Old Nov 19, 2014, 08:23 AM
BENJAS's Avatar
Mexico, GTO, León
Joined Jul 2011
Spybird Eagle Ornithopter 1200mm (PNF)
guys who think this http://www.hobbyking.com/hobbyking/s...00mm_PNF_.html
ami apparently looks way too fragile
I do not understand, that the three servos
BENJAS is offline Find More Posts by BENJAS
Old Nov 19, 2014, 08:56 AM
Joined Aug 2013
Third servo is used to twist the diagonal spars fastening points and to help with turns ( when one of them goes up another one goes down and vice versa)similar to the next video :
Pls watch the last tird of the video.
da vinci history the worlds smallest ornithopter (5 min 14 sec)
ZTEX is offline Find More Posts by ZTEX
Old Nov 19, 2014, 10:58 AM
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
I wonder what the three-axis stabilization system is- think they have gyros in this thing too? Wonder if it has a glide-lock function.
KeithK is offline Find More Posts by KeithK
Old Nov 19, 2014, 11:32 AM
Joined Aug 2013
Fixed Wing 3 Axis Gyro System Overview (6 min 23 sec)
Not sure about the glide lock .Regarding pictures it doesn't have one but if the average dihedral and flapping amplitude aren't very high then it can glide relatively well when the wings are in upper dead point -which usually happen by itself when the motor is stopped.
Old Nov 19, 2014, 12:33 PM
Marcialtech's Avatar
Joined May 2012
you can try using this 3 axis gyro to save weight..
OrangeRX RX3SM Micro 3-Axis Flight Stabilizer w/DSM2 Comp. 4CH 2.4Ghz Receiver
http://hobbyking.com/hobbyking/store...arehouse_.html
I use FY-41 AP for my newest gen. Eagle Orni .. i also have a gyro for the pan and tilt camera onboard ( it's heavier but my big orni can handle the extra weight ).
http://www.feiyu-tech.com/product-en.php?id=32
Fred M.
Marcialtech is online now Find More Posts by Marcialtech
Old Nov 19, 2014, 01:23 PM
BENJAS's Avatar
Mexico, GTO, León
Joined Jul 2011
here a video, you say?
skyonme spybird (4 min 32 sec)
Old Nov 19, 2014, 03:04 PM
Joined Aug 2013
The video isn't very informative but based on what I've seen on take off and lending I will say it flies good, probably because of the wings construction much closer to Cybirds and Kakuta then to Kinkade. the prise is very good too and it's available in U.S. warehouse. The frame ,tail assembly remind me on some early Kinkade models.
I personally want to see how it turns only by the this third servo without tail assist.
Old Nov 19, 2014, 03:48 PM
Joined Aug 2013
Fred M.
My understanding is that it will come already equipped with this gyro stabilizer .
I beleave that is better to sale the ornithopter without it and to lower the price with $10 - 15 .
As about the weights
Old Nov 19, 2014, 04:07 PM
BENJAS's Avatar
Mexico, GTO, León
Joined Jul 2011
I think double the topic, sorry
http://www.rcgroups.com/forums/showthread.php?t=2192208
Old Nov 19, 2014, 11:01 PM
Wildlife Artist / RC Designer
DaVinciBrainchld's Avatar
Joined Jul 2014
I have one in my collection guys, and my recommendation is - don't waste your money. The design is not bad. It is a little on the fragile side, which I expected, but that wasn't the real problem. Each wing was twisted wrong and came with a shredded dime sized hole in them; bolts were mismatched; nuts were missing; bolts were missing; push rods weren't set up right; heavy adhesive was applied to secure one of the gears; and the nameless brand 3axis gyro was completely defective - leaving the bird with no servo control what so ever. Making matters worse there was no instruction manual either, and the manufacturer is a complete ghost - no name, address, or contact information anywhere, not even on the box. I knew it was a risky buy to begin with, but I still expected more for the money. On one hand I was pissed with all the problems, but on the other hand I bought it with the idea in mind that I was going to remake it completely anyway. In the end it would have been easier and cheaper to build what I wanted from scratch. Lol
Oh I almost forgot, it was assembled with the 3axis stabilizer mounted in such a position that it was touching the smaller gear. Turning on the throttle would have shredded it for sure!
DaVinciBrainchld is offline Find More Posts by DaVinciBrainchld
Old Nov 20, 2014, 10:05 AM
Joined Aug 2013
Spybird Eagle Ornithopter - HobbyKing Daily (2 min 34 sec)
Old Nov 20, 2014, 10:40 AM
Joined Apr 2001
I guess I am a sucker when it comes to ornithopters. But I just . Ordered one of these. We will see what happens.
Flyboy70 is offline Find More Posts by Flyboy70
Old Nov 20, 2014, 11:12 AM
Joined Jul 2014
I hope whoever assembles yours does a much better job than the person who did mine. Best of luck.
Old Nov 20, 2014, 02:52 PM
Joined Aug 2013
The "phantom" manufacturer web site :http://www.skyonme.com
Old Nov 20, 2014, 03:19 PM
Joined Apr 2001
Brain did you ever get you spybird to fly.
New Product Hobbyking Junkers JU-52 1200mm (PNF) Mikemynameis Scale ARF/RTF 562 Jan 24, 2015 05:03 PM
Sold Messerschmitt Bf.110 - 1200mm (PNF) klmehaffy Aircraft - Electric - Airplanes (FS/W) 2 Aug 10, 2014 10:48 PM
Sold Brushless PNF EPO Cox / Nine Eagles Xtra 300 ShokWaveRider Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Aug 09, 2012 06:57 AM
For Sale Brushless EPO PNF Cox / Nine Eagles Cessna Sky Eagle / Ranger ShokWaveRider Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 02, 2012 09:49 AM
Sold Techone Mini Christen Eagle, PNF f1honda Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Dec 12, 2011 07:38 PM
