Old Apr 12, 2011, 05:46 PM
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
Quick flashing blue KK board question.
Hey Guys,
Hope all is well and still flying high.
Got a quick question for ya.
When flashing the blue KK FC, do all the esc wires, power wires and receiver connections need to be disconnected to flash a new firmware or can it be flashed with all still connected and just no power on anything?
Going to try the new 1.6 firmware on my blueboard Y4 and have never flashed it before.
Does the KKmulticopter flash tool work good or should I use something else to flash with.
Randy
Flyingfool is offline Find More Posts by Flyingfool
Old Apr 13, 2011, 04:35 PM
danielnc06's Avatar
United States, NC, Charlotte
Joined May 2010
U can leave it all plugged up. But you shouldnt use ur normal battery as power..i have had issues that way.
What i do...take the heli and unplug battery. Hook up the isp connector. Then plug a 5v battery into an empty motor slot to give the board power. The escs will beep since they are getting 5v power but no main battery power. Now u can program the chip.
Sent from my ADR6300 using Tapatalk
danielnc06 is offline Find More Posts by danielnc06
Old Apr 13, 2011, 07:01 PM
Flyingfool's Avatar
Joined Apr 2002
I actually flashed it last night but I unplugged all wiring first just in case because I hadn't got an answer to this question last night.
I didn't use any 5 volt to the board as the programmer must supply it with voltage from usb as it took the flash.
Was that the wrong way to do it? Should I have plugged in a 5 volt supply to the board also?
Randy
Discussion kk blue board y4 or y6? Flyingfool Multirotor Talk 5 Jun 28, 2011 10:05 AM
Discussion Blue kk board - roll of death thepelell Multirotor Talk 0 Apr 10, 2011 05:22 PM
For Sale KK board and 4 motors for Quad tc3wins Aircraft - Electric - Helis (FS/W) 5 Mar 22, 2011 06:53 PM
Discussion KK blue board hookup? aadamson Multirotor Talk 2 Feb 24, 2011 12:10 AM
Discussion Question: KK board and FY-20 or FY-90q Hamanu Multirotor Talk 2 Feb 08, 2011 04:10 PM
