Old Jan 14, 2013, 09:39 AM
Joined Aug 2012
Is this power setup realistic?
I'm currently running my Scimitar on an ICE 100 with the stock motor, 5s 3300, and an APC 9x9e. Static power draw according to the datalogs is averaging 95amps and 1600w at WOT. According to my inline wattage meter it's more like 78amps and 1500w - not sure who to believe.
Anyway...
The Power 32 motor is only rated for 60a and 600w continuous, so I'd like to get something more likely to hold up to the power being pulled and if I can pick up some speed in the process that'd be great. Having a high enough kv to be able to run a 4s 4000mah instead of the 5s would also be nice too. So I found this motor...
http://www.amainhobbies.com/product_...r-2330W-1400kV
Castle's eCalc puts my current setup at about 4400 grams of static thrust and 136mph pitch speed, but it also only shows 66amps draw so I don't know how accurate it really is.
Throwing the Scorpion motor on there with only a 4s will yeild 4800/142 at 98amps with the 9x9, so I get a nice little boost in thrust/speed with the lighter weight of the 4s which will allow me to go up in mah and recover some of the lost flight time.
Am I overlooking something? I'm new to this stuff and kind of shooting in the dark while learning in the process.
AWDstylez is offline Find More Posts by AWDstylez
Old Jan 15, 2013, 04:21 PM
snoopy_schulz's Avatar
Germany, lake of constance
Joined Oct 2010
Hi AWDstylez
With the Scorpion HK-3226-1400 Brushless Motor @ 4S and a 9x9 prop the calculated
motor current with my own motor calc is about 100 A. Details see attachment.
Best regards
Micha
snoopy_schulz is offline Find More Posts by snoopy_schulz
Discussion Wing for this power setup? Razor_Racer Flying Wings 0 Nov 30, 2012 02:29 PM
Question Will this charger, Power Suppy setup work? snoshoe62 Batteries and Chargers 0 Mar 14, 2012 11:04 PM
Tiger Diablo - Any thoughts on this power setup Bill Germanson Foamies (Kits) 2 Oct 27, 2002 11:09 PM
Carb Batery Charger As 12v DC Power Supply???? Will This Setup Work putt_13 Electric Plane Talk 2 Aug 13, 2002 12:13 PM
Does this even sound realistic (motocalc 6) Rekit Electric Plane Talk 4 May 22, 2001 07:07 PM
