Old Apr 25, 2013, 10:56 AM
froots loops
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
Esc cheap info ??
WHAT DO YOU THINK OF THIS
http://www.hobbyking.com/hobbyking/s..._ESC_2_3S.html
plug and play? for a quad
saskya is offline Find More Posts by saskya
Old Apr 25, 2013, 12:04 PM
United States, NJ, Manville
Joined May 2006
Never assume an ESC is plug and play....Always check the settings....Even if you think the low voltage cutoff is set right it is a good idea to set it again to what you want it to be...Remember that when using multiple ESCs one could shut off before the others causing problems...
skizziks is offline Find More Posts by skizziks
Old Apr 25, 2013, 12:07 PM
Joined Dec 2010
multistar = fail.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Apr 25, 2013, 12:27 PM
froots loops
saskya's Avatar
Joined Apr 2012
any suggestion small max 15amp cheap price plug and play?
Old Apr 25, 2013, 12:28 PM
Joined Dec 2010
What the heck is plug and play? Any esc that isn't running simonk firmware will need to be flashed first, HK carries no such thing (though this will change soon), so maybe hit up RCTimer or something?
Old Apr 25, 2013, 12:31 PM
froots loops
saskya's Avatar
Joined Apr 2012
if someone have the answer please post a link
Old Apr 25, 2013, 12:34 PM
Joined Dec 2010
http://www.quantumhobby.com/ZTW-A-Se...w12abec-mr.htm
Old Apr 25, 2013, 12:36 PM
froots loops
saskya's Avatar
Joined Apr 2012
great
any cheaper price?
Old Apr 25, 2013, 12:39 PM
Joined Dec 2010
http://www.hobbyking.com/hobbyking/s...ontroller.html + http://www.hobbyking.com/hobbyking/s...hing_Tool.html
Why are you so cheap anyway?
$15 for ESC is pretty reasonable, doncha think?
Old Apr 25, 2013, 12:43 PM
froots loops
saskya's Avatar
Joined Apr 2012
I am felling cheap today loll
Old Apr 25, 2013, 12:45 PM
froots loops
saskya's Avatar
Joined Apr 2012
why hobbyking do not sell flash esc with simonk firmware
it make no sense??
Old Apr 25, 2013, 12:46 PM
Joined Dec 2010
They will, when the time is right. Stop being cheap and buy BS12A and flash them.
Old Apr 25, 2013, 12:52 PM
froots loops
saskya's Avatar
Joined Apr 2012
ok
also going to MC Donald buying a cheeseburger at $1.25
Old Apr 25, 2013, 12:57 PM
Joined May 2006
Flashing the ESCs with simonk firmware will limit their consumer market to only multirotors, They also would have to pay some one to flash the ESCs which will drive up the cost unless they find some one like elton john who works for free...A good thing to do is to be 10 Amps above what your maximum demand of Amps will be for insurance...
Old Apr 25, 2013, 02:06 PM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
ORLY?
I use them on planes and gliders too. Forget that crappy stock firmware which you can accidentally reprogram on field (and go home, because you can't reprogram without instructions), cryptic throttle range setting, not-good-working brakes (i like 6/10 on most planes with SimonK FW, but some requires more, some less) and many other good features...
So - there's NO limit, maybe unusable on heli (yet?) because governor is missing.
ABLomas is offline Find More Posts by ABLomas
Found Info on Jeti 08 brushless esc rcbobcat55 Aircraft - Electric - Power Systems (FS/W) 2 Apr 14, 2013 09:50 PM
Wanted RCtimer or other cheap SimonK esc templton89 Aircraft - Electric - Multirotor (FS/W) 2 Apr 09, 2013 04:05 PM
Sold Phoenix 60 amp ESC cheap! xtremetoyz Aircraft - Electric - Power Systems (FS/W) 4 Mar 31, 2013 12:28 AM
Sold Brushed ESC cheap jurgencm Aircraft - Electric - Power Systems (FS/W) 2 Mar 27, 2013 11:06 AM
Help! Need a GOOD cheap esc combo for savage xs tired of fooling with the stock esc jcarter99000 Car Talk 15 Feb 18, 2013 09:32 AM
