Old Oct 20, 2012, 08:21 AM
Sweden, Gothenburg
Joined Aug 2005
Question
Matter of tailrotordirection
Hi guys
As topic,does it really matter which direction the tailblades are spinnng,most of the 3 d helis i come around the tail rotor spins upwash direction,have seen real thing spin downwash,so what do you think,reason for asking...on mine seaking the
Tailrotor is sitting on the left side seen upwards,this makes to turn the tailrotor
180 degrees if to use the trex one.
Looking on youtube for example guys who had make the seaking 500 mostly are using either a trex 500
Or hk 500, in this cases the just turned the tailrotor gearbox around making the blades spin downwash
And it just flies fine.
Just curios.
Cheers
Jack
viggen65 is offline Find More Posts by viggen65
Old Oct 20, 2012, 11:50 AM
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Jack,
I have had the same problem with my Align 600 mechanics in my Apache its also spinning the "wrong" way but it performs just fine.
No problem.
Jan,
Horseman is offline Find More Posts by Horseman
Old Oct 20, 2012, 12:12 PM
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
If you are running a belt driven tail you can aways rotate your belt 180* at the tail and reinstall gearbox and it will spin upwash.
However on a TT tail unless you add another gear in it some where eather up front at the mount or make a custom raised tail mod , the only way to change its direction is to flip the oneway bearing and change the direction of the main rotor.
cap231ex is offline Find More Posts by cap231ex
Old Oct 20, 2012, 04:58 PM
I convince things to work
The Netherlands
Joined Nov 2009
II have flown helicopters with different configurations, also forward or backward spinning.... never could really establish a noticeable difference in performance.
Mind: that is scalers exclusively. Possibly on high loaded 3D helicopters it does make a difference, but not on scalers.
For that, the velocity of the downwash is too small compared to the velocity of the tailblades.
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Oct 20, 2012, 05:30 PM
Sweden, Gothenburg
Joined Aug 2005
Brgds, Bert
Could be so, important thing is that it doesnt matter on our scalers, even the real
thing is spinning downwash on some types
Cheers
Jack
Old Oct 21, 2012, 12:06 PM
kin
Composite factory
Joined Sep 2007
In our experience , the tail rotor direction is nothing different if the linkage and rudder control rod keey same (Pull to add the pitch) . it is nothing different or maybe i can say (so hard to feel the different ).Just keep the rudder control rod (pull to add the tail pitch ) .And check carefully you gyro and gyro servo direct is right or not . some accident is from they change the concept when modification .
kin is offline Find More Posts by kin
Sold Dark Matter MCP X Night Blades Body Lights VIDEO Ifly_65 Aircraft - Electric - Helis (FS/W) 0 Apr 06, 2012 11:55 PM
Sold Dark Matter MCP X Night Blades Body Lights VIDEO Ifly_65 Aircraft - Electric - Helis (FS/W) 0 Apr 04, 2012 12:50 AM
Sold Dark Matter MCP X Night Blades Body Lights VIDEO Ifly_65 Aircraft - Electric - Helis (FS/W) 4 Mar 28, 2012 10:10 PM
Sold Dark Matter MCP X Night Blades Body Lights VIDEO Ifly_65 Aircraft - Electric - Helis (FS/W) 5 Mar 27, 2012 03:43 PM
Discussion Reliability - What matters? dbsanders FPV Talk 14 Mar 24, 2012 12:24 AM
