Old Mar 28, 2014, 10:04 PM
Concordefan2's Avatar
Joined Jun 2013
1/9th scale Twin Otter build under way....
Since afternoon today, I have been slowly working on this Totter model to get it ready for a display tomorrow evening at another event for PIA. I'm working slowly on it as my sensation in right foot is slowly coming back that I lost 2 days ago during physio clinic visit.
It's one of many rare kits from early to mid 90's from Horizon Models and are pretty much extinct now. I happen to find one few months ago and it's being built.
Model Specs:
1/9th scale
Fuselage length: 63"
Wingspan 85"
It have fibreglass fuselage with with all bulkheads already installed. It even have landing gear mounts installed. Wing are foamcore sheeted. Core have control rods for throttles, nyrod cables for both flaps and ailerons. NO dihedral brace but I am making it now it from either 1/4" ply or 3/8" plywood sheet.
Both nacelles are 2 part, top and bottom, they arer made from HD abs plastic and have engine mounts and wing mounts already built with them.
Fin and h-stab plus elevators and rudder are also pre-sheeted and also have balsa tips glued on them.
Due to time constraints Its being built as complete as possible including being painted in PIA's 90's sports livery.
I hope to have it displayable by tomorrow afternoon as event starts at 6pm.
If I get time, I will install motors on it with props, other wise props will be mounted on a dowel with spinners on nacelles.
Concordefan2 is offline Find More Posts by Concordefan2
Old Mar 28, 2014, 10:12 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
PIA twin is Otter!
. . . .How cool is that . . . Great build Sam!
demondriver is offline Find More Posts by demondriver
Old Mar 28, 2014, 10:45 PM
Joined Jun 2013
Dihedral brace slot were cut into both wing half on my scroll saw, they were align later and balsa test brace was inserted to make sure slots were cut perfectly.
Old Mar 29, 2014, 12:13 AM
Joined Jun 2013
Wing tips before and after, wings were also lightly sanded...
Old Mar 29, 2014, 12:16 AM
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Cool model, keep up the good work!
WAGliderGuy is offline Find More Posts by WAGliderGuy
Old Mar 29, 2014, 01:43 AM
Joined Jun 2013
Thank you .....
Update:
Just applied first light coat of clear coat on the fuselage painted areas....
I will wait a bit and then will reapply couple more coats to give it that rich deep look.
Old Mar 29, 2014, 01:56 AM
Up-Out-&-Gone
Joined Mar 2007
Great sanding work on your Otter ' s wingtips Sam!
Old Mar 29, 2014, 03:57 PM
Joined Jun 2013
Fuselage is still under masking, 1hr 20 mins ago, painted the lighter green band on forward fuselage. it's drying now. still delicate to touch!....I still have to paint lighter blue band before fuse can come out of all the masking...
new ply dihedral brace was cut from larger sheet of 1/4" x 12" x 24" sheet and has been glued between both wing halfs. Once fully cured, this will become one piece wing!.
fin and rudder are fibreglassed on one side, waiting for full cure stage so other side can be fibreglass also. Leading edge and tip of the fin were sanded into proper shape before glassing...I think i'll be lucky if one side could be painted before 6pm...
Old Mar 30, 2014, 12:14 AM
Joined Jun 2013
Couldn't meet the target, small disaster happened but now once again working away...
Old Mar 30, 2014, 12:31 AM
Joined Jun 2013
Fin and rudder were glassed in evening, now ready for sanding, primer and paint.
Main wing's dihedral brace is now solid, this slot is ready to be filled with cap strips.
Fuselage's belly is almost dry with light blue band painted. soon i'll take the masking off.
Old Mar 30, 2014, 03:08 AM
Joined Jun 2013
Model is dry assembled 80%.....
Old Mar 31, 2014, 06:24 AM
ich bauen groß modell flugzeug
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Wow, Im Speechless Sam!
Keenan smith is offline Find More Posts by Keenan smith
Old Mar 31, 2014, 07:10 PM
Esteemed Noodler
United States, FL, Sanford
Joined Dec 2013
That paint job is looking pretty sharp; sign of things to come!
AirworthyPasta is offline Find More Posts by AirworthyPasta
Old Mar 31, 2014, 07:36 PM
Doushiyou12's Avatar
Joined Feb 2010
Looking sharp Sam.
Doushiyou12 is offline Find More Posts by Doushiyou12
Build Log 1/6 Scale 130" Twin Otter vonJaerschky Scale Kit/Scratch Built 73 Jun 05, 2011 06:18 PM
Sold Plans and Accessories for 1/6 Scale (130") DHC-6 Twin Otter vonJaerschky Aircraft - Fuel - Airplanes (FS/W) 2 Jun 01, 2011 08:54 PM
Build Log 1/6 Scale 130" Twin Otter vonJaerschky Giant Electric Planes 0 Apr 30, 2010 10:22 PM
Discussion 1/6 Scale Ryan STA\M build gets under way TwoTall Scale Fuel Planes 3 Dec 15, 2007 04:33 AM
1:1 scale - Virgin World Flyer under way georgeg Scale Kit/Scratch Built 0 Mar 01, 2005 06:37 PM
