Old Dec 06, 2014, 09:00 AM
Joined Sep 2007
Originally Posted by GLM View Post
Hello Everybody,
I'd like to announce the long awaited Multiplex Pilatus Battery Sled System.
Thanks to Rudderman98 for lending me his fuse to make the prototype and his excellent motivation.
The build video is here:
http://youtu.be/nxdHdLUOu7U
Hopefully the aircraft shipments will start to roll soon.
These are ready go...
Cheers!
Gary
You might try these, they work great holding the battery in the exact place everytime.
robbie9859901 is offline Find More Posts by robbie9859901
Old Dec 08, 2014, 10:10 AM
United States, MO, Fenton
Joined Jan 2012
Originally Posted by ripacheco View Post
Great idea! gotta see if the electronics on the nose get on the way of the tray going in /out... the nose in my pilatus is quite full
Not a good radio installation. Put the receiver in the back just in front of the rear hatch. Works fine there. Always make sure you have the antennas oriented at 90 degrees. Your set up sandwiched close to the esc and in between the battery and motor is a recipe for disaster...
Fentonflyers is offline Find More Posts by Fentonflyers
Old Dec 08, 2014, 10:24 AM
Kimbers Keeper.
Joined Nov 2014
This looked to me like the perfect place for the rec?
BHOFM is offline Find More Posts by BHOFM
Old Dec 08, 2014, 11:34 AM
Joined Jan 2012
That it is!
Old Dec 08, 2014, 01:01 PM
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Give that man a beer! I'll be doing that while I fix my broken gear. Help move the CG back a little too, so the battery doesn't have to go so far back.
xmech2k is online now Find More Posts by xmech2k
Old Dec 08, 2014, 06:04 PM
Yes it was Abby Normal
Joined May 2012
Yep I put my main Spektrum Rx in the servo bay while the Satellite Rx went in a rear cabin window...the Morgan Mill battery sled is most useful for this plane...highly advise getting one for this plane.
TwistedGrin
TwistedGrin is offline Find More Posts by TwistedGrin
Old Dec 12, 2014, 08:17 PM
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
Got to try that!
ripacheco is offline Find More Posts by ripacheco
Old Dec 13, 2014, 01:59 AM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
TwistedGrin
Thanks TG
Cheers!
Gary
GLM is offline Find More Posts by GLM
Old Dec 13, 2014, 06:25 AM
SeeMeDo's Avatar
Joined Feb 2013
Pilatus Porter is making the trip today will shoot some video to attach. I had cracked a landing gear on the right plastic strut right at the stop for the spring. Epoxied it back and wrapped several layers of dental floss soaked in Gorilla Glue as a splice.
Jeff…………
Little on board action from Saturday 13Dec14:
Pilatus PC-6 On Board @ Aaron Bessant Park 13Dec14 (6 min 54 sec)
Jeff…………..
SeeMeDo is offline Find More Posts by SeeMeDo
Old Dec 16, 2014, 05:38 PM
rip
ripacheco's Avatar
Joined Jan 2013
Might try one of these,
Cheers!
Gary
http://www.morganmill.com/RC/Pilatus_PC_6_parts.html
Ok you talked me into it... I've ordered one of these sleds... is the right season to have a sled
Old Dec 16, 2014, 08:26 PM
EDFFanatic's Avatar
Montreal
Joined Feb 2004
Battery sled
The sled is brilliant for sure.
If you own one, would you be able to measure the width and height that it allows for, I want to order some LiPos but I want to make sure they will fit in the sled, and the plane, first.
Thanks!
EDFFanatic is offline Find More Posts by EDFFanatic
Old Dec 18, 2014, 06:58 AM
SeeMeDo's Avatar
Joined Feb 2013
If your landing strut with the spring has broke, did it break at the spring stop? That's where I finally snapped one. I've "fixed" it with some whipping and GG followed up with a coating of JB Quick so I don't think it will break again.
I've been thinking that if I cut a 1/4" off the bottom of the struts and put a small piece of foam in the bottom of the strut then they might not bottom out with as much force?
Jeff………
Old Yesterday, 05:55 PM
United States, CA, Anaheim
Joined Oct 2006
Originally Posted by Xerxesmh View Post
My plastic landing snapped on second landing as we fly from a very rough field. Decided to use shock absorbers from a 1/16th scale RC Car. See pic below. Great enhanced performance and looks the part. $10 mod works well.
Please post where you found these shocks, and how you connected them to the lower strut. Are they glued to the strut?
Thanks a lot. Looks great!
CM_HeliPilot is offline Find More Posts by CM_HeliPilot
Old Today, 12:53 AM
EDFFanatic's Avatar
Montreal
Joined Feb 2004
MPX Battery Sled
For those who want to get Gary's awesome battery sled, I got some details on the dimensions:
The width of the sled allows for a battery 1.5'' wide.
The actual slider sits 1/4'' above the floor in the nose area.
http://morganmill.com/RC/Pilatus_PC_6_parts.html
Gallery Pilatus PC-6 Porter wizard of odd Scale Drawings and Three Views 2 Nov 04, 2014 12:11 PM
Build Log Guillow's Pilatus Porter PC-6 Bill Smudge Scale Kit/Scratch Built 51 Jan 13, 2014 08:01 AM
Sold PC-6 Pilatus Porter 60" wingspan UV-20 Golden Knights version payne9999 Aircraft - Electric - Airplanes (FS/W) 12 Dec 15, 2013 01:15 PM
Discussion Pilatus PC-6 Porter DXF file wizard of odd Scale Drawings and Three Views 2 Nov 16, 2013 01:52 AM
Pilatus Pc-6 Turbo Porter Parkflyer kestrel2003 Parkflyers 23 Jan 02, 2004 06:19 PM
