Old Aug 08, 2014, 03:59 PM
Joined Aug 2014
Long Range FPV Equipment
New here, so hey everyone.
I have a phantom 2 with a gopro on a h3-3d, i can get over 1km range on the standard 2.4ghz controller radio equipemnt with a panel antenna. But i cant seem to get any decent fpv range.
Have tried 5.8ghz using a immersionrc 700mw tx and a black pearl monitor with built in 5.8 rx but can only get around 400m range with this.
Tried 900mhz 1000mw tx with a standard rx and get about 800m range with this: http://www.ebay.co.uk/itm/281395021979
Tried 1.2ghz 700mw tx with a standard rx and get about 600m range with this: http://www.ebay.co.uk/itm/390895190943
Have tried all the above with both rubber duck antennas and clover leaf antennas but it's not that much better with either.
But i keep reading on here that people get over 2km range with a 200mw systems etc. So whats the best rx/tx/antennas to get this sort of range?
Thanks in advanced for any help.
boylin is offline Find More Posts by boylin
Old Aug 08, 2014, 06:40 PM
1fullbird's Avatar
United States, NE, Omaha
Joined Nov 2011
Good antennas will make a world of difference. I have gotten 3,500' with a 200 Mw 5.8 gHz using a IBCrazy Clover leaf and a skewplanner wheel on the base station. With a 400 Mw 1.3 using IBCrazy over a mile. Some of the "cheap" antennas perform poorly. Better to purchase from companies that cater to FPV like RMRC.
http://www.readymaderc.com/store/ind...ex&cPath=11_45
1fullbird is offline Find More Posts by 1fullbird
Old Aug 09, 2014, 04:58 AM
Joined Jun 2014
Something must be wrong. I have a 500mw transmitter and with the stock rubber duckies it came with, no special filtering or anything, I can get around 2 km.
cantremember is offline Find More Posts by cantremember
Old Aug 09, 2014, 10:10 AM
Joined Aug 2014
Which transmitter and receiver are you using?
Question Considering going long range for FPV, need advice robodeath Radios 2 Mar 20, 2014 11:16 AM
Discussion Long range FPV equipments recommandation whatala FPV Equipment 4 Mar 19, 2014 06:30 PM
Question What equipment should I use to get started in long range fpv? carlosduch FPV Equipment 3 Aug 31, 2013 02:45 PM
Wanted Meduim-long range FPV equipment. Toby Rice FPV Equipment (FS/W) 23 Apr 25, 2013 07:26 PM
Discussion Best equipment for long range ground based FPV? hogfarmer FPV Talk 0 Nov 28, 2010 09:39 AM
