Old Aug 17, 2012, 05:22 PM
Peter, irl
Joined May 2012
Hitec HS-125 tab removal?
Anybody ever take off the three tabs from those servos or their digital cousins? Want to heat-shrink and epoxy them into some composite wings, don't want to expand the bay opening. The bottom one looks like I could unscrew the plate, but not sure about the two in the side...
Itchy Thumbs is offline Find More Posts by Itchy Thumbs
Old Aug 17, 2012, 05:31 PM
Ninja Master
BigSwede's Avatar
United States, CA, Thousand Oaks
Joined Feb 2007
Don't do it!!! Just make some ply frames and epoxy them into the wing! Easy servo removal for service, adjustment, or replacement. Once I started using frames a few years ago, I'll never glue another servo into a wing again.
But, if you really do want to cut the tabs off, just use a pair of flush cut pliers and snip them off.
BigSwede is offline Find More Posts by BigSwede
Old Aug 17, 2012, 06:03 PM
Peter, irl
Joined May 2012
With the tabs off and sanded there would still barely be enoug room to get the servos through the opening. Sure a ply frame would be nice but why not the other method?
Old Aug 17, 2012, 06:19 PM
United States, MA, Waltham
Joined Dec 2001
Snip them. I've done it a few times with decent results.
lincoln is offline Find More Posts by lincoln
Old Aug 17, 2012, 06:22 PM
Wallingford, Ct
Joined Sep 2001
I would saw them off with a razor saw.
Al M is online now Find More Posts by Al M
Old Aug 17, 2012, 08:45 PM
USA, FL, Milton
Joined Jul 2008
I used a razor saw on mine too. Very easy and a flush cut. Cut off the tab on the side opposite the shaft and butted the servo up against a wing rib. Other two tabs used for screws in a homemade plywood mount. Worked out extremely well.
lc
liftchaser is offline Find More Posts by liftchaser
Old Aug 19, 2012, 03:55 PM
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
Maybe a different servo would be a better fit? The 125's were notoriously breakable. What plane and what will they control?
Mark Miller is offline Find More Posts by Mark Miller
Old Aug 21, 2012, 09:23 PM
Peter, irl
Joined May 2012
They are meant for the ailerons on the Reverb (aka a bunch of other names) from HK. What is it that's known to break?
Sold 3 Hitec HS-65MG 2 Hitec HS-65HB crashnburn69 Aircraft - General - Radio Equipment (FS/W) 1 Jul 19, 2012 04:26 AM
Sold 6 Hitec HS-645MG Servos $125 Shipped aaflyer60 Aircraft - General - Radio Equipment (FS/W) 2 Mar 20, 2012 06:58 PM
Sold Unused Hitec HS-125 2 each & 2 each HS-5125 used Kenneth Henius Aircraft - General - Radio Equipment (FS/W) 1 Dec 23, 2009 06:46 PM
HS-125 servo stickers not to be removed? tic Hitec/Multiplex USA 3 Jul 16, 2005 08:41 AM
