Old Sep 15, 2014, 08:53 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Tu144 depron pusher
http://www.wattflyer.com/forums/showthread.php?t=73244
6mm Depron build of Russia's Tu144.
This as a sister to my sport edf Concorde.
Same build style - simplified fuselage and flat plate wing.
One change was to not use any BBQ / bamboo / cf stiffening but to sandwich two sheets of depron with laminating epoxy resin. The resulting wing is stiff over all its form unlike localized rod stiffening.
Power plants - twin Floater-jet motors 2140kv with 3s 1750 lipo each and 5.5x5.5 props.
Thrust is well over 1:1 ... actual measurements to be made once I have ironed out a few details after her maiden flights. She proved to be highly manouevrable and actually sensitive even though the elevons are tiny.
Here is the full build scenario and photos from the Wattflyer contest at start of thread.
Nigel
solentlife is online now Find More Posts by solentlife
Old Sep 15, 2014, 02:10 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Quite-good looking Concordski you have there Nigel. . . Too bad you didn't do the build here on RCG.
demondriver is online now Find More Posts by demondriver
Old Sep 16, 2014, 02:03 PM
solentlife's Avatar
Joined Jan 2010
It was all part of a competition ... which RCG do not run similar.
There's also good reason why it was only posted up on WF additional to the Comp : I was stuck for time ... after Ukraine and then of to hospital - which I've just been released from !
Nigel
Build Log F-35 Lightning II - Full Fuse Depron Pusher Parkjet Clickety Pusher Prop Jet Models 55 Dec 04, 2014 02:15 AM
depron pusher prop F16 Stefan lamers Foamies (Kits) 52 Nov 12, 2004 11:51 PM
Folding Depron == getting started on Avro Arrow pusher byrocat Foamies (Kits) 0 May 03, 2004 08:51 AM
Start Depron Profile DH-108 Pusher mtflyr Foamies (Kits) 4 Mar 15, 2004 05:18 PM
Question depron pusher jets?? CaptDH Foamies (Kits) 1 Dec 16, 2003 12:20 AM
