 PM
Renton, Wa.
Joined Feb 2006
Does this mean Feda that you are going to be supplying planes through Canada or just a select few?
Old May 16, 2011, 04:20 PM
corsair214's Avatar
Joined Mar 2007
skywing
Hi feda i would be interested in the mxs if you get some... thanks
Old May 16, 2011, 05:31 PM
scotland uk
Joined Jan 2005
Looks nice!
wishawhunk is offline Find More Posts by wishawhunk
Old May 29, 2011, 07:06 PM
Sniffing the glue
scamair's Avatar
United States, WA, Bellingham
Joined Aug 2010
just got mine!
scamair is offline Find More Posts by scamair
Old Sep 16, 2014, 10:45 PM
Israel Montoya
crackup007's Avatar
Joined Jan 2007
Yak 55M 3D EPP Airplane 1256mm 49.5"
Yak 55M 3D EPP Airplane 1256mm 49.4"
Yak 55M 3D EPP Airplane 1256mm 49.4" (3 min 59 sec)
Tengo que aclarar que este avión tiene el empenaje reconstruido, como viene de fabrica la cola la tiene super floja, lo probé con un sólo vuelo de nuevo y la cola iba para un lado y el avión para otro, le reforcé el empenaje con deprom de 3mm por las caras internas del EPP, desde la mitad del avión al timón con placas completas de deprom por cada cara del empenaje y estructure en triángulos transversales con el mismo deprom. El avión cambio radicalmente su vuelo y me quedo muy bien para poder usar baterías un poco más grandes, porque quedo un poco pesado de cola, pero esta perfecto para quitar el plomo que le puse en la nariz y usar baterías más grandes.
Specifications:
Motor: Turnigy 3639 750kv
ESC: F40 40A
Battery: Zippy Compact 4S-1800ma-35C
Servos: TGY 2216MG
Prop: Turnigy Ultra-light wood propeller 15x6
Altitude above sea level: 2,300 meters
Aún hay que probar otro tipo de Propela, voy a probar una Wooden Slow Fly 14x4.5 o 15x4.5. El motor tiene bajas RPM por eso soporta palas muy grandes y eso es bueno para el vuelo 3D
Así como me quedo pesado de cola se puede usar baterías fácilmente de 2200ma-4S-35c o tal vez una de 4s-2400ma-35c porque le puse plomos hasta el frente para que balanceara, así le quito plomos y le aumento tiempo de vuelo.
El tiempo de vuelo con la pala 15x 6 y batería de 4s-1800ma-35c es de 6 min. vuelo combinado, en el video no se voló más tiempo porque empezó a llover y mejor decidí aterrizar.
Hay que cambiar el Spinner por uno que tenga ventilación en el cono (para eléctricos) y permita que el motor se enfrié, con el spiner que se ve en el video se calienta un poco.
https://www.hobbyking.com/hobbyking/...mm_Yellow.html
crackup007 is online now Find More Posts by crackup007
New Product Another EPP Yak55m -- Winners Model 49" Yak55m SEPP feda 3D Foamies 7 Jan 06, 2011 10:27 PM
New Product Zerogravity Yak55M 49" ZeroGravity 3D Flying 82 Aug 19, 2009 09:19 PM
Discussion EPP Yak55M Indestructible practice plane 138gr AUW leadfeather Indoor Pattern/F3P 15 Mar 17, 2009 09:46 PM
Sold 2 NIB Slofly 28 SuperSlo-Acro's with 2 sheets of 9mm black EPP - $49 shipped shawn595 Aircraft - Electric - Airplanes (FS/W) 2 Feb 07, 2008 11:53 PM
