Old Dec 30, 2009, 10:49 PM
Joined Aug 2002
Originally Posted by Diggs View Post
<snip>This is my first TX with the sliders/levers on the sides, and I was not real impressed by their feel. I assumed these would be used for flaps, but moving them smoothly is going to prove to be a challenge. Might take some getting used to on my part, but I expected them to be more fluid in their motion. It's the first time I have ever tried levers on a TX like that, so maybe my impression of how they would work was a bit off. My only other small complaint, and again I think it is my inexperience with the TX is the touch screen. It works well, but the little exit door at the top right of the screen is kinda hard for me to hit with my chubby digits. Has anyone tried a stylus on the A9? Diggs
Originally Posted by Don McGill View Post
Seems that it would work fine, I saw this video earlier tonight with a guy using a magic marker. I would have tried it but mine Aurora9 is still in the wind as of yet.
1. Detents on the sliders are on the Aurora 9 software wish list thread
2. Hitec's little black plastic screwdriver with holder, supplied with standard Spectra Module, clips onto carrying handle and is a good tool for both the button and in need as a stylus - perhaps with one end blunted.
The Range Check / Bind Button is deliberately recessed to prevent the many problems presented with exposed buttons being accidentally pressed. [Exposed reset buttons have been the cause of frustration with other systems e.g. when Tx is stood up in case and lent backwards, button may be depressed by edge of case and model must then be rebound or when passing TX between users as in training without a buddy box.]
Both suggestions already with engineers in Seoul Kr.
Aurora A9 Undocumented Features - Mixes, Setups, Tips. (includes Spectra Pro and Optima RX features. {frequently updated}
Update 18Nov10: Screwdriver, with soft tip cap, now supplied with Aurora TX and original jpg attached hereto enlarged.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Dec 30, 2009, 10:54 PM
fatcat220's Avatar
Plano, TX
Joined Nov 2006
Diggs I stoled one of my daughter's DS stylus and it works great! I used it for the heavy portion of programming. For the field I'll use my pinky finger nail or whatever pointy object I have at hand.
fatcat220 is offline Find More Posts by fatcat220
Old Dec 30, 2009, 10:57 PM
NORDPAC S3
mfpage's Avatar
United States, OR, Estacada
Joined Jan 2009
Diggs
Yes, I like to use the stylus from my Palm Pilot, and I love it.
Mfpage
mfpage is offline Find More Posts by mfpage
Old Dec 30, 2009, 11:24 PM
We come in peace.
Synth's Avatar
Canada, BC, Penticton
Joined Feb 2003
The little radio that could!!!
Who would have thought this radio could have generated so much attention.
I have had this for almost 2 months now and am still amazed with this thing.
I should have paid a grand for this thing.(chuckle chuckle)
Synth is offline Find More Posts by Synth
Old Dec 30, 2009, 11:27 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I like the built in servo speed feature. Just did some mechanical retracts and and slowed them down just how I wanted
Don
The Don is online now Find More Posts by The Don
Old Dec 31, 2009, 12:46 AM
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Ok a few quick observations. First off let me preface this with the fact I have never really used any other TX besides a DX7, so the different nomenclature added a little to my confusion. Also let me say that so far I am extremely impressed with this TX, what little I have used it. Now a couple of things I need some clarification on.
Binding / ID Link - The manual confused me on page 19. Seems like you must power on the RX while holding in the recessed link button. Is that correct? IF so GRRRR! I assume that is what the switch is for in the kit. I forgot it was still in the box, thought it was for a glow plane RX pack or something. While I like the fact I don't need a little bind key to get it in bind mode, I don't have 4 hands to connect a deans and hold the something to depress that button all at once. If you don't have that switch then you are looking at a two man operation or some frustration. I will try out the switch next time, but I am not sure I am a fan of this setup. Again, the manual states
"Press and hold the button on the receiver, turn on the receiver. red LED is on solid, release the button on the RX. After RX is powered up, the red led glows solid and the blue LED flashes"
So exactly when do you depress the button and power on the RX?
2. RX size and antenna length. Wow, it wasn't easy fitting that into a Radian. I had to carve some foam and route the antenna wire, which is too short to run down the bottom of the model like intended for a 72mhz RX and too long to fit inside the cabin. I cut a trail for the antenna wire and taped over it so it is embedded in the foam. Small price to pay if I don't have another fly-away. But that long antenna will take some getting used too. But I hope it is longer for a reason
3. Model setup. WOW, how sexy is that! I love that portion of this TX. I can't figure out how to setup a delta wing yet, but will read back a bit. I am sure it has been covered, and I bet it is already an option. This is where the nomenclature bites me. Is it the Ailevator option? Sounds correct, but I have never heard that term used.
4. Just typing in the model name and my name was a HUGE HUGE leap from the DX7. I wanted to setup more models but didn't have time, speaking of, the A9 has kept me up past my bedtime as it is.
Once I figure out a few things, I am sure those little areas of frustration will go away quickly. And already I am very happy with what I have seen and I haven't gotten past the extreme basics at this point. The Cularis is going to be big fun to setup. Attempting a full house sailplane on the DX7 was asking for an aneurysm I glanced at the glider options and it was making sense in the menus, unlike the spektrum where I had to slave stuff and then setup odd mixes that were like Chinese arithmetic
I wished I had a few more nights before my next event on Saturday to play with it, but I am guessing I will get many questions from other pilots there, which will help me learn!
Diggs - Who is like a kid on Christmas at the moment.
Diggs is offline Find More Posts by Diggs
Old Dec 31, 2009, 01:17 AM
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by GhostRider32 View Post
The whole deal with the spc port is kinda strange to me. I realize why it's there but why would someone go to the trouble to put 2 batteries on a receiver when many times they won't put 1single adequate pack? Sure, a single pack can fail and if it does, ths spc is useless anyway since it won't drive the servos. All you'll have then is the telemetry telling you at what speed you struck the ground. I'f I'm going to use 2 batteries, it's going to be 2 a123 packs plugged in with y harnesses, at least you have a redundant supply that way. YMMV.
You have no redundancy, from what I read somewhere here or in other post.
Is either SPC or BEC/ESC, not both.
If SPC fails, even if you have Rx powered from ESC, you have no reception.
renatoa is offline Find More Posts by renatoa
Old Dec 31, 2009, 02:25 AM
Germany
Joined Mar 2004
Uli,
I have to respectfully disagree with this statement. The addition of the SPC to me seems even more reliable than using an external BEC. The SPC is for power to the RX only, where a BEC is typically used to power the RX and the servos. The Aurora 9 with its telemetry also can keep the pilot aware of voltages to a certain level. While all 2.4 systems are in fact prone to brown out conditions, I feel that Hitec has provided some additional features that make it far less prone to brownouts than any other 2.4 offering.
After all of my whining, I now have an Aurora 9 sitting here. I have already converted it over to Lipo and have bounced through the menus a few times. First impression is pretty much "Hell Yeah!" I had a few distractions tonight and haven't been able to spend as much time on it as I would like, but I am about to crack open the manual and install my first Optima RX in a Radian. I just finished putting the tail section on it and came down to get an RX to install and thought I would post real quick.
This thing feels more solid than my DX7. I read a dozen times if not more how others were shocked at the weight, and it still surprised me when I picked it up for the first time. This is my first TX with the sliders/levers on the sides, and I was not real impressed by their feel. I assumed these would be used for flaps, but moving them smoothly is going to prove to be a challenge. Might take some getting used to on my part, but I expected them to be more fluid in their motion. It's the first time I have ever tried levers on a TX like that, so maybe my impression of how they would work was a bit off. My only other small complaint, and again I think it is my inexperience with the TX is the touch screen. It works well, but the little exit door at the top right of the screen is kinda hard for me to hit with my chubby digits. Has anyone tried a stylus on the A9?
Well off to setup a mode on it and get under the hood a bit more. So far from what I have seen it is going to make my life much simpler and teach me a lot about my radio I have avoided learning in the past. The DX7 was certainly a challenge to program and setup. OH, the Keyboard function is uber sweet! NO more scrolling through letters... Yes!
Diggs
Hi Diggs,
the A9 is a fine transmitter. Beyond question a A9 is more sophisticated than a DX7 and it CAN be more safe, too.
But a reliable power source with proper wiring is mandatory. I have seen so many sloppy build models. Some "specialists" would be able to produce lockouts/resets with NASA RC equipment and they will have problems with the Aurora as well. That's for sure.
Regards
Uli
the avro is offline Find More Posts by the avro
Old Dec 31, 2009, 02:51 AM
Greece, Attica, Piraeus
Joined Jun 2004
I am used in flying very complicated setups in Uav planes so i can mention another reason for the SPC port.
I am using the same concept like the SPC port for over two years now in my UAVs as i power the receiver separately from the servos in order to avoid servo noise carried through the supply rail from entering the receiver and other sensitive stuff like GPS and a/d converters for various instruments.
What i do is to power the receiver from a BEC and a differential/common mode filter and the servo + rail from another.
The only servo wires that make it physically to the rx are the servo signal and ground wires.
You can't imagine what a noisy/bad servo can do to a 2000+ Euro plane in an instant...
Lately i also made a board with electronic fuses for each servo that monitor the servo current and decide what to do if a servo shows abnormal behavior.
Chris
hendrix is offline Find More Posts by hendrix
Old Dec 31, 2009, 04:05 AM
Joined Aug 2002
Spectra 2.4Ghz - Optima & Minima ID-Setup (aka binding linking) & Range Test
Ok a few quick observations. First off let me preface this with the fact I have never really used any other TX besides a DX7, so the different nomenclature added a little to my confusion. Also let me say that so far I am extremely impressed with this TX, what little I have used it. Now a couple of things I need some clarification on.<snip>
.<snip> So exactly when do you depress the button and power on the RX?
15 December 2012:
. New Minima Binding tutorial - Video
30 October 2012:
Hitec AFHSS ID-Setup (Bind) Spectra Module V3.01(0), Optima Transceiver 6, 7 & 9ch V2.02(0) & Minima Receivers - quick reference.
07 Oct 2011 - LED Update:
Blue LED on Optima V2.02 may not hold steady after ID setup, just a very brief flash.
Red LED then holds steady.
Cycle power both TX & Optima to complete and then range test as usual.
Current firmware for optimum performance:
. Aurora 9 V1.08(1) 10 July 2011
. Optic 6 Sport V1.04(1)
. Spectra 2.4Ghz Module firmware V3.01 18 April 2011
(How to update Hitec TX with fixed "modules" such as Optic 6 Sport & Optic 5)
. Optima 6, 7 & 9 Ch Transceiver Firmware V2.02(0) 07 Oct 2011
. HPP-22 Software Version V1.14(0) - 18 January 2013 (Details and pictorial "How to" install)
History - Instructions relating to earlier firmware now moved to bottom of page.
RANGE CHECK PROCEDURE: .
[see also Aurora Manual (page 20 ) under "Set-up and Use of the Hitec 2.4GHz System" - Range Check Function]
AFHSS - Power Down for Range Check is 1mw - tested to at least 1/4 mile.
a). Place the model on a wooden bench or equivalent, at least 60cm (two feet) above ground,
which is clear of any metal contamination, and tie down/secure safely. Small models can be held
in a safe position above waist level.
b). Receiver’s antenna should be in a Vertical position, 2nd antenna on 9ch transceiver at 90 degrees (Horizontal) position.
Antenna must not touch the bench or ground.
Transmitter to be held with TX antenna in a Vertical position.
c). Turn Transmitter On First then receiver and establish link.
d). Press the button on Spectra 2.4 Ghz Module for <3 seconds.
At first beep (red LED will go out if in Normal Mode and both LED will go out if in Scan mode), release button immediately.
Both Blue and Red LED's will start Flashing together with Continuous Beeping.
The <90-second countdown starts from the time button is released until beeping stops and the LED remain lit without flashing.
caution: if button is depressed for to long (6 sec), module will enter scan function and system will then need to be re-linked
e). Walk away 30m (100 feet) from the secured aircraft while simultaneously operating the controls on the transmitter.
Have an assistant stand to confirm that all controls are completely and operate correctly.
NB: It is imperative that all engine/motor equipped models are tested both with and without
the engine/motor running whilst throttle is moved up and down both slowly and rapidly through the full throttle
range to determine if there is any interference caused by the ignition system
(frequent cause of problems) or motor/ESC and if any vibration problems from bent shafts or bad propeller.
f). Exit the power-down mode.
Simply wait for the 90 seconds to expire and beeping stop or if wishing to stop power down
before the 90 seconds expires, press the button briefly again to escape.
(caution - holding button in to long will enter scan function set-up and RX will need to be re-linked)
g). Range Test without a helper holding/observing the model.
From system "Model" Menu, select "Monitor" then change Test INH to ACT and
Aurora will commence exercising servos automatically (at the rate set by the throttle).
Suggest model be secured on a stand/table so out of ground effect and surfaces more visible from 100'.
. Range Test - Check and Resolution of Range Failure may assist.
. Optima Transceiver (RX) - Servo Move Slower Than Usual - then Rebind.
...(Switched between Normal <> Scan mode with power off before process completed).
. Optima Transceiver (RX) - Servo Wag & Jerky Servo Movements Reasons & Cure - Do Not Fly With This Condition.
(...includes when switching on some ESC) .
. Optima Transceiver (RX) - Servos Stepping - Battery pack (power supply) failing under load.
h). If FAIL-SAFE is Deactivated, the FAIL-SAFE position settings are also deleted.
FAQ & Tips
1. Aurora 9 - After Market Accessories: Cautions re Opti-kill, Sparkswitch, Duralite, Powerbox
& ensure "R" type spark plug is in use.
2. If 2.4Ghz range test is short, try re-binding first.
(system may have been turned off in wrong order first time - refer procedures above)
3. Q. Receiver LED is correct but servos do not respond properly or appear sluggish to TX commands.
....A. This typically indicates that you have inadvertently switched into scan mode and then shut off the power
before the confirmation beep is heard to complete the mode change.
Solution = Continue to go through the rebinding process and eventually it will take.
....Q. I notice a beep from the module once in a while when flying, why?
....Q. I notice the blue LED flickers occasionally on Optima transceiver, why?
....A. A beep from the module and/or blue LED flickering on Rx indicates that your receiver battery voltage is
dropping too low under flight load.
This can result in a brown out if it drops too low.
Either battery is failing and should be replaced before you fly again or the Receiver battery/power supply
is simply not big enough to handle the current that all the servos draw under flight load. See also
. Aurora A9 Warning Alarms Battery voltage levels and consumption.
. Optima Transceiver (RX) - SPC - SPC connection & Lead Detailed plus Optima Current Draw/Amps.
. Hitec HPP-22 - Replacement Leads, Extensions & How To Update Optima buried in Models
4. Q: I disconnected the battery on my receiver, and the voltage alarm sounded on the transmitter
since I guess it was seeing 0 volts.
However, now I'm noticing that when I disconnect the battery, the voltage stays at its last
reading on the transmitter, and no alarm sounds?
....A: Because the telemetry cycles about 3 times/second, sometimes when you are unplugging the battery it
will sense the voltage drop and the warning will kick in, but sometimes it won't because once you unplug
the battery there is no signal going back to the TX.
This is a hit and miss thing due to the way the system works.
5. EP models without an On/Off switch:
Remove ESC lead and use the Loose Cell Battery Box & Switch harness
- Included with Aurora & Optima set to aid Linking and Set Up only for those with EP Models in lieu of using ESC/BEC.
[The Loose cell AA Battery Box Is Not intended For Use In Flight], or a switch harness and a 4.8<>6.0V battery pack.
Batteries must be fully charged, especially if loose NiMH in Battery Holder
6. Swap either standard or promo AFHSS 2.4Ghz modules between Teacher/Student TX to avoid
need for re-linking. (Aurora-Eclipse_Optic 6 and Futaba as listed)
7. Unexplained problems with Computerised Transmitters?
. Make sure battery is fully charged when programming.
. If Low Battery Warning sounds when flying - perform full range check, testing all mixes and trims before next flight.
This because a low battery frequently does not have the capacity to flash the trim and other adjustments to memory since TX was last turned on.
Programming and other trim adjustments are only saved at time or after transmitter is turned off.
NB: Like USB devices pulled out to quickly, If TX is turned off/on again to quickly, previous adjustments may not have been fully saved.
WARNING:
. If you are unable to accomplish a successful range check of 90 feet, DO NOT ATTEMPT TO FLY.
. Range check to be completed at the field, prior to first flight of the day, so as to be in the same RF environment.
. FAIL-SAFE settings should be checked every time before you run the engine/motor.
Update 18 Nov 2010:
Aurora Transmitter now includes the screwdriver (now with a rubber tip) that was supplied with
the 72 MHz Spectra module, Laser, Focus & Ranger TX to adjust trim pots.
. Use it to press the link button when binding a receiver to the transmitter.
. Use it as a stylus to navigate through the programming screens.
see also Aurora A9 - Stylus & Screen cleaner
HISTORY
For those using earlier firmware or wishing to revert:
18 April 2011: New Procedures to cover differences between Transceiver and Receiver.
Optima V3.0+, Optima Transceivers 2.01+ and Minima Receivers
(earlier versions? see original procedures below)
Hitec 2.4 GHz AFHSS Equipment Updates - V3.0 refer major amendments under 2.i[/B] and attachments
20 Apr11 2011:
"New "smart scan" is basically an easier way of picking a new set of channels per your environment other than going into
scan mode and then back to normal mode which is what is recommended to use.
Scan mode was nice that it picked a new set of channels each time, but really unnecessary and some of the downfalls with having to cycle power on
both the TX and RX made it inconvenient. First of all note that the Hitec team has never done the scan mode to normal mode trick as we use the
same channels picked by normal mode and have flown at all the major events with zero issues.
The only time we suggest you use the scan function is if you need to avoid another device or if somehow you are having problems at a specific field.
Linking telemetry and non-telemetry Rx's... the technology requires a different binding method.
When binding the Optima (telemetry) RX's you would utilize the same exact procedure that you are familiar with, but with the new Minima RX's,
you must push the link button again to get the blue light flashing. - Mike"
. AFHSS - Receiver Manual V3.0 (jpg attached below)
. AFHSS - Spectra Module V3.0
. Hitec Minima - How to Set Up ID (Bind) - Video.
Original Instructions:
AFHSS Spectra Module & Optima V1 & 2, Aurora V1.03 to early V1.08
1. AFHSS - Normal & Scan Modes Explained includes Redundant (Dual) Receivers.
2. Each system and module / receiver set is paired at the factory for your convenience.
Use the following Linking (ID-Setting) sequence as you add Optima receivers into other aircraft
to be controlled by your Aurora or another TX with a Spectra 2.4Ghz module installed.
Caution:
- System is in Normal Mode if the red LED is on both the module and receiver after connecting.
- System is in Scan Mode if the red and blue LED's are on both the module and receiver after binding.
Multiple (redundant) Receivers Cannot be used in Scan Mode.
Linking(ID-setting) when Transmitter is in Normal Mode:
25Feb11: attached a pictorial
a. Aurora - Turn on TX and while it is displaying the YES NO Transmit screen
> push and hold down the bind button > then press YES for transmit.
b. For other TX with Spectra 2.4 Ghz Module
- after installing the module on the transmitter, press and hold the button on the module,
turn on the transmitter, then release the button.
TX must be in PPM mode, will not bind if TX left in QPCM/PCM mode. Red LED will flash while it is searching for a receiver.
c. Press and hold the button on the receiver, turn on the receiver, red LED is on solid, release the button on the receiver.
Solid red and blue LED emits indicate it is linked with the module.
d. Solid red LED and blinking blue LED on the module indicate when the linking process is completed.
e. Turn Receiver Off First then Transmitter Off Last.
f. Turn Transmitter On First, red LED is solid on the module.
g. Turn Receiver On Last, red LED is solid, after a moment, when both module and receiver connected,
module will beep 4 times.
h. You should now have control over the model as the transmitter module and receiver are linked in Normal Mode.
Linking(ID-setting) when Transmitter is in Scan Mode:
a. For Aurora press and hold the button on the module, turn on the transmitter, then press
“Transmit Yes” on the front LCD screen, only then release the button.
For other TX, after installing the module on the transmitter, press and hold the button on the module,
b. Press and hold the button on the receiver, turn on the receiver, red LED is on solid, release the button on the receiver.
c. Solid red LED and blinking blue LED on the module indicate when the linking process is completed.
d. Turn Receiver Off First then Transmitter Off Last.
e. Turn on Transmitter first, red LED is solid, blue LED is blinking on the module.
f. Turn Receiver On Last, red LED is solid, after a moment, the blue LED will also come on, and the module will beep twice .
g. You should now have control over the model as the transmitter module and receiver are linked in Scan Mode.
2. i.) Spectra 2.4GHz Module Firmware Version 3.01 - Update Released April, 18th, 2011
Changed “Scan Mode” to less complex “Scan Function”
Added compatibility with Hitec’s non-telemetry 2.4GHz receivers
Improved LED indicator error after Scan is done
Minima RX (non telemetry) can only be used with Spectra 2.4GHz modules which have been upgraded to V3.01.
New Manuals:
Spectra 2.4GHz Module Firmware Version 3.01 - manual V3.0 Manual - Addendum re Range Check.
Hitec 2.4GHZ Receiver V3.0- manual
Note-
ID Setting (Bind) must be done within 15ft. (5m) of the transmitter and receiver.
- Transmitter and receiver need to be at least 18in. (45 cm) from each other to bind correctly.
- In the ScanMode, if the transmitter or receiver has been shut off or disconnected for more
than one second
, both module and receiver need to re-boot (turn the power off, and back on)
- thus ScanMode cannot be rebound in flight.
LED Status Card . Digital .pdf copy which
can be printed and inserted as a page in manual or extra cards made.
3. Normal / Scan Mode - Switch:
Press and hold the Spectra 2.4Ghz Module button for six seconds.
Once two continuous beeps are heard, release the button immediately.
(Refer Module LED Status Indicator attached)
(Transceivers to be used will also then need to be relinked (rebound).)
4. SPC plug must be installed if not using a separate battery to power RX or on initial start up with
high power servos, RX voltage dips below reset (brownout) voltage.
Please refer to Optima RX - SPC Cable and use and attachment for full details.
. Optima RX - Multiple Batteries may be installed Dual batteries for redundancy or even one for each servo, may also assist.
. Optima working when powered via ESC/BEC but not when using a battery pack - FAQ
(ensure ability of pack under load, AAA batteries fail under even small loads)
5. POWER DOWN - Normal Mode & Scan Mode for Range Check as above:
Hitec USA Support Forum Sticky: Aurora A9, Spectra Modules & Optima Transceivers
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
[Right click RCG attachments and open in new window.
Button bottom right of IE screen (or _+icons Firefox Toolbar) enables viewing size increase upto 400% for easier reading.]
Old Dec 31, 2009, 04:42 AM
Rpinto's Avatar
Almada - Portugal
Originally Posted by Rpinto View Post
I think that the curve in the ABR-ELE mix should be ajusted by points, to permit a "linear ajustment" to the gliber beaviour. Any glider guy here who understand what I m trying to say?
A.T. or Mike,
Can you please check this issue, at least let me know if I m wrong, because if I m not this is important for the new firmware release.
Rpinto is offline Find More Posts by Rpinto
Old Dec 31, 2009, 05:05 AM
Joined Sep 2007
There is a special thread for future Aurora sugested developments / firmare fixes reporting.
If not implemented, add it there too, as a proposal.
Old Dec 31, 2009, 06:28 AM
Sydney, Australia
Joined Dec 2005
I use a stylus for the Ipod like the one below. My fat fingers can't seem to get the sweet spot most of the time when using the touch screen. The stylus works perfectly and is pretty cheap too.
http://www.daydeal.com/product.php?p...21236&cat=2751
orcrest is offline Find More Posts by orcrest
Old Dec 31, 2009, 06:36 AM
udogigahertz's Avatar
Deutschland, Nordrhein-Westfalen, Geilenkirchen
Joined Aug 2007
Originally Posted by the avro View Post
I used Spektrum over years in different helicopters and it works perfect without any problem. My Aurora works perfect as well. Nevertheless guys who experienced lockouts/voltage reboot issues with spektrum will make the same experience with a Aurora and all other brands, too!
Uli
Of course, they will. That's why the Aurora Receivers have got the "SPC"-socket. Use this and no more problems with lockouts/voltage reboot issues.
Udo
udogigahertz is offline Find More Posts by udogigahertz
Old Dec 31, 2009, 08:46 AM
Turtle_Flyer's Avatar
Joined Oct 2007
Diggs,
I have the same kind of problem with my phone sometimes. The corner touches do not seem to trigger. Re-calibrating the screen takes care of it.
Turtle_Flyer is offline Find More Posts by Turtle_Flyer
For Sale FS - Hitec 600mah 9.6V NiCd Transmitter Battery Pack - Good Condition freedomflyer Aircraft - Electric - Batteries & Chargers (FS/W) 4 Aug 07, 2006 04:15 AM
WANT! Hitec Flash 5 Transmitter! jocappy Aircraft - Electric - Airplanes (FS/W) 1 Jun 13, 2002 10:04 AM
Wanted >= 4 channel Hitec (or compatable) Transmitter OverHeadCam Aircraft - Electric - Airplanes (FS/W) 3 May 28, 2002 10:56 AM
FS Hitec Prism 7X Transmitter mt_100 Aircraft - Electric - Airplanes (FS/W) 2 May 20, 2002 07:30 AM
WTB: Hitec Flash 5 Transmitter stevevanwagner Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2002 10:29 PM
