Old Aug 02, 2014, 07:41 AM
Joined May 2014
Mikey's pusher adjustments
Hello
i've built mikey's pusher plane although i've changed view things,
i've removed the whole tail, making it almost a flying wing, i've placed stabilizers on both ends of the wing.
couple issues came up, is rudder,
there is no rudder at the moment, and thought of flying it with only ailerons / flaps, is this a smart / flyable choice?
the other issue is the control horn, should i place it at the middle of the ailerons, or at the end? position 1 or 2?
front of the plane
=......................................( 1 ).................................( 2)=
back
thank you for support
chargerz is offline Find More Posts by chargerz
Old Aug 02, 2014, 08:05 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
You're changing a known working design, and then asking will it fly ? Why change it ?
What are you using as an elevator ?
eflightray is offline Find More Posts by eflightray
Old Aug 02, 2014, 08:46 AM
Joined May 2014
thanks for respond,
changed it to fit a bigger propeller, yes i could have increased wing's length to fit a bigger prop but i've already made the wing,
as for elevator, flaps down for lift, up for landing,
although i could easily add an elevator,
Old Aug 02, 2014, 10:36 AM
United States, KY, Louisville
Joined Feb 2011
If you are using same control surfaces for ailerons and elevator it will work but only using flaps for up and down will get you a horribly flying plane you probably wont want to fly.
MunkyMo is offline Find More Posts by MunkyMo
Old Aug 02, 2014, 10:47 AM
Joined May 2014
guess i'll add an elevator, it will be very close to the propeller but better than nothing,
thank you for your respond
Old Aug 02, 2014, 02:29 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Any chance of a picture of your model ?
If it's Mikey's model, but without the twin booms and tailplane, then I think you will have a serious problem trying to fly it. Even as a flying wing it will need adjustments to the CG, some reflex, and elevons for control.
Old Aug 04, 2014, 07:38 AM
Joined May 2014
i'll try to post a picture later,
it's only the nose and the wing with a kfm2 airfoil
i've added an elevator now,
controls i have are the following
1-ailerons -> one up one down (for left and right turns)
2-ailerons -> both up or both down
3-elevator
4-throttle
i've rewired the motor to esc, motor sound is a lot higher and there seem to be a lot more thrust especially with new prop, looks like it's going to be a great model if other things get sorted
thank you for your support
i've added about 180g at the end of the nose to get the plane balanced, not so sure about CG so far
Discussion Mikey's rc FPV thread! torque roll FPV Talk 14 Oct 10, 2014 11:01 AM
Help! Mikey's RCA FPV v3 tx programming flohio117 Foamies (Scratchbuilt) 0 Mar 28, 2012 12:03 AM
Help! Mikey's rc Sport Trainer Motor and ESC help szymek.k3 Foamies (Scratchbuilt) 16 Jul 13, 2011 05:40 PM
Yippee! First FPV Flight = Success w/ Mikey's FPV Pusher Durtbag FPV Talk 14 Feb 14, 2011 06:35 AM
