Old Dec 17, 2014, 06:02 PM
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
Originally Posted by pbm77 View Post
Zero wind today so had a short launch session. Good thing spring is a long way off as I need lots of work and practice on the launch before the season starts.
I'd be thrilled to launch 55m (180')
- Jim
JimZinVT is offline Find More Posts by JimZinVT
Old Dec 17, 2014, 06:06 PM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
Originally Posted by cirrus_uk View Post
worth a read if you've not seen this before. (openAltimeter project)
Yes, I've looked in on that project a few times. It sounds fantastic, but my funds (or lack thereof ) fit the HK altimeter better. I think I'll skip the bluetooth option for now.
- Jim
Old Dec 17, 2014, 06:09 PM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
Tried it on win8 and it worked fine
Thanks for checking that Cirrus!
Old Dec 17, 2014, 06:49 PM
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
- Jim
as long as you don't bury the altimeter too far in your plane, digging it out to plug to the usb connector isn't a drama
in the binary it's ended up behind the elevator servo to optimise balance, but removing it merely needs the lemonRx pulled forward after the 1s lipo gets hoisted
scruffy1 is offline Find More Posts by scruffy1
Old Dec 17, 2014, 10:05 PM
Splash down counter: 10
xStatiCa's Avatar
United States, FL, New Port Richey
Joined Jul 2006
Made a double xStatiCa cardboard DLG wall mount to hold my 2nd 1.5m DLG. My previous version only held 1. I cut it out and then fold it so that the tabs help hold it together. Another piece gets put into the center of it that sticks out to hold it together. All i need is a used shipping box and some packaging tape. You can see the template I made for the first version which required two pieces together plus a third and then the new version that is one single piece plus another smaller version of the T piece that isn't in the template pic. I left enough room between them so I can open the canopies to charge them on the mount.
xStatiCa is offline Find More Posts by xStatiCa
Old Dec 17, 2014, 10:21 PM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
Anywhere I put it will require a bit of tail weight....my current plane balances just right with no nose lead. I have to slide out the Rx to unplug the battery after every flight, so it would probably go under the Rx. It would have to really....it's not going to fit anywhere else.
- Jim
Old Dec 18, 2014, 01:20 AM
scruffy1's Avatar
Joined Feb 2008
so does mine
and even better with the altimeter behind the servo
for the auw of under 3gm, just shove it aft in the pod and if you absolutely must, add under half a gram at the tail end
Old Dec 18, 2014, 03:35 AM
yorkshire UK
Joined Oct 2007
Xtatica, love that idea!
I have been thinking about wall mount options for a while on and off, seen lots of ideas with tubing and wires none of which i liked, never occurred to me to just cut out some cardboard like you have.
Thanks.
I know what I am going to be doing later on!
nigelsheffield is offline Find More Posts by nigelsheffield
Old Dec 18, 2014, 05:58 AM
scruffy1's Avatar
Joined Feb 2008
celebrated the arrival of a stash of foam-tac by repairing the YG bird
and discovered one of the two lemonRx i recently purchased wouldn't bind, but the other would, and so i added 9.7gm of nose weight
and then proceeded to fly it until i (re-)broke the fin
which i intend to fix
however, it flew pretty nicely until i absolutely delaminated the carbon fin support from the epoxy... so i have some hope for it
Discussion What crazy thing did you do with your plane today? RCAddict16 Electric Plane Talk 14 Nov 16, 2014 09:31 PM
Discussion What do you guys do with your Old RC Toys? Sherlock221B RC Toys 11 Oct 08, 2014 01:46 AM
Discussion What Do *You* Do With Your Clapped-Out Servos? A Useless Geek DIY Electronics 6 May 03, 2012 03:30 PM
Poll What do you do with your Old Timer? orange&white Vintage & Old-Timer Designs 17 Apr 25, 2012 04:14 PM
Discussion How do you travel with your DLG, Blaster 2-3, Fireworks etc nph Hand Launch 13 Mar 27, 2012 02:19 PM
