Old Feb 02, 2013, 08:01 PM
United States, HI, Honolulu
Joined Sep 2011
Question
Cheap easy way to increase 2.4Ghz range
I just got a 1000 Watt 2.4GHz system and it came with a standard whip antenna. I am looking at an inexpensive way to increase the range. Does anyone know if this will do the trick: http://www.hobbyking.com/hobbyking/s...dproduct=15283. I don't mind it being directional.
I was also wondering about switching out the whip on the TX for a clover-leaf antenna -- will that work with this type of directional antenna and will the clover-leaf be a significant improvement over the whip?
Thank you
Eric Tessmer is offline Find More Posts by Eric Tessmer
Old Feb 02, 2013, 09:03 PM
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
it will get you lots of range. It will not perform very well at all with a cloverleaf! That is a linear patch antenna, 3dB loss when run with CP. Better off with the whip, make your own dipole, or upgrade to a V antenna since those are linear and work well for range.
You want range and stable signal when banking? dial up RMRC or TrueRC.net and get properly matched, well made CP antennas. The directional should be a helical, crosshair, gatling, ... whatever you can afford.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Feb 02, 2013, 11:15 PM
BEOWULF
North vancouver, B.C. Canada
Joined Apr 2008
Orrigionl lawmate tx antenna works great
Increase range with high dbi video rx antenna
David22 is online now Find More Posts by David22
Old Feb 03, 2013, 02:00 AM
Crashing is my thing.
MayMayDay's Avatar
Canada, BC, Vancouver
Joined Mar 2012
Watch this:
Antennas 101 - Polarization, Diversity & Gain Patterns (27 min 56 sec)
Then look over this (Step 1 & 2):
http://videoaerialsystems.com/how-to-choose-an-antenna/
MayMayDay is online now Find More Posts by MayMayDay
Old Feb 03, 2013, 11:51 PM
Joined Sep 2011
Thank you for all the help and thank you MayMayDay for the great video link and how to choose your antenna link - this was excellent and was just what I needed.
Old Feb 04, 2013, 12:15 AM
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
How To Make A Cheap WindSurfer Antenna to Boost Wifi Signal (4 min 14 sec)
Try a windsurfer antenna booster.
It works well, especially that it costs almost nothing.
scrtsqrl is online now Find More Posts by scrtsqrl
Old Feb 05, 2013, 11:31 PM
Joined Sep 2011
scrtsqrl - Thank you! I will definitely give the windsurfer antenna booster a try. If this works, it will certainly win the criteria for the cheapest, easiest, way to increase 2.4Ghz range.
Old Feb 05, 2013, 11:32 PM
scrtsqrl's Avatar
Joined Oct 2006
"Windsurfer" Antenna Booster. (5 min 3 sec)
Old Feb 06, 2013, 02:59 AM
Ascended's Avatar
Joined May 2012
Use a skew planar wheel from Circular Wireless on both the TX and RX, or a SPW on the TX and a Helical on the RX if you want insane range.
The issue I find with dipoles is their radiation pattern is quite flat, once you start going 5 or 6km away any pitch up or down will take our out of the beam width when flying away, or banking when flying parallel. This makes it kinda hard to gain altitude in a hurry if you need to.
I wouldn't bother with a Cloverleaf, the radiation pattern is awful compared to a SPW - there is no reason not to use a SPW.
How far are you looking to go, because a 1W tx with even an average receiver (Airwave based) will get out past 15km without breaking a sweat.
Ascended is offline Find More Posts by Ascended
Old Feb 06, 2013, 09:30 AM
Project Tormentor is flying!
United States, WA, White Salmon
Joined Nov 2005
1000 Watts! Scary!
philthyy is online now Find More Posts by philthyy
Old Feb 06, 2013, 09:52 AM
Edmonton, AB, Canada
Joined Oct 2002
I can only speak from personal experience, but my 2.4ghz (500mw) video transmitter with a stock Lawmate whip can easily do 8 miles of crystal-clear video with a 14dBi patch on the ground: http://www.readymaderc.com/store/ind...products_id=56
So $40 will give you all the range you need. No need to get complicated.
anixs is offline Find More Posts by anixs
Old Feb 06, 2013, 11:28 AM
Joined Sep 2011
Originally Posted by philthyy View Post
1000 Watts! Scary!
Woops, 1000mW. With a 1000 watts I could fly to China! philthy, thanks for the catch.
Old Feb 06, 2013, 12:00 PM
Joined Nov 2005
Heh. No worries. So, what control frequency are you using with this video system?
Old Feb 06, 2013, 12:03 PM
BushmanLA's Avatar
Joined Dec 2005
Buy circular polarized, antennas. End of story. If you want to fly more than a mile out, a circular polarized directional antenna will be useful, otherwise omni's will be just fine.
BushmanLA is offline Find More Posts by BushmanLA
Old Feb 06, 2013, 09:00 PM
Joined Sep 2011
Video is 2.4Ghz and Radio is 72Mhz.
Discussion 2.4GHz range tests in the new issue of RC Sport Flyer pwy Radios 20 Jan 08, 2014 10:35 AM
Discussion Approx Range 2.4ghz 500mw mick3485 FPV Talk 9 Jan 17, 2013 02:04 AM
For Sale 1 Watt 2.4Ghz Booster (3s lipo) w/ Attn pad, High gain Ant -- MUST SEE SELLING CHEAP mmalik4 FPV Equipment (FS/W) 3 Jan 04, 2013 10:23 PM
Easy, cheap way to increase video camera range? eyedoc Aerial Photography 4 May 07, 2004 06:31 PM
