Old Apr 18, 2007, 07:08 AM
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Which LockTite where???
I am assembling my first heli and saw that it is good to use locktite.
There are 3 types
Blue - weakest
Green - for bearing installs - How? Anywhere else?
Red - torch to remove!
which do I use and where?
Do I use it on set screws and frame screws as well? Where shouldn't I use it?
Frank
Fly2High is offline Find More Posts by Fly2High
Old Apr 18, 2007, 11:29 AM
Slowly Approaching 1,000
Detroit (area), MI
Joined Mar 2004
BLUE.
Which helicopter?
philosophicle_1 is offline Find More Posts by philosophicle_1
Old Apr 18, 2007, 12:56 PM
Heli Hooligan
London
Joined Dec 2006
Finless Bob made a video all about Loctite, the different colours, where to use it and how to apply it. I'm on my cellphone right now and don't have the link at hand. Just do a Google search for Finless Bob build videos.
mahbouni is offline Find More Posts by mahbouni
Old Apr 19, 2007, 11:02 AM
Manchester,UK
Joined Nov 2003
I use Loctite 222(purple) on all metal to metal and Loctite 603 (green) Retaining compound for bearings.
Loctite 222 is all you will need on metal to metal,anything stronger and it might be a problem getting things loose,its easy to remove even on small set screws.I use it on my 1/8th IC buggy and those things vibrate and not lost a bolt,nut or set screw yet.
Generally you use stronger loctite's on lager nuts,bolts etc as theres less chance of snapping or rounding heads,or bolts that wont need to be removed after assembly.
jossUK is offline Find More Posts by jossUK
which cosel and where? asjeep Batteries and Chargers 6 Aug 02, 2004 01:29 PM
Sky Tach....which model and where? CWallace Electric Heli Talk 7 Jan 20, 2004 03:03 PM
Which cells and where Peter Boyd Batteries and Chargers 10 Nov 30, 2003 05:33 PM
which is the website where you make an offer cruzomatic Electric Plane Talk 6 Apr 17, 2003 06:42 PM
Which batteries? (and where to get them) CruzThs Electric Heli Talk 5 Jul 16, 2001 08:10 AM
